1 |
# RCSid $Id: Rmakefile,v 2.35 2011/02/18 00:40:25 greg Exp $ |
2 |
3 |
# Makefile for conversion programs |
4 |
5 |
6 |
OPT = -O |
7 |
8 |
MACH = -DBSD |
9 |
10 |
CFLAGS = -I../common -L../lib $(OPT) $(MACH) |
11 |
METACFLAGS = -I../meta |
12 |
13 |
CC = cc |
14 |
15 |
MLIB = -lm |
16 |
17 |
INSTDIR = /usr/local/bin |
18 |
19 |
LIBDIR = /usr/local/lib/ray |
20 |
21 |
PROGS = ies2rad nff2rad lampcolor tmesh2rad obj2rad \ |
22 |
mgf2rad rad2mgf mgf2meta mgfilt mgf2inv 3ds2mgf pkgBSDF |
23 |
24 |
LIBFILES = source.cal tilt.cal lamp.tab window.cal |
25 |
26 |
all: $(PROGS) |
27 |
28 |
install: $(PROGS) $(LIBFILES) optics2rad.csh |
29 |
cp $(PROGS) $(INSTDIR) |
30 |
cp optics2rad.csh $(INSTDIR)/optics2rad |
31 |
chmod 755 $(INSTDIR)/optics2rad |
32 |
cd $(LIBDIR) && rm -f $(LIBFILES) |
33 |
cp $(LIBFILES) $(LIBDIR) |
34 |
35 |
clean: |
36 |
set nonomatch; rm -f $(PROGS) *.o core |
37 |
38 |
ies2rad: ies2rad.o |
39 |
$(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad $(MLIB) |
40 |
41 |
arch2rad: arch2rad.o trans.o |
42 |
$(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad |
43 |
44 |
nff2rad: nff2rad.o |
45 |
$(CC) $(CFLAGS) -o nff2rad nff2rad.o |
46 |
47 |
lampcolor: lampcolor.o |
48 |
$(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrtrad |
49 |
50 |
tmesh2rad: tmesh2rad.o |
51 |
$(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrtrad $(MLIB) |
52 |
53 |
obj2rad: obj2rad.o trans.o |
54 |
$(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB) |
55 |
56 |
mgf2rad: mgf2rad.o |
57 |
$(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB) |
58 |
59 |
rad2mgf: rad2mgf.o |
60 |
$(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB) |
61 |
62 |
mgf2meta: mgf2meta.o |
63 |
$(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB) |
64 |
65 |
mgfilt: mgfilt.o |
66 |
$(CC) $(CFLAGS) -o mgfilt mgfilt.o -lmgf -lrtrad $(MLIB) |
67 |
68 |
mgf2inv: mgf2inv.o |
69 |
$(CC) $(CFLAGS) -o mgf2inv mgf2inv.o -lmgf -lrtrad $(MLIB) |
70 |
71 |
3ds2mgf: 3ds2mgf.o rayopt3ds.o vect3ds.o |
72 |
$(CC) $(CFLAGS) -o 3ds2mgf 3ds2mgf.o rayopt3ds.o vect3ds.o \ |
73 |
74 |
75 |
pkgBSDF: pkgBSDF.o |
76 |
$(CC) $(CFLAGS) -o pkgBSDF pkgBSDF.o -lrtrad $(MLIB) |
77 |
78 |
mgf2rad.o: mgf2rad.c ../common/mgf_parser.h ../common/tmesh.h \ |
79 |
../common/color.h |
80 |
$(CC) $(CFLAGS) -c mgf2rad.c |
81 |
82 |
mgf2meta.o: mgf2meta.c ../common/mgf_parser.h |
83 |
$(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c |
84 |
85 |
arch2rad.o trans.o: trans.h |
86 |
87 |
ies2rad.o lampcolor.o: ../common/color.h |
88 |
89 |
ies2rad.o: ../common/paths.h |
90 |
91 |
obj2rad.o tmesh2rad.o: ../common/tmesh.h \ |
92 |
../common/standard.h ../common/rtmisc.h ../common/rtio.h \ |
93 |
../common/rtmath.h ../common/rterror.h ../common/mat4.h \ |
94 |
../common/fvect.h |
95 |
96 |
obj2rad.o: trans.h |
97 |
98 |
rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \ |
99 |
../common/object.h ../common/color.h ../common/lookup.h |
100 |
101 |
mgfilt.o: ../common/mgf_parser.h ../common/ccolor.h |
102 |
103 |
mgf2inv.o: ../common/mgf_parser.h ../common/ccolor.h |
104 |
105 |
3ds2mgf.o rayopt3ds.o: rayopt3ds.h |
106 |
107 |
3ds2mgf.o rayopt3ds.o vect3ds.o: vect3ds.h |
108 |
109 |
pkgBSDF.o: ../common/bsdf.h ../common/fvect.h ../common/ccolor.h \ |
110 |
../common/paths.h |
