1 |
2 |
# SCCSid "$SunId$ LBL" |
3 |
# Makefile for conversion programs |
4 |
5 |
6 |
OPT = -O |
7 |
8 |
MACH = -DBSD |
9 |
10 |
CFLAGS = $(OPT) $(MACH) -I../common -L../lib |
11 |
12 |
CC = cc |
13 |
14 |
MLIB = -lm |
15 |
16 |
INSTDIR = /usr/local/bin |
17 |
18 |
LIBDIR = /usr/local/lib/ray |
19 |
20 |
PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \ |
21 |
mgf2rad rad2mgf mgf2meta mgfilt mgf2inv |
22 |
23 |
LIBFILES = source.cal tilt.cal lamp.tab tmesh.cal |
24 |
25 |
all: $(PROGS) |
26 |
27 |
install: $(PROGS) $(LIBFILES) |
28 |
cp $(PROGS) $(INSTDIR) |
29 |
cd $(LIBDIR) ; rm -f $(LIBFILES) |
30 |
cp $(LIBFILES) $(LIBDIR) |
31 |
32 |
clean: |
33 |
set nonomatch; rm -f $(PROGS) *.o core |
34 |
cd mgflib ; make clean |
35 |
36 |
thf2rad: thf2rad.o |
37 |
$(CC) $(CFLAGS) -o thf2rad thf2rad.o |
38 |
39 |
ies2rad: ies2rad.o |
40 |
$(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrt -lm |
41 |
42 |
arch2rad: arch2rad.o trans.o |
43 |
$(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt |
44 |
45 |
nff2rad: nff2rad.o |
46 |
$(CC) $(CFLAGS) -o nff2rad nff2rad.o |
47 |
48 |
lampcolor: lampcolor.o |
49 |
$(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrt |
50 |
51 |
tmesh2rad: tmesh2rad.o tmesh.o |
52 |
$(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o tmesh.o -lrt $(MLIB) |
53 |
54 |
obj2rad: obj2rad.o trans.o tmesh.o |
55 |
$(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o tmesh.o -lrt $(MLIB) |
56 |
57 |
mgf2rad: MGF_LIB mgf2rad.o tmesh.o |
58 |
$(CC) $(CFLAGS) -o mgf2rad mgf2rad.o tmesh.o -lmgf -lrt $(MLIB) |
59 |
60 |
rad2mgf: rad2mgf.o |
61 |
$(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrt $(MLIB) |
62 |
63 |
mgf2meta: MGF_LIB mgf2meta.o |
64 |
$(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrt $(MLIB) |
65 |
66 |
mgfilt: |
67 |
cd mgflib ; rm -f mgfilt ; \ |
68 |
make mgfilt CC=$(CC) \ |
69 |
CFLAGS="$(OPT) $(MACH) '-DMEM_PTR=char *' -DNOPROTO" ; \ |
70 |
mv mgfilt .. |
71 |
72 |
mgf2inv: |
73 |
cd mgflib ; rm -f mgf2inv ; \ |
74 |
make mgf2inv CC=$(CC) \ |
75 |
76 |
mv mgf2inv .. |
77 |
78 |
MGF_LIB: |
79 |
cd mgflib ; rm -f libmgf.a ; \ |
80 |
make libmgf.a CC=$(CC) \ |
81 |
82 |
cp libmgf.a ../../lib |
83 |
84 |
mgf2rad.o: mgflib/parser.h tmesh.h ../common/color.h |
85 |
$(CC) $(CFLAGS) '-DMEM_PTR=char *' -DNOPROTO -c mgf2rad.c |
86 |
87 |
mgf2meta.o: mgflib/parser.h |
88 |
$(CC) $(CFLAGS) '-DMEM_PTR=char *' -DNOPROTO -c mgf2meta.c |
89 |
90 |
arch2rad.o trans.o: trans.h |
91 |
92 |
ies2rad.o lampcolor.o: ../common/color.h |
93 |
94 |
ies2rad.o: ../common/paths.h |
95 |
96 |
obj2rad.o tmesh2rad.o: tmesh.h \ |
97 |
../common/standard.h ../common/mat4.h ../common/fvect.h |
98 |
99 |
obj2rad.o: trans.h |
100 |
101 |
tmesh.o: tmesh.h ../common/fvect.h |
102 |
103 |
rad2mgf.o: ../common/fvect.h ../common/object.h ../common/color.h \ |
104 |
../common/lookup.h |
