root/Development/ray/src/cv/SConscript
Revision: 1.9
Committed: Fri Jul 9 15:24:44 2010 UTC (15 years, 5 months ago) by greg
Removed duplicate installs and added dctimestep
1 import os
2
3 Import ('env')
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 # compose paths
9 def rbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
10 def rlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
11 def mgfs(src): return map(lambda s:os.path.join('mgflib', s), src)
12
13 MGFSRC = Split('''parser.c context.c xf.c object.c lookup.c badarg.c
14 words.c
15 fvect.c''')
16 libmgf = env.StaticLibrary(rlib('mgf'), source=mgfs(MGFSRC))
17
18 MGFPROGS = (
19 ('mgfilt', Split('mgfilt.c')),
20 ('mgf2inv', Split('mgf2inv.c cvrgb.c')),
21 ('3ds2mgf', Split('3ds2mgf.c rayopt.c vect.c')),
22 )
23 for p in MGFPROGS:
24 prog = env.Program(target=rbin(p[0]), source=mgfs(p[1]), LIBS=mlib+['mgf'])
25 Default(prog)
26 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
27
28 trans = env.Object(source="trans.c")
29
30 # standard targets
31 PROGS = [
32 ('ies2rad', ['ies2rad.c'], ['rtlamps','rtcolor','rtio','rtpath']+ mlib),
33 ('arch2rad', ['arch2rad.c',trans],['rtcont','rtmem'] + mlib),
34 ('nff2rad', ['nff2rad.c'], []),
35 ('lampcolor', ['lampcolor.c'], ['rtlamps','rtcolor','rtio','rtpath']),
36 ('tmesh2rad', ['tmesh2rad.c'], ['rtscene','rtmath'] + mlib),
37 ('obj2rad', ['obj2rad.c',trans],
38 ['rtscene','rtargs','rtio','rtcont','rtmem','rtmath','rterror'] + mlib),
39 ('mgf2rad', ['mgf2rad.c'], ['rtscene','rtcolor','mgf'] + mlib),
40 ('rad2mgf', ['rad2mgf.c'],
41 ['rtproc', 'rtpath', # for win_popen()
42 'rtscene','rtio','rtcolor','rtcont','rtmem','rterror'] + mlib),
43 ]
44 for p in PROGS:
45 prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2])
46 Default(prog)
47 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
48
49 # meta targets
50 prog = env.Program(target=rbin('mgf2meta'), source=['mgf2meta.c'],
51 CPPPATH=env.get('CPPPATH', []) + [os.path.join('#src','meta')],
52 LIBS=['meta','rtmath','rtcont','rtmem','rterror','mgf'] + mlib)
53
54 LIBFILES = Split('source.cal tilt.cal window.cal')
55 env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
56
57 if os.name == 'posix':
58 for s in Split('''optics2rad'''):
59 Default(env.InstallCsh(rbin(s), s + '.csh'))
