root/Development/ray/src/cv/Rmakefile
Revision: 2.26
Committed: Fri Nov 5 03:31:37 2004 UTC (21 years, 2 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1
1 # RCSid $Id: Rmakefile,v 2.25 2004/10/27 23:36:09 greg Exp $
2 #
3 # Makefile for conversion programs
4 #
5
6 OPT = -O
7
8 MACH = -DBSD
9
10 CFLAGS = -I../common -L../lib $(OPT) $(MACH)
11 METACFLAGS = -I../meta
12
13 CC = cc
14
15 MLIB = -lm
16
17 INSTDIR = /usr/local/bin
18
19 LIBDIR = /usr/local/lib/ray
20
21 MGF_LIB = ../lib/libmgf.a
22
23 PROGS = ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \
24 mgf2rad rad2mgf mgf2meta mgfilt mgf2inv
25
26 LIBFILES = source.cal tilt.cal lamp.tab
27
28 all: $(PROGS)
29
30 install: $(PROGS) $(LIBFILES)
31 cp $(PROGS) $(INSTDIR)
32 cd $(LIBDIR) && rm -f $(LIBFILES)
33 cp $(LIBFILES) $(LIBDIR)
34
35 clean:
36 set nonomatch; rm -f $(PROGS) *.o core
37 cd mgflib ; make clean
38
39 ies2rad: ies2rad.o
40 $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrt -lm
41
42 arch2rad: arch2rad.o trans.o
43 $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt
44
45 nff2rad: nff2rad.o
46 $(CC) $(CFLAGS) -o nff2rad nff2rad.o
47
48 lampcolor: lampcolor.o
49 $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrt
50
51 tmesh2rad: tmesh2rad.o
52 $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrt $(MLIB)
53
54 obj2rad: obj2rad.o trans.o
55 $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrt $(MLIB)
56
57 mgf2rad: $(MGF_LIB) mgf2rad.o
58 $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrt $(MLIB)
59
60 rad2mgf: rad2mgf.o
61 $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrt $(MLIB)
62
63 mgf2meta: $(MGF_LIB) mgf2meta.o
64 $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrt $(MLIB)
65
66 mgfilt:
67 cd mgflib ; rm -f mgfilt ; \
68 make mgfilt CC=$(CC) \
69 CFLAGS="$(OPT) $(MACH)" ; \
70 mv mgfilt ..
71
72 mgf2inv:
73 cd mgflib ; rm -f mgf2inv ; \
74 make mgf2inv CC=$(CC) \
75 CFLAGS="$(OPT) $(MACH)" ; \
76 mv mgf2inv ..
77
78 $(MGF_LIB):
79 cd mgflib ; rm -f libmgf.a ; \
80 make libmgf.a CC=$(CC) \
81 CFLAGS="$(OPT) $(MACH)" ; \
82 mv libmgf.a ../../lib
83
84 mgf2rad.o: mgf2rad.c mgflib/parser.h ../common/tmesh.h ../common/color.h
85 $(CC) $(CFLAGS) -c mgf2rad.c
86
87 mgf2meta.o: mgf2meta.c mgflib/parser.h
88 $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c
89
90 arch2rad.o trans.o: trans.h
91
92 ies2rad.o lampcolor.o: ../common/color.h
93
94 ies2rad.o: ../common/paths.h
95
96 obj2rad.o tmesh2rad.o: ../common/tmesh.h \
97 ../common/standard.h ../common/rtmisc.h ../common/rtio.h \
98 ../common/rtmath.h ../common/rterror.h ../common/mat4.h \
99 ../common/fvect.h ../common/tifftypes.h
100
101 obj2rad.o: trans.h
102
103 rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \
104 ../common/object.h ../common/color.h ../common/lookup.h
