root/radiance/ray/src/cv/Rmakefile
Revision: 2.58
Committed: Tue Mar 8 19:04:56 2022 UTC (3 years ago) by greg
Changes since 2.57: +3 -2 lines
feat(iso2klems): New script to generate Klems BSDF from simplified measurements
1 # RCSid $Id: Rmakefile,v 2.57 2021/12/14 02:33:18 greg Exp $
2 #
3 # Makefile for conversion programs
4 #
5
6 OPT = -O
7
8 MACH = -DBSD
9
10 CFLAGS = -I../common -L../lib $(OPT) $(MACH)
11 CXXFLAGS = $(CFLAGS)
12 METACFLAGS = -I../meta
13
14 CC = cc
15 CXX = c++
16
17 MLIB = -lm
18
19 INSTDIR = /usr/local/bin
20
21 LIBDIR = /usr/local/lib/ray
22
23 PROGS = ies2rad nff2rad lampcolor tmesh2rad obj2rad robjutil \
24 mgf2rad rad2mgf mgf2meta mgfilt mgf2inv 3ds2mgf bsdfquery checkBSDF \
25 pabopto2xyz pabopto2bsdf bsdf2ttree bsdf2klems pkgBSDF epw2wea bsdf2rad
26
27 LIBFILES = source.cal tilt.cal lamp.tab window.cal bsdf2rad.cal
28
29 all: $(PROGS)
30
31 install: $(PROGS) $(LIBFILES) optics2rad.csh
32 cp $(PROGS) $(INSTDIR)
33 cp optics2rad.csh $(INSTDIR)/optics2rad
34 cp iso2klems.pl $(INSTDIR)/iso2klems
35 chmod 755 $(INSTDIR)/optics2rad $(INSTDIR)/iso2klems
36 cd $(LIBDIR) && rm -f $(LIBFILES)
37 cp $(LIBFILES) $(LIBDIR)
38
39 clean:
40 set nonomatch; rm -f $(PROGS) *.o
41
42 ies2rad: ies2rad.o
43 $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad $(MLIB)
44
45 arch2rad: arch2rad.o trans.o
46 $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad
47
48 nff2rad: nff2rad.o
49 $(CC) $(CFLAGS) -o nff2rad nff2rad.o
50
51 lampcolor: lampcolor.o
52 $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrtrad
53
54 tmesh2rad: tmesh2rad.o
55 $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrtrad $(MLIB)
56
57 obj2rad: obj2rad.o trans.o
58 $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB)
59
60 mgf2rad: mgf2rad.o
61 $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB)
62
63 rad2mgf: rad2mgf.o
64 $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB)
65
66 mgf2meta: mgf2meta.o
67 $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB)
68
69 mgfilt: mgfilt.o
70 $(CC) $(CFLAGS) -o mgfilt mgfilt.o -lmgf -lrtrad $(MLIB)
71
72 mgf2inv: mgf2inv.o
73 $(CC) $(CFLAGS) -o mgf2inv mgf2inv.o -lmgf -lrtrad $(MLIB)
74
75 3ds2mgf: 3ds2mgf.o rayopt3ds.o vect3ds.o
76 $(CC) $(CFLAGS) -o 3ds2mgf 3ds2mgf.o rayopt3ds.o vect3ds.o \
77 -lmgf -lrtrad $(MLIB)
78
79 pabopto2xyz: pabopto2xyz.o
80 $(CXX) $(CXXFLAGS) -o pabopto2xyz pabopto2xyz.o \
81 -lrtrad $(MLIB)
82
83 pabopto2bsdf: pabopto2bsdf.o bsdfrep.o bsdfrbf.o bsdfmesh.o bsdftrans.o
84 $(CXX) $(CXXFLAGS) -o pabopto2bsdf pabopto2bsdf.o bsdfrep.o \
85 bsdfrbf.o bsdfmesh.o bsdftrans.o -lrtrad $(MLIB)
86
87 pabopto2rad: pabopto2rad.o bsdfrep.o bsdfrbf.o
88 $(CC) $(CFLAGS) -o pabopto2rad pabopto2rad.o bsdfrep.o \
89 bsdfrbf.o -lrtrad $(MLIB)
90
91 pabopto2rad.o: pabopto2bsdf.c bsdfrep.h
