root/Development/ray/src/cv/Rmakefile
Revision: 2.37
Committed: Fri Aug 24 15:20:18 2012 UTC (13 years, 1 month ago) by greg
Changes since 2.36: +7 -2 lines
Introducing program for interpolating BSDF data
1 # RCSid $Id: Rmakefile,v 2.36 2011/06/23 18:05:18 greg Exp $
2 #
3 # Makefile for conversion programs
4 #
5
6 OPT = -O
7
8 MACH = -DBSD
9
10 CFLAGS = -I../common -L../lib $(OPT) $(MACH)
11 METACFLAGS = -I../meta
12
13 CC = cc
14
15 MLIB = -lm
16
17 INSTDIR = /usr/local/bin
18
19 LIBDIR = /usr/local/lib/ray
20
21 PROGS = ies2rad nff2rad lampcolor tmesh2rad obj2rad \
22 mgf2rad rad2mgf mgf2meta mgfilt mgf2inv pabopto2xml pkgBSDF 3ds2mgf
23
24 LIBFILES = source.cal tilt.cal lamp.tab window.cal
25
26 all: $(PROGS)
27
28 install: $(PROGS) $(LIBFILES) optics2rad.csh
29 cp $(PROGS) $(INSTDIR)
30 cp optics2rad.csh $(INSTDIR)/optics2rad
31 chmod 755 $(INSTDIR)/optics2rad
32 cd $(LIBDIR) && rm -f $(LIBFILES)
33 cp $(LIBFILES) $(LIBDIR)
34
35 clean:
36 set nonomatch; rm -f $(PROGS) *.o core
37
38 ies2rad: ies2rad.o
39 $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad $(MLIB)
40
41 arch2rad: arch2rad.o trans.o
42 $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad
43
44 nff2rad: nff2rad.o
45 $(CC) $(CFLAGS) -o nff2rad nff2rad.o
46
47 lampcolor: lampcolor.o
48 $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrtrad
49
50 tmesh2rad: tmesh2rad.o
51 $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrtrad $(MLIB)
52
53 obj2rad: obj2rad.o trans.o
54 $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB)
55
56 mgf2rad: mgf2rad.o
57 $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB)
58
59 rad2mgf: rad2mgf.o
60 $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB)
61
62 mgf2meta: mgf2meta.o
63 $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB)
64
65 mgfilt: mgfilt.o
66 $(CC) $(CFLAGS) -o mgfilt mgfilt.o -lmgf -lrtrad $(MLIB)
67
68 mgf2inv: mgf2inv.o
69 $(CC) $(CFLAGS) -o mgf2inv mgf2inv.o -lmgf -lrtrad $(MLIB)
70
71 3ds2mgf: 3ds2mgf.o rayopt3ds.o vect3ds.o
72 $(CC) $(CFLAGS) -o 3ds2mgf 3ds2mgf.o rayopt3ds.o vect3ds.o \
73 -lmgf -lrtrad $(MLIB)
74
75 pabopto2xml: pabopto2xml.o
76 $(CC) $(CFLAGS) -o pabopto2xml pabopto2xml.o -lrtrad $(MLIB)
77
78 pkgBSDF: pkgBSDF.o
79 $(CC) $(CFLAGS) -o pkgBSDF pkgBSDF.o -lrtrad $(MLIB)
80
81 mgf2rad.o: mgf2rad.c ../common/mgf_parser.h ../common/tmesh.h \
82 ../common/color.h
83 $(CC) $(CFLAGS) -c mgf2rad.c
84
85 mgf2meta.o: mgf2meta.c ../common/mgf_parser.h
86 $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c
87
88 arch2rad.o trans.o: trans.h
89
90 ies2rad.o lampcolor.o: ../common/color.h
91
92 ies2rad.o: ../common/paths.h
93
94 obj2rad.o tmesh2rad.o: ../common/tmesh.h \
95 ../common/standard.h ../common/rtmisc.h ../common/rtio.h \
96 ../common/rtmath.h ../common/rterror.h ../common/mat4.h \
97 ../common/fvect.h
98
99 obj2rad.o: trans.h
100
101 rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \
102 ../common/object.h ../common/color.h ../common/lookup.h
103
104 mgfilt.o: ../common/mgf_parser.h ../common/ccolor.h
105
106 mgf2inv.o: ../common/mgf_parser.h ../common/ccolor.h
107
108 3ds2mgf.o rayopt3ds.o: rayopt3ds.h
109
110 3ds2mgf.o rayopt3ds.o vect3ds.o: vect3ds.h
111
112 pkgBSDF.o: ../common/bsdf.h ../common/fvect.h ../common/ccolor.h \
113 ../common/paths.h
114
115 pabopto2xml.o: ../common/bsdf.h ../common/fvect.h ../common/ccolor.h
