root/Development/ray/src/cv/Rmakefile
Revision: 2.38
Committed: Fri Oct 19 04:14:29 2012 UTC (13 years, 1 month ago) by greg
Changes since 2.37: +16 -5 lines
1 # RCSid $Id: Rmakefile,v 2.37 2012/08/24 15:20:18 greg Exp $
2 #
3 # Makefile for conversion programs
4 #
5
6 OPT = -O
7
8 MACH = -DBSD
9
10 CFLAGS = -I../common -L../lib $(OPT) $(MACH)
11 METACFLAGS = -I../meta
12
13 CC = cc
14
15 MLIB = -lm
16
17 INSTDIR = /usr/local/bin
18
19 LIBDIR = /usr/local/lib/ray
20
21 PROGS = ies2rad nff2rad lampcolor tmesh2rad obj2rad \
22 mgf2rad rad2mgf mgf2meta mgfilt mgf2inv 3ds2mgf \
23 pabopto2bsdf bsdf2ttree pkgBSDF
24
25 LIBFILES = source.cal tilt.cal lamp.tab window.cal
26
27 all: $(PROGS)
28
29 install: $(PROGS) $(LIBFILES) optics2rad.csh
30 cp $(PROGS) $(INSTDIR)
31 cp optics2rad.csh $(INSTDIR)/optics2rad
32 chmod 755 $(INSTDIR)/optics2rad
33 cd $(LIBDIR) && rm -f $(LIBFILES)
34 cp $(LIBFILES) $(LIBDIR)
35
36 clean:
37 set nonomatch; rm -f $(PROGS) *.o core
38
39 ies2rad: ies2rad.o
40 $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad $(MLIB)
41
42 arch2rad: arch2rad.o trans.o
43 $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad
44
45 nff2rad: nff2rad.o
46 $(CC) $(CFLAGS) -o nff2rad nff2rad.o
47
48 lampcolor: lampcolor.o
49 $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrtrad
50
51 tmesh2rad: tmesh2rad.o
52 $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrtrad $(MLIB)
53
54 obj2rad: obj2rad.o trans.o
55 $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB)
56
57 mgf2rad: mgf2rad.o
58 $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB)
59
60 rad2mgf: rad2mgf.o
61 $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB)
62
63 mgf2meta: mgf2meta.o
64 $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB)
65
66 mgfilt: mgfilt.o
67 $(CC) $(CFLAGS) -o mgfilt mgfilt.o -lmgf -lrtrad $(MLIB)
68
69 mgf2inv: mgf2inv.o
70 $(CC) $(CFLAGS) -o mgf2inv mgf2inv.o -lmgf -lrtrad $(MLIB)
71
72 3ds2mgf: 3ds2mgf.o rayopt3ds.o vect3ds.o
73 $(CC) $(CFLAGS) -o 3ds2mgf 3ds2mgf.o rayopt3ds.o vect3ds.o \
74 -lmgf -lrtrad $(MLIB)
75
76 pabopto2bsdf: pabopto2bsdf.o bsdfrep.o bsdfrbf.o bsdfmesh.o
77 $(CC) $(CFLAGS) -o pabopto2bsdf pabopto2bsdf.o bsdfrep.o \
78 bsdfrbf.o bsdfmesh.o -lrtrad $(MLIB)
79
80 bsdf2ttree: bsdf2ttree.o bsdfrep.o bsdfinterp.o
81 $(CC) $(CFLAGS) -o bsdf2ttree bsdf2ttree.o bsdfrep.o bsdfinterp.o \
82 -lrtrad $(MLIB)
83
84 pkgBSDF: pkgBSDF.o
85 $(CC) $(CFLAGS) -o pkgBSDF pkgBSDF.o -lrtrad $(MLIB)
86
87 mgf2rad.o: mgf2rad.c ../common/mgf_parser.h ../common/tmesh.h \
88 ../common/color.h
89 $(CC) $(CFLAGS) -c mgf2rad.c
90
91 mgf2meta.o: mgf2meta.c ../common/mgf_parser.h
92 $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c
93
94 arch2rad.o trans.o: trans.h
95
96 ies2rad.o lampcolor.o: ../common/color.h
97
98 ies2rad.o: ../common/paths.h
99
100 obj2rad.o tmesh2rad.o: ../common/tmesh.h \
101 ../common/standard.h ../common/rtmisc.h ../common/rtio.h \
102 ../common/rtmath.h ../common/rterror.h ../common/mat4.h \
103 ../common/fvect.h
104
105 obj2rad.o: trans.h
106
107 rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \
108 ../common/object.h ../common/color.h ../common/lookup.h
109
110 mgfilt.o: ../common/mgf_parser.h ../common/ccolor.h
111
112 mgf2inv.o: ../common/mgf_parser.h ../common/ccolor.h
113
114 3ds2mgf.o rayopt3ds.o: rayopt3ds.h
115
116 3ds2mgf.o rayopt3ds.o vect3ds.o: vect3ds.h
117
118 pkgBSDF.o: ../common/bsdf.h ../common/fvect.h ../common/ccolor.h \
119 ../common/paths.h
120
121 bsdf2ttree.o bsdfinterp.o bsdfmesh.o bsdfrbf.o bsdfrep.o \
122 pabopto2bsdf.o: bsdfrep.h ../common/bsdf.h ../common/fvect.h ../common/ccolor.h
123
124 bsdf2ttree.o pabopto2bsdf.o: ../common/platform.h
125
126 bsdfrep.o: ../common/resolu.h ../common/rtio.h
