root/Development/ray/src/cv/SConscript
Revision: 1.15
Committed: Thu Mar 10 21:43:22 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.14: +20 -33 lines
1 import os
2
3 Import ('env')
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 # compose paths
9 def rbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
10
11 trans = env.Object(source="trans.c")
12 bsdfrep = env.Object(source="bsdfrep.c")
13 bsdfinterp = env.Object(source="bsdfinterp.c")
14
15 # standard targets
16 PROGS = [
17 ('3ds2mgf', Split('3ds2mgf.c rayopt3ds.c vect3ds.c'), ['mgf','rtrad'] + mlib),
18 ('ies2rad', ['ies2rad.c'], ['rtrad'] + mlib),
19 #('arch2rad', ['arch2rad.c',trans],['rtrad'] + mlib),
20 ('nff2rad', ['nff2rad.c'], []),
21 ('lampcolor', ['lampcolor.c'], ['rtrad'] ),
22 ('tmesh2rad', ['tmesh2rad.c'], ['rtrad'] + mlib),
23 ('obj2rad', ['obj2rad.c',trans], ['rtrad'] + mlib),
24 ('mgf2rad', ['mgf2rad.c'], ['mgf','rtrad'] + mlib),
25 ('rad2mgf', ['rad2mgf.c'], ['rtrad'] + mlib),
26 ('mgfilt', ['mgfilt.c'], ['mgf','rtrad'] + mlib),
27 ('mgf2inv', ['mgf2inv.c'], ['mgf','rtrad'] + mlib),
28 ('pabopto2bsdf',
29 ['pabopto2bsdf.c',bsdfrep,'bsdfrbf.c', 'bsdfmesh.c', 'bsdftrans.cpp',],
30 ['rtrad'] + mlib),
31 ('bsdf2klems',['bsdf2klems.c', bsdfrep, bsdfinterp,], ['rtrad'] + mlib),
32 ('bsdf2ttree',['bsdf2ttree.c', bsdfrep, bsdfinterp,], ['rtrad'] + mlib),
33 ('pkgBSDF', ['pkgBSDF.c', ], ['rtrad'] + mlib),
34 ('epw2wea', ['epw2wea.c', ], ['rtrad'] + mlib),
35 ('mgf2meta', ['mgf2meta.c'], ['meta', 'mgf','rtrad'] + mlib,
36 [os.path.join('#src','meta')]),
37 ]
38 for p in PROGS:
39 if len(p) == 4: inclp = env.get('CPPPATH', []) + [os.path.join('#src','meta')],
40 else: inclp = env.get('CPPPATH', [])
41 prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2], CPPPATH=inclp)
42 Default(prog)
43 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
44
45 LIBFILES = Split('source.cal tilt.cal window.cal')
46 env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
47
48 if os.name == 'posix':
49 for s in Split('''optics2rad'''):
50 Default(env.InstallScript(rbin(s), s + '.csh'))
51
52 # vim: set syntax=python:
