root/radiance/ray/src/cv/Rmakefile
Revision: 2.25
Committed: Wed Oct 27 23:36:09 2004 UTC (19 years, 5 months ago) by greg
CVS Tags: rad3R6P1
# User Rev Content
1 greg 2.25 # RCSid $Id: Rmakefile,v 2.24 2003/11/17 13:20:10 schorsch Exp $
2 greg 2.8 #
3 greg 1.1 # Makefile for conversion programs
4     #
5
6 greg 1.3 OPT = -O
7 greg 1.1
8 greg 1.10 MACH = -DBSD
9 greg 1.1
10 greg 2.18 CFLAGS = -I../common -L../lib $(OPT) $(MACH)
11 schorsch 2.24 METACFLAGS = -I../meta
12 greg 1.1
13 greg 2.2 CC = cc
14
15 greg 2.4 MLIB = -lm
16
17 greg 1.10 INSTDIR = /usr/local/bin
18 greg 1.1
19 greg 1.10 LIBDIR = /usr/local/lib/ray
20 greg 1.3
21 schorsch 2.20 MGF_LIB = ../lib/libmgf.a
22
23 greg 2.10 PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \
24 greg 2.15 mgf2rad rad2mgf mgf2meta mgfilt mgf2inv
25 greg 1.3
26 greg 2.19 LIBFILES = source.cal tilt.cal lamp.tab
27 greg 1.9
28 greg 1.3 all: $(PROGS)
29
30 greg 1.9 install: $(PROGS) $(LIBFILES)
31 greg 1.3 cp $(PROGS) $(INSTDIR)
32 greg 2.23 cd $(LIBDIR) && rm -f $(LIBFILES)
33 greg 1.9 cp $(LIBFILES) $(LIBDIR)
34 greg 1.3
35     clean:
36 greg 1.5 set nonomatch; rm -f $(PROGS) *.o core
37 greg 2.9 cd mgflib ; make clean
38 greg 1.3
39     thf2rad: thf2rad.o
40 greg 2.2 $(CC) $(CFLAGS) -o thf2rad thf2rad.o
41 greg 1.3
42 greg 1.6 ies2rad: ies2rad.o
43 greg 2.13 $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrt -lm
44 greg 1.1
45 greg 1.6 arch2rad: arch2rad.o trans.o
46 greg 2.2 $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt
47 greg 1.1
48 greg 1.3 nff2rad: nff2rad.o
49 greg 2.2 $(CC) $(CFLAGS) -o nff2rad nff2rad.o
50 greg 1.4
51 greg 1.6 lampcolor: lampcolor.o
52 greg 2.2 $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrt
53 greg 1.3
54 greg 2.19 tmesh2rad: tmesh2rad.o
55     $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrt $(MLIB)
56 greg 2.5
57 greg 2.19 obj2rad: obj2rad.o trans.o
58     $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrt $(MLIB)
59 greg 2.4
60 schorsch 2.20 mgf2rad: $(MGF_LIB) mgf2rad.o
61 greg 2.19 $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrt $(MLIB)
62 greg 2.7
63 greg 2.10 rad2mgf: rad2mgf.o
64     $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrt $(MLIB)
65
66 schorsch 2.20 mgf2meta: $(MGF_LIB) mgf2meta.o
67 greg 2.12 $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrt $(MLIB)
68 greg 2.15
69     mgfilt:
70     cd mgflib ; rm -f mgfilt ; \
71     make mgfilt CC=$(CC) \
72 greg 2.21 CFLAGS="$(OPT) $(MACH)" ; \
73 greg 2.15 mv mgfilt ..
74
75     mgf2inv:
76     cd mgflib ; rm -f mgf2inv ; \
77     make mgf2inv CC=$(CC) \
78 greg 2.21 CFLAGS="$(OPT) $(MACH)" ; \
79 greg 2.15 mv mgf2inv ..
80 greg 2.12
81 schorsch 2.20 $(MGF_LIB):
82 greg 2.12 cd mgflib ; rm -f libmgf.a ; \
83 greg 2.11 make libmgf.a CC=$(CC) \
84 greg 2.21 CFLAGS="$(OPT) $(MACH)" ; \
85     mv libmgf.a ../../lib
86 greg 2.7
87 greg 2.19 mgf2rad.o: mgf2rad.c mgflib/parser.h ../common/tmesh.h ../common/color.h
88 greg 2.21 $(CC) $(CFLAGS) -c mgf2rad.c
89 greg 2.12
90 greg 2.18 mgf2meta.o: mgf2meta.c mgflib/parser.h
91 schorsch 2.24 $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c
92 greg 2.7
93 greg 1.1 arch2rad.o trans.o: trans.h
94
95 greg 1.11 ies2rad.o lampcolor.o: ../common/color.h
96 greg 2.3
97     ies2rad.o: ../common/paths.h
98 greg 2.4
99 greg 2.19 obj2rad.o tmesh2rad.o: ../common/tmesh.h \
100 greg 2.22 ../common/standard.h ../common/rtmisc.h ../common/rtio.h \
101 greg 2.25 ../common/rtmath.h ../common/rterror.h ../common/mat4.h \
102     ../common/fvect.h ../common/tifftypes.h
103 greg 2.7
104     obj2rad.o: trans.h
105 greg 2.10
106 gwlarson 2.17 rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \
107     ../common/object.h ../common/color.h ../common/lookup.h
