root/Development/ray/src/cv/Rmakefile
Wed May 21 17:23:07 2025 UTC (6 months, 1 week ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.59: +9 -2 lines
Diff to previous 2.59 , to selected 2.49
feat(bsdfpeaks): Added new utility to find and measure peaks in BSDFs
Mon Feb 26 23:43:35 2024 UTC (21 months ago) by greg
Diff to previous 2.58 , to selected 2.49
chore: Added missing dependency
Tue Mar 8 19:04:56 2022 UTC (3 years, 8 months ago) by greg
Changes since 2.57: +3 -2 lines
Diff to previous 2.57 , to selected 2.49
feat(iso2klems): New script to generate Klems BSDF from simplified measurements
Tue Dec 14 02:33:18 2021 UTC (3 years, 11 months ago) by greg
Changes since 2.56: +9 -4 lines
Diff to previous 2.56 , to selected 2.49
feat(checkBSDF): created new checkBSDF tool to check XML data reciprocity
Mon Mar 30 18:28:35 2020 UTC (5 years, 7 months ago) by greg
Changes since 2.55: +8 -2 lines
Diff to previous 2.55 , to selected 2.49
Thu Jun 7 15:39:36 2018 UTC (7 years, 5 months ago) by greg
Changes since 2.54: +5 -1 lines
Diff to previous 2.54 , to selected 2.49
Resurrected original bsdf2rad utility (optional build)
Thu Apr 13 00:14:36 2017 UTC (8 years, 7 months ago) by greg
Diff to previous 2.53 , to selected 2.49
Added value flushing to bsdfquery and put in standard build
Sun Apr 9 21:39:26 2017 UTC (8 years, 7 months ago) by greg
Diff to previous 2.52 , to selected 2.49
Thu Aug 18 00:52:48 2016 UTC (9 years, 3 months ago) by greg
Changes since 2.51: +3 -1 lines
Diff to previous 2.51 , to selected 2.49
Wed Jul 27 18:05:53 2016 UTC (9 years, 4 months ago) by greg
Changes since 2.50: +6 -2 lines
Diff to previous 2.50 , to selected 2.49
Added pabopto2xyz utility to interpolate CIE-XYZ color values from measurements
Sat Apr 26 15:59:38 2014 UTC (11 years, 7 months ago) by greg
Diff to previous 2.49
Revision 2.49 - (view) (download) (annotate) - [selected]
Thu Mar 27 03:49:14 2014 UTC (11 years, 8 months ago) by greg
Diff to previous 2.48
Minor fixes
Wed Mar 26 22:29:08 2014 UTC (11 years, 8 months ago) by greg
Diff to previous 2.47 , to selected 2.49
Fixed major bug in incident mesh triangulation code
Wed Mar 26 02:52:31 2014 UTC (11 years, 8 months ago) by greg
Changes since 2.46: +9 -5 lines
Diff to previous 2.46 , to selected 2.49
Sat Mar 8 01:05:00 2014 UTC (11 years, 8 months ago) by greg
Changes since 2.45: +3 -1 lines
Diff to previous 2.45 , to selected 2.49
Fixed compiler warnings
Tue Nov 26 17:35:59 2013 UTC (12 years ago) by greg
Changes since 2.44: +3 -1 lines
Diff to previous 2.44 , to selected 2.49
Include random.h for Windows instead of calling drand48
Tue Nov 26 17:33:55 2013 UTC (12 years ago) by greg
Changes since 2.43: +3 -1 lines
Diff to previous 2.43 , to selected 2.49
Thu Nov 21 23:57:28 2013 UTC (12 years ago) by greg
Diff to previous 2.42 , to selected 2.49
Created bsdfquery program for evaluating BSDF representations
Fri Nov 8 23:32:54 2013 UTC (12 years ago) by greg
Diff to previous 2.41 , to selected 2.49
Tue Oct 22 04:29:27 2013 UTC (12 years, 1 month ago) by greg
Changes since 2.40: +12 -1 lines
Diff to previous 2.40 , to selected 2.49
Wed Sep 25 16:52:28 2013 UTC (12 years, 2 months ago) by greg
Changes since 2.39: +5 -2 lines
Diff to previous 2.39 , to selected 2.49
Sun Apr 21 23:01:14 2013 UTC (12 years, 7 months ago) by greg
Changes since 2.38: +6 -2 lines
Diff to previous 2.38 , to selected 2.49
Fri Oct 19 04:14:29 2012 UTC (13 years, 1 month ago) by greg
Changes since 2.37: +16 -5 lines
Diff to previous 2.37 , to selected 2.49
Fri Aug 24 15:20:18 2012 UTC (13 years, 3 months ago) by greg
Changes since 2.36: +7 -2 lines
Diff to previous 2.36 , to selected 2.49
Introducing program for interpolating BSDF data
Thu Jun 23 18:05:18 2011 UTC (14 years, 5 months ago) by greg
Changes since 2.35: +8 -2 lines
Diff to previous 2.35 , to selected 2.49
Created pkgBSDF program
Fri Feb 18 00:40:25 2011 UTC (14 years, 9 months ago) by greg
Changes since 2.34: +23 -31 lines
Diff to previous 2.34 , to selected 2.49
Mon Nov 29 17:22:30 2010 UTC (15 years ago) by greg
Changes since 2.33: +11 -11 lines
Diff to previous 2.33 , to selected 2.49
Modifications to support dmake
Tue Jun 24 02:01:19 2008 UTC (17 years, 5 months ago) by greg
Diff to previous 2.32 , to selected 2.49
Mon Feb 11 15:17:54 2008 UTC (17 years, 9 months ago) by greg
Diff to previous 2.31 , to selected 2.49
Added missing link to math library for ies2rad
Sat Nov 24 00:37:27 2007 UTC (18 years ago) by greg
