Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added mgf2meta program
added rad2mgf program
minor change to clean entry
added mgf2rad program
added mapping file to obj2rad
created obj2rad program
added tmesh2rad program
standardized macro settings
moved librt to ../lib
added lampcolor
Makefile normalization
improved use of lamp data
