root/radiance/ray/src/cv/Rmakefile
Revision: 2.28
Committed: Fri May 19 03:50:13 2006 UTC (17 years, 10 months ago) by greg
1 # RCSid $Id: Rmakefile,v 2.27 2006/03/10 19:40:12 schorsch Exp $
2 #
3 # Makefile for conversion programs
4 #
5
6 OPT = -O
7
8 MACH = -DBSD
9
10 CFLAGS = -I../common -L../lib $(OPT) $(MACH)
11 METACFLAGS = -I../meta
12
13 CC = cc
14
15 MLIB = -lm
16
17 INSTDIR = /usr/local/bin
18
19 LIBDIR = /usr/local/lib/ray
20
21 MGF_LIB = ../lib/libmgf.a
22
23 PROGS = ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \
24 mgf2rad rad2mgf mgf2meta mgfilt mgf2inv
25
26 LIBFILES = source.cal tilt.cal lamp.tab window.cal
27
28 all: $(PROGS)
29
30 install: $(PROGS) $(LIBFILES) optics2rad.csh
31 cp $(PROGS) $(INSTDIR)
32 cp optics2rad.csh $(INSTDIR)/optics2rad
33 chmod 755 $(INSTDIR)/optics2rad
34 cd $(LIBDIR) && rm -f $(LIBFILES)
35 cp $(LIBFILES) $(LIBDIR)
36
37 clean:
38 set nonomatch; rm -f $(PROGS) *.o core
39 cd mgflib ; make clean
40
41 ies2rad: ies2rad.o
42 $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad -lm
43
44 arch2rad: arch2rad.o trans.o
45 $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad
46
47 nff2rad: nff2rad.o
48 $(CC) $(CFLAGS) -o nff2rad nff2rad.o
49
50 lampcolor: lampcolor.o
51 $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrtrad
52
53 tmesh2rad: tmesh2rad.o
54 $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrtrad $(MLIB)
55
56 obj2rad: obj2rad.o trans.o
57 $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB)
58
59 mgf2rad: $(MGF_LIB) mgf2rad.o
60 $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB)
61
62 rad2mgf: rad2mgf.o
63 $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB)
64
65 mgf2meta: $(MGF_LIB) mgf2meta.o
66 $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB)
67
68 mgfilt:
69 cd mgflib ; rm -f mgfilt ; \
70 make mgfilt CC=$(CC) \
71 CFLAGS="$(OPT) $(MACH)" ; \
72 mv mgfilt ..
73
74 mgf2inv:
75 cd mgflib ; rm -f mgf2inv ; \
76 make mgf2inv CC=$(CC) \
77 CFLAGS="$(OPT) $(MACH)" ; \
78 mv mgf2inv ..
79
80 $(MGF_LIB):
81 cd mgflib ; rm -f libmgf.a ; \
82 make libmgf.a CC=$(CC) \
83 CFLAGS="$(OPT) $(MACH)" ; \
84 mv libmgf.a ../../lib
85
86 mgf2rad.o: mgf2rad.c mgflib/parser.h ../common/tmesh.h ../common/color.h
87 $(CC) $(CFLAGS) -c mgf2rad.c
88
89 mgf2meta.o: mgf2meta.c mgflib/parser.h
90 $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c
91
92 arch2rad.o trans.o: trans.h
93
94 ies2rad.o lampcolor.o: ../common/color.h
95
96 ies2rad.o: ../common/paths.h
97
98 obj2rad.o tmesh2rad.o: ../common/tmesh.h \
99 ../common/standard.h ../common/rtmisc.h ../common/rtio.h \
100 ../common/rtmath.h ../common/rterror.h ../common/mat4.h \
101 ../common/fvect.h ../common/tifftypes.h
102
103 obj2rad.o: trans.h
104
105 rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \
106 ../common/object.h ../common/color.h ../common/lookup.h