92 $(CC) $(CFLAGS) -c -DTEST_MAIN -o pabopto2rad.o pabopto2bsdf.c
93
94 bsdf2rad: bsdf2rad.o bsdfrep.o bsdfinterp.o
95 $(CC) $(CFLAGS) -o bsdf2rad bsdf2rad.o bsdfrep.o bsdfinterp.o \
96 -lrtrad $(MLIB)
97
98 bsdf2rado: bsdf2rado.o bsdfrep.o bsdfinterp.o
99 $(CC) $(CFLAGS) -o bsdf2rado bsdf2rado.o bsdfrep.o bsdfinterp.o \
100 -lrtrad $(MLIB)
101
102 bsdfquery: bsdfquery.o bsdfrep.o bsdfinterp.o
103 $(CC) $(CFLAGS) -o bsdfquery bsdfquery.o bsdfrep.o bsdfinterp.o \
104 -lrtrad $(MLIB)
105
106 bsdf2ttree: bsdf2ttree.o bsdfrep.o bsdfinterp.o
107 $(CC) $(CFLAGS) -o bsdf2ttree bsdf2ttree.o bsdfrep.o bsdfinterp.o \
108 -lrtrad $(MLIB)
109
110 bsdf2klems: bsdf2klems.o bsdfrep.o bsdfinterp.o
111 $(CC) $(CFLAGS) -o bsdf2klems bsdf2klems.o bsdfrep.o bsdfinterp.o \
112 -lrtrad $(MLIB)
113
114 pkgBSDF: pkgBSDF.o
115 $(CC) $(CFLAGS) -o pkgBSDF pkgBSDF.o -lrtrad $(MLIB)
116
117 checkBSDF: checkBSDF.o
118 $(CC) $(CFLAGS) -o checkBSDF checkBSDF.o -lrtrad $(MLIB)
119
120 epw2wea: epw2wea.o
121 $(CC) $(CFLAGS) -o epw2wea epw2wea.o
122
123 robjutil: robjutil.o
124 $(CC) $(CFLAGS) -o robjutil robjutil.o \
125 -lwfobj -lrtrad $(MLIB)
126
127 mgf2rad.o: mgf2rad.c ../common/mgf_parser.h ../common/tmesh.h \
128 ../common/color.h
129 $(CC) $(CFLAGS) -c mgf2rad.c
130
131 mgf2meta.o: mgf2meta.c ../common/mgf_parser.h
132 $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c
133
134 arch2rad.o trans.o: trans.h
135
136 ies2rad.o lampcolor.o: ../common/color.h
137
138 ies2rad.o: ../common/paths.h
139
140 obj2rad.o tmesh2rad.o: ../common/tmesh.h \
141 ../common/standard.h ../common/rtmisc.h ../common/rtio.h \
142 ../common/rtmath.h ../common/rterror.h ../common/mat4.h \
143 ../common/fvect.h
144
145 obj2rad.o: trans.h
146
147 rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \
148 ../common/object.h ../common/color.h ../common/lookup.h
149
150 mgfilt.o: ../common/mgf_parser.h ../common/ccolor.h
151
152 mgf2inv.o: ../common/mgf_parser.h ../common/ccolor.h
153
154 3ds2mgf.o rayopt3ds.o: rayopt3ds.h
155
156 3ds2mgf.o rayopt3ds.o vect3ds.o: vect3ds.h
157
158 checkBSDF.o pkgBSDF.o: ../common/bsdf.h ../common/fvect.h \
159 ../common/ccolor.h ../common/paths.h
160
161 bsdf2ttree.o bsdfinterp.o bsdfmesh.o bsdfrbf.o bsdfrep.o bsdf2rad.o bsdftrans.o \
162 pabopto2bsdf.o: bsdfrep.h ../common/bsdf.h ../common/fvect.h ../common/ccolor.h
163
164 bsdf2ttree.o pabopto2bsdf.o: ../common/platform.h
165
166 bsdfrep.o: ../common/resolu.h ../common/rtio.h
167
168 pabopto2bsdf.o: ../common/resolu.h
169
170 bsdf2rad.o bsdf2ttree.o: ../common/rtprocess.h
171
172 bsdf2klems.o bsdf2ttree.o mgf2meta.o: ../common/random.h
173
174 bsdftrans.o: transportSimplex.h
175
176 bsdfquery.o: ../common/rtmath.h ../common/rtio.h bsdfrep.h
177
178 checkBSDF.o: ../common/rtio.h ../common/bsdf_m.h ../common/bsdf_t.h
179
180 robjutil.o: ../common/objutil.h
