--- ray/src/cv/Rmakefile 2011/06/23 18:05:18 2.36 +++ ray/src/cv/Rmakefile 2022/03/08 19:04:56 2.58 @@ -1,4 +1,4 @@ -# RCSid $Id: Rmakefile,v 2.36 2011/06/23 18:05:18 greg Exp $ +# RCSid $Id: Rmakefile,v 2.58 2022/03/08 19:04:56 greg Exp $ # # Makefile for conversion programs # @@ -8,9 +8,11 @@ OPT = -O MACH = -DBSD CFLAGS = -I../common -L../lib $(OPT) $(MACH) +CXXFLAGS = $(CFLAGS) METACFLAGS = -I../meta CC = cc +CXX = c++ MLIB = -lm @@ -18,22 +20,24 @@ INSTDIR = /usr/local/bin LIBDIR = /usr/local/lib/ray -PROGS = ies2rad nff2rad lampcolor tmesh2rad obj2rad \ -mgf2rad rad2mgf mgf2meta mgfilt mgf2inv 3ds2mgf pkgBSDF +PROGS = ies2rad nff2rad lampcolor tmesh2rad obj2rad robjutil \ +mgf2rad rad2mgf mgf2meta mgfilt mgf2inv 3ds2mgf bsdfquery checkBSDF \ +pabopto2xyz pabopto2bsdf bsdf2ttree bsdf2klems pkgBSDF epw2wea bsdf2rad -LIBFILES = source.cal tilt.cal lamp.tab window.cal +LIBFILES = source.cal tilt.cal lamp.tab window.cal bsdf2rad.cal all: $(PROGS) install: $(PROGS) $(LIBFILES) optics2rad.csh cp $(PROGS) $(INSTDIR) cp optics2rad.csh $(INSTDIR)/optics2rad - chmod 755 $(INSTDIR)/optics2rad + cp iso2klems.pl $(INSTDIR)/iso2klems + chmod 755 $(INSTDIR)/optics2rad $(INSTDIR)/iso2klems cd $(LIBDIR) && rm -f $(LIBFILES) cp $(LIBFILES) $(LIBDIR) clean: - set nonomatch; rm -f $(PROGS) *.o core + set nonomatch; rm -f $(PROGS) *.o ies2rad: ies2rad.o $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad $(MLIB) @@ -72,9 +76,54 @@ mgf2inv: mgf2inv.o $(CC) $(CFLAGS) -o 3ds2mgf 3ds2mgf.o rayopt3ds.o vect3ds.o \ -lmgf -lrtrad $(MLIB) +pabopto2xyz: pabopto2xyz.o + $(CXX) $(CXXFLAGS) -o pabopto2xyz pabopto2xyz.o \ +-lrtrad $(MLIB) + +pabopto2bsdf: pabopto2bsdf.o bsdfrep.o bsdfrbf.o bsdfmesh.o bsdftrans.o + $(CXX) $(CXXFLAGS) -o pabopto2bsdf pabopto2bsdf.o bsdfrep.o \ +bsdfrbf.o bsdfmesh.o bsdftrans.o -lrtrad $(MLIB) + +pabopto2rad: pabopto2rad.o bsdfrep.o bsdfrbf.o + $(CC) $(CFLAGS) -o pabopto2rad pabopto2rad.o bsdfrep.o \ +bsdfrbf.o -lrtrad $(MLIB) + +pabopto2rad.o: pabopto2bsdf.c bsdfrep.h + $(CC) $(CFLAGS) -c -DTEST_MAIN -o pabopto2rad.o pabopto2bsdf.c + +bsdf2rad: bsdf2rad.o bsdfrep.o bsdfinterp.o + $(CC) $(CFLAGS) -o bsdf2rad bsdf2rad.o bsdfrep.o bsdfinterp.o \ +-lrtrad $(MLIB) + +bsdf2rado: bsdf2rado.o bsdfrep.o bsdfinterp.o + $(CC) $(CFLAGS) -o bsdf2rado bsdf2rado.o bsdfrep.o bsdfinterp.o \ +-lrtrad $(MLIB) + +bsdfquery: bsdfquery.o bsdfrep.o bsdfinterp.o + $(CC) $(CFLAGS) -o bsdfquery bsdfquery.o bsdfrep.o bsdfinterp.o \ +-lrtrad $(MLIB) + +bsdf2ttree: bsdf2ttree.o bsdfrep.o bsdfinterp.o + $(CC) $(CFLAGS) -o bsdf2ttree bsdf2ttree.o bsdfrep.o bsdfinterp.o \ +-lrtrad $(MLIB) + +bsdf2klems: bsdf2klems.o bsdfrep.o bsdfinterp.o + $(CC) $(CFLAGS) -o bsdf2klems bsdf2klems.o bsdfrep.o bsdfinterp.o \ +-lrtrad $(MLIB) + pkgBSDF: pkgBSDF.o $(CC) $(CFLAGS) -o pkgBSDF pkgBSDF.o -lrtrad $(MLIB) +checkBSDF: checkBSDF.o + $(CC) $(CFLAGS) -o checkBSDF checkBSDF.o -lrtrad $(MLIB) + +epw2wea: epw2wea.o + $(CC) $(CFLAGS) -o epw2wea epw2wea.o + +robjutil: robjutil.o + $(CC) $(CFLAGS) -o robjutil robjutil.o \ +-lwfobj -lrtrad $(MLIB) + mgf2rad.o: mgf2rad.c ../common/mgf_parser.h ../common/tmesh.h \ ../common/color.h $(CC) $(CFLAGS) -c mgf2rad.c @@ -106,5 +155,26 @@ mgf2inv.o: ../common/mgf_parser.h ../common/ccolor.h 3ds2mgf.o rayopt3ds.o vect3ds.o: vect3ds.h -pkgBSDF.o: ../common/bsdf.h ../common/fvect.h ../common/ccolor.h \ -../common/paths.h +checkBSDF.o pkgBSDF.o: ../common/bsdf.h ../common/fvect.h \ +../common/ccolor.h ../common/paths.h + +bsdf2ttree.o bsdfinterp.o bsdfmesh.o bsdfrbf.o bsdfrep.o bsdf2rad.o bsdftrans.o \ +pabopto2bsdf.o: bsdfrep.h ../common/bsdf.h ../common/fvect.h ../common/ccolor.h + +bsdf2ttree.o pabopto2bsdf.o: ../common/platform.h + +bsdfrep.o: ../common/resolu.h ../common/rtio.h + +pabopto2bsdf.o: ../common/resolu.h + +bsdf2rad.o bsdf2ttree.o: ../common/rtprocess.h + +bsdf2klems.o bsdf2ttree.o mgf2meta.o: ../common/random.h + +bsdftrans.o: transportSimplex.h + +bsdfquery.o: ../common/rtmath.h ../common/rtio.h bsdfrep.h + +checkBSDF.o: ../common/rtio.h ../common/bsdf_m.h ../common/bsdf_t.h + +robjutil.o: ../common/objutil.h
