--- ray/src/cv/Rmakefile 1991/03/14 13:55:16 1.4 +++ ray/src/cv/Rmakefile 2024/02/26 23:43:35 2.59 @@ -1,49 +1,180 @@ -# SCCSid "$SunId$ LBL" - +# RCSid $Id: Rmakefile,v 2.59 2024/02/26 23:43:35 greg Exp $ # # Makefile for conversion programs # OPT = -O -MACH = -f68881 /usr/lib/libm.il -DBSD +MACH = -DBSD -CFLAGS = $(OPT) $(MACH) +CFLAGS = -I../common -L../lib $(OPT) $(MACH) +CXXFLAGS = $(CFLAGS) +METACFLAGS = -I../meta -INSTDIR = /lumen/lumen/ray/bin.sun3 +CC = cc +CXX = c++ -LIBDIR = /lumen/lumen/ray/lib +MLIB = -lm -PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor +INSTDIR = /usr/local/bin +LIBDIR = /usr/local/lib/ray + +PROGS = ies2rad nff2rad lampcolor tmesh2rad obj2rad robjutil \ +mgf2rad rad2mgf mgf2meta mgfilt mgf2inv 3ds2mgf bsdfquery checkBSDF \ +pabopto2xyz pabopto2bsdf bsdf2ttree bsdf2klems pkgBSDF epw2wea bsdf2rad + +LIBFILES = source.cal tilt.cal lamp.tab window.cal bsdf2rad.cal + all: $(PROGS) -install: $(PROGS) +install: $(PROGS) $(LIBFILES) optics2rad.csh cp $(PROGS) $(INSTDIR) + cp optics2rad.csh $(INSTDIR)/optics2rad + cp iso2klems.pl $(INSTDIR)/iso2klems + chmod 755 $(INSTDIR)/optics2rad $(INSTDIR)/iso2klems + cd $(LIBDIR) && rm -f $(LIBFILES) + cp $(LIBFILES) $(LIBDIR) clean: - rm -f $(PROGS) *.o core + set nonomatch; rm -f $(PROGS) *.o -thf2rad: thf2rad.o - cc $(CFLAGS) -o thf2rad thf2rad.o +ies2rad: ies2rad.o + $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad $(MLIB) -ies2rad: ies2rad.o lamps.o spec_rgb.o fropen.o rexpr.o - cc $(CFLAGS) -o ies2rad ies2rad.o lamps.o \ -spec_rgb.o fropen.o rexpr.o +arch2rad: arch2rad.o trans.o + $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad -arch2rad: arch2rad.o trans.o savestr.o - cc $(CFLAGS) -o arch2rad arch2rad.o trans.o savestr.o - nff2rad: nff2rad.o - cc $(CFLAGS) -o nff2rad nff2rad.o + $(CC) $(CFLAGS) -o nff2rad nff2rad.o -lampcolor: lampcolor.o lamps.o spec_rgb.o fropen.o rexpr.o - cc $(CFLAGS) -o lampcolor lampcolor.o spec_rgb.o \ -lamps.o fropen.o rexpr.o +lampcolor: lampcolor.o + $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrtrad -fropen.o: fropen.c - cc $(CFLAGS) -DDEFPATH=\":$(LIBDIR)\" -c fropen.c +tmesh2rad: tmesh2rad.o + $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrtrad $(MLIB) +obj2rad: obj2rad.o trans.o + $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB) + +mgf2rad: mgf2rad.o + $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB) + +rad2mgf: rad2mgf.o + $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB) + +mgf2meta: mgf2meta.o + $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB) + +mgfilt: mgfilt.o + $(CC) $(CFLAGS) -o mgfilt mgfilt.o -lmgf -lrtrad $(MLIB) + +mgf2inv: mgf2inv.o + $(CC) $(CFLAGS) -o mgf2inv mgf2inv.o -lmgf -lrtrad $(MLIB) + +3ds2mgf: 3ds2mgf.o rayopt3ds.o vect3ds.o + $(CC) $(CFLAGS) -o 3ds2mgf 3ds2mgf.o rayopt3ds.o vect3ds.o \ +-lmgf -lrtrad $(MLIB) + +pabopto2xyz: pabopto2xyz.o + $(CXX) $(CXXFLAGS) -o pabopto2xyz pabopto2xyz.o \ +-lrtrad $(MLIB) + +pabopto2bsdf: pabopto2bsdf.o