1 |
from __future__ import division, print_function, unicode_literals |
2 |
3 |
import os |
4 |
5 |
Import ('env') |
6 |
7 |
# math libs |
8 |
mlib = env['RAD_MLIB'] |
9 |
10 |
# compose paths |
11 |
def rbin(name): return os.path.join(env['RAD_BUILDBIN'], name) |
12 |
13 |
trans = env.Object(source="trans.c") |
14 |
bsdfrep = env.Object(source="bsdfrep.c") |
15 |
bsdfinterp = env.Object(source="bsdfinterp.c") |
16 |
17 |
# standard targets |
18 |
PROGS = [ |
19 |
('3ds2mgf', Split('3ds2mgf.c rayopt3ds.c vect3ds.c'), ['mgf','rtrad'] + mlib), |
20 |
('ies2rad', ['ies2rad.c'], ['rtrad'] + mlib), |
21 |
#('arch2rad', ['arch2rad.c',trans],['rtrad'] + mlib), |
22 |
('nff2rad', ['nff2rad.c'], []), |
23 |
('lampcolor', ['lampcolor.c'], ['rtrad'] ), |
24 |
('tmesh2rad', ['tmesh2rad.c'], ['rtrad'] + mlib), |
25 |
('obj2rad', ['obj2rad.c',trans], ['rtrad'] + mlib), |
26 |
('mgf2rad', ['mgf2rad.c'], ['mgf','rtrad'] + mlib), |
27 |
('rad2mgf', ['rad2mgf.c'], ['rtrad'] + mlib), |
28 |
('mgfilt', ['mgfilt.c'], ['mgf','rtrad'] + mlib), |
29 |
('mgf2inv', ['mgf2inv.c'], ['mgf','rtrad'] + mlib), |
30 |
('pabopto2bsdf', |
31 |
['pabopto2bsdf.c',bsdfrep,'bsdfrbf.c', 'bsdfmesh.c', 'bsdftrans.cpp',], |
32 |
33 |
('bsdf2klems',['bsdf2klems.c', bsdfrep, bsdfinterp,], ['rtrad'] + mlib), |
34 |
('bsdf2ttree',['bsdf2ttree.c', bsdfrep, bsdfinterp,], ['rtrad'] + mlib), |
35 |
('pkgBSDF', ['pkgBSDF.c', ], ['rtrad'] + mlib), |
36 |
('epw2wea', ['epw2wea.c', ], ['rtrad'] + mlib), |
37 |
('mgf2meta', ['mgf2meta.c'], ['meta', 'mgf','rtrad'] + mlib, |
38 |
[os.path.join('#src','meta')]), |
39 |
40 |
for p in PROGS: |
41 |
if len(p) == 4: inclp = env.get('CPPPATH', []) + [os.path.join('#src','meta')], |
42 |
else: inclp = env.get('CPPPATH', []) |
43 |
prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2], CPPPATH=inclp) |
44 |
Default(prog) |
45 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) |
46 |
47 |
LIBFILES = Split('bsdf2rad.cal source.cal tilt.cal window.cal') |
48 |
env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES)) |
49 |
50 |
if os.name == 'posix': |
51 |
for s in Split('''optics2rad'''): |
52 |
Default(env.InstallScript(rbin(s), s + '.csh')) |
53 |
54 |
# vim: set syntax=python: |
55 |
# vi: set ts=4 sw=4 : |