Diff to previous 2.30 , to selected 2.49
Wed Nov 21 17:52:04 2007 UTC (18 years ago) by greg
Diff to previous 2.29 , to selected 2.49
Sun Nov 4 17:01:34 2007 UTC (18 years ago) by greg
Changes since 2.28: +8 -2 lines
Diff to previous 2.28 , to selected 2.49
Added 3ds2mgf to default builds
Fri May 19 03:50:13 2006 UTC (19 years, 6 months ago) by greg
Diff to previous 2.27 , to selected 2.49
Fri Mar 10 19:40:12 2006 UTC (19 years, 8 months ago) by schorsch
Diff to previous 2.26 , to selected 2.49
Fri Nov 5 03:31:37 2004 UTC (21 years ago) by greg
Diff to previous 2.25 , to selected 2.49
Wed Oct 27 23:36:09 2004 UTC (21 years, 1 month ago) by greg
CVS Tags: rad3R6P1
Diff to previous 2.24 , to selected 2.49
Mon Nov 17 13:20:10 2003 UTC (22 years ago) by schorsch
Diff to previous 2.23 , to selected 2.49
Mon Oct 20 15:10:18 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 2.22 , to selected 2.49
Diff to previous 2.21 , to selected 2.49
Fri Jun 6 19:40:34 2003 UTC (22 years, 5 months ago) by greg
Diff to previous 2.20 , to selected 2.49
Thu Jun 5 17:04:19 2003 UTC (22 years, 5 months ago) by schorsch
Diff to previous 2.19 , to selected 2.49
Mon Mar 10 19:38:19 2003 UTC (22 years, 8 months ago) by greg
Diff to previous 2.18 , to selected 2.49
Sat Feb 22 02:07:23 2003 UTC (22 years, 9 months ago) by greg
Diff to previous 2.17 , to selected 2.49
Fri Sep 4 09:09:58 1998 UTC (27 years, 2 months ago) by gwlarson
Diff to previous 2.16 , to selected 2.49
Tue Jun 16 17:33:40 1998 UTC (27 years, 5 months ago) by gwlarson
Diff to previous 2.15 , to selected 2.49
Fri Jan 19 09:47:34 1996 UTC (29 years, 10 months ago) by greg
Diff to previous 2.14 , to selected 2.49
Mon Oct 16 09:24:48 1995 UTC (30 years, 1 month ago) by greg
Diff to previous 2.13 , to selected 2.49
Tue Apr 25 21:40:23 1995 UTC (30 years, 7 months ago) by greg
Diff to previous 2.12 , to selected 2.49
Tue Apr 4 10:19:17 1995 UTC (30 years, 8 months ago) by greg
Diff to previous 2.11 , to selected 2.49
added mgf2meta program
Mon Dec 12 12:35:46 1994 UTC (30 years, 11 months ago) by greg
Diff to previous 2.10 , to selected 2.49
Thu Jul 7 17:30:45 1994 UTC (31 years, 4 months ago) by greg
Diff to previous 2.9 , to selected 2.49
added rad2mgf program
Thu Jun 23 10:27:54 1994 UTC (31 years, 5 months ago) by greg
Diff to previous 2.8 , to selected 2.49
minor change to clean entry
Wed Jun 22 15:39:49 1994 UTC (31 years, 5 months ago) by greg
Diff to previous 2.7 , to selected 2.49
added mgf2rad program
Wed Jun 22 12:35:56 1994 UTC (31 years, 5 months ago) by greg
Diff to previous 2.6 , to selected 2.49
Wed Apr 13 14:08:53 1994 UTC (31 years, 7 months ago) by greg
Diff to previous 2.5 , to selected 2.49
added mapping file to obj2rad
Tue Apr 12 17:12:58 1994 UTC (31 years, 7 months ago) by greg
Diff to previous 2.4 , to selected 2.49
created obj2rad program
Tue Feb 15 15:59:57 1994 UTC (31 years, 9 months ago) by greg
Diff to previous 2.3 , to selected 2.49
added tmesh2rad program
Tue Sep 8 10:05:15 1992 UTC (33 years, 2 months ago) by greg
Diff to previous 2.2 , to selected 2.49
Wed Jul 1 15:06:36 1992 UTC (33 years, 5 months ago) by greg
Diff to previous 2.1 , to selected 2.49
Tue Nov 12 17:01:56 1991 UTC (34 years ago) by greg
Diff to previous 1.11 , to selected 2.49
Thu Oct 24 10:35:23 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.10 , to selected 2.49
Wed Oct 23 10:45:41 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.9 , to selected 2.49
standardized macro settings
Thu Sep 5 14:11:59 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.8 , to selected 2.49
Thu Aug 22 09:22:50 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.7 , to selected 2.49
moved librt to ../lib
Thu Aug 22 08:48:29 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.6 , to selected 2.49
Mon Jul 15 12:38:50 1991 UTC (34 years, 4 months ago) by greg
Diff to previous 1.5 , to selected 2.49
Thu Apr 11 09:21:18 1991 UTC (34 years, 7 months ago) by greg
Diff to previous 1.4 , to selected 2.49
Thu Mar 14 13:55:16 1991 UTC (34 years, 8 months ago) by greg
Diff to previous 1.3 , to selected 2.49
added lampcolor
Wed Mar 6 10:14:12 1991 UTC (34 years, 9 months ago) by greg
Diff to previous 1.2 , to selected 2.49
Makefile normalization
Fri Dec 14 14:41:19 1990 UTC (34 years, 11 months ago) by greg
Diff to previous 1.1 , to selected 2.49
improved use of lamp data
Tue Dec 11 08:45:45 1990 UTC (34 years, 11 months ago) by greg
Diff to selected 2.49