bsdfrep.o bsdfrbf.o bsdfmesh.o bsdftrans.o + $(CXX) $(CXXFLAGS) -o pabopto2bsdf pabopto2bsdf.o bsdfrep.o \ +bsdfrbf.o bsdfmesh.o bsdftrans.o -lrtrad $(MLIB) + +pabopto2rad: pabopto2rad.o bsdfrep.o bsdfrbf.o + $(CC) $(CFLAGS) -o pabopto2rad pabopto2rad.o bsdfrep.o \ +bsdfrbf.o -lrtrad $(MLIB) + +pabopto2rad.o: pabopto2bsdf.c bsdfrep.h + $(CC) $(CFLAGS) -c -DTEST_MAIN -o pabopto2rad.o pabopto2bsdf.c + +bsdf2rad: bsdf2rad.o bsdfrep.o bsdfinterp.o + $(CC) $(CFLAGS) -o bsdf2rad bsdf2rad.o bsdfrep.o bsdfinterp.o \ +-lrtrad $(MLIB) + +bsdf2rado: bsdf2rado.o bsdfrep.o bsdfinterp.o + $(CC) $(CFLAGS) -o bsdf2rado bsdf2rado.o bsdfrep.o bsdfinterp.o \ +-lrtrad $(MLIB) + +bsdfquery: bsdfquery.o bsdfrep.o bsdfinterp.o + $(CC) $(CFLAGS) -o bsdfquery bsdfquery.o bsdfrep.o bsdfinterp.o \ +-lrtrad $(MLIB) + +bsdf2ttree: bsdf2ttree.o bsdfrep.o bsdfinterp.o + $(CC) $(CFLAGS) -o bsdf2ttree bsdf2ttree.o bsdfrep.o bsdfinterp.o \ +-lrtrad $(MLIB) + +bsdf2klems: bsdf2klems.o bsdfrep.o bsdfinterp.o + $(CC) $(CFLAGS) -o bsdf2klems bsdf2klems.o bsdfrep.o bsdfinterp.o \ +-lrtrad $(MLIB) + +pkgBSDF: pkgBSDF.o + $(CC) $(CFLAGS) -o pkgBSDF pkgBSDF.o -lrtrad $(MLIB) + +checkBSDF: checkBSDF.o + $(CC) $(CFLAGS) -o checkBSDF checkBSDF.o -lrtrad $(MLIB) + +epw2wea: epw2wea.o + $(CC) $(CFLAGS) -o epw2wea epw2wea.o + +robjutil: robjutil.o + $(CC) $(CFLAGS) -o robjutil robjutil.o \ +-lwfobj -lrtrad $(MLIB) + +mgf2rad.o: mgf2rad.c ../common/mgf_parser.h ../common/tmesh.h \ +../common/color.h + $(CC) $(CFLAGS) -c mgf2rad.c + +mgf2meta.o: mgf2meta.c ../common/mgf_parser.h + $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c + arch2rad.o trans.o: trans.h -ies2rad.o spec_rgb.o: color.h +ies2rad.o lampcolor.o: ../common/color.h + +ies2rad.o: ../common/paths.h + +obj2rad.o tmesh2rad.o: ../common/tmesh.h \ +../common/standard.h ../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/rterror.h ../common/mat4.h \ +../common/fvect.h + +obj2rad.o: trans.h + +rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \ +../common/object.h ../common/color.h ../common/lookup.h + +mgfilt.o: ../common/mgf_parser.h ../common/ccolor.h + +mgf2inv.o: ../common/mgf_parser.h ../common/ccolor.h + +3ds2mgf.o rayopt3ds.o: rayopt3ds.h + +3ds2mgf.o rayopt3ds.o vect3ds.o: vect3ds.h + +checkBSDF.o pkgBSDF.o: ../common/bsdf.h ../common/fvect.h \ +../common/ccolor.h ../common/paths.h + +bsdf2ttree.o bsdfinterp.o bsdfmesh.o bsdfrbf.o bsdfrep.o bsdf2rad.o bsdftrans.o \ +pabopto2bsdf.o: bsdfrep.h ../common/bsdf.h ../common/fvect.h ../common/ccolor.h + +bsdf2ttree.o pabopto2bsdf.o: ../common/platform.h + +bsdfrep.o: ../common/resolu.h ../common/rtio.h + +pabopto2bsdf.o: ../common/resolu.h + +bsdf2rad.o bsdf2ttree.o: ../common/rtprocess.h + +bsdf2klems.o bsdf2ttree.o mgf2meta.o: ../common/random.h ../common/calcomp.h + +bsdftrans.o: transportSimplex.h + +bsdfquery.o: ../common/rtmath.h ../common/rtio.h bsdfrep.h + +checkBSDF.o: ../common/rtio.h ../common/bsdf_m.h ../common/bsdf_t.h + +robjutil.o: ../common/objutil.h
