--- ray/src/cv/Rmakefile 1994/07/07 17:30:45 2.10 +++ ray/src/cv/Rmakefile 2011/06/23 18:05:18 2.36 @@ -1,5 +1,5 @@ +# RCSid $Id: Rmakefile,v 2.36 2011/06/23 18:05:18 greg Exp $ # -# SCCSid "$SunId$ LBL" # Makefile for conversion programs # @@ -7,7 +7,8 @@ OPT = -O MACH = -DBSD -CFLAGS = $(OPT) $(MACH) -I../common -L../lib +CFLAGS = -I../common -L../lib $(OPT) $(MACH) +METACFLAGS = -I../meta CC = cc @@ -17,69 +18,93 @@ INSTDIR = /usr/local/bin LIBDIR = /usr/local/lib/ray -PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \ -mgf2rad rad2mgf +PROGS = ies2rad nff2rad lampcolor tmesh2rad obj2rad \ +mgf2rad rad2mgf mgf2meta mgfilt mgf2inv 3ds2mgf pkgBSDF -LIBFILES = source.cal tilt.cal lamp.tab tmesh.cal +LIBFILES = source.cal tilt.cal lamp.tab window.cal all: $(PROGS) -install: $(PROGS) $(LIBFILES) +install: $(PROGS) $(LIBFILES) optics2rad.csh cp $(PROGS) $(INSTDIR) - cd $(LIBDIR) ; rm -f $(LIBFILES) + cp optics2rad.csh $(INSTDIR)/optics2rad + chmod 755 $(INSTDIR)/optics2rad + cd $(LIBDIR) && rm -f $(LIBFILES) cp $(LIBFILES) $(LIBDIR) clean: set nonomatch; rm -f $(PROGS) *.o core - cd mgflib ; make clean -thf2rad: thf2rad.o - $(CC) $(CFLAGS) -o thf2rad thf2rad.o - ies2rad: ies2rad.o - $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrt + $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad $(MLIB) arch2rad: arch2rad.o trans.o - $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt + $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad nff2rad: nff2rad.o $(CC) $(CFLAGS) -o nff2rad nff2rad.o lampcolor: lampcolor.o - $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrt + $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrtrad -tmesh2rad: tmesh2rad.o tmesh.o - $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o tmesh.o -lrt $(MLIB) +tmesh2rad: tmesh2rad.o + $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrtrad $(MLIB) -obj2rad: obj2rad.o trans.o tmesh.o - $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o tmesh.o -lrt $(MLIB) +obj2rad: obj2rad.o trans.o + $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB) -mgf2rad: MGF_LIB mgf2rad.o tmesh.o - $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o tmesh.o -lmgf -lrt $(MLIB) +mgf2rad: mgf2rad.o + $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB) rad2mgf: rad2mgf.o - $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrt $(MLIB) + $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB) -MGF_LIB: - cd mgflib ; \ - make libmgf.a CFLAGS="$(OPT) $(MACH) '-DMEM_PTR=char *' -DNOPROTO" ; \ - cp libmgf.a ../../lib +mgf2meta: mgf2meta.o + $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB) -mgf2rad.o: mgflib/parser.h tmesh.h - $(CC) $(CFLAGS) '-DMEM_PTR=char *' -DNOPROTO -c mgf2rad.c +mgfilt: mgfilt.o + $(CC) $(CFLAGS) -o mgfilt mgfilt.o -lmgf -lrtrad $(MLIB) +mgf2inv: mgf2inv.o + $(CC) $(CFLAGS) -o mgf2inv mgf2inv.o -lmgf -lrtrad $(MLIB) + +3ds2mgf: 3ds2mgf.o rayopt3ds.o vect3ds.o + $(CC) $(CFLAGS) -o 3ds2mgf 3ds2mgf.o rayopt3ds.o vect3ds.o \ +-lmgf -lrtrad $(MLIB) + +pkgBSDF: pkgBSDF.o + $(CC) $(CFLAGS) -o pkgBSDF pkgBSDF.o -lrtrad $(MLIB) + +mgf2rad.o: mgf2rad.c ../common/mgf_parser.h ../common/tmesh.h \ +../common/color.h + $(CC) $(CFLAGS) -c mgf2rad.c + +mgf2meta.o: mgf2meta.c ../common/mgf_parser.h + $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c + arch2rad.o trans.o: trans.h ies2rad.o lampcolor.o: ../common/color.h ies2rad.o: ../common/paths.h -obj2rad.o tmesh2rad.o: tmesh.h \ -../common/standard.h ../common/mat4.h ../common/fvect.h +obj2rad.o tmesh2rad.o: ../common/tmesh.h \ +../common/standard.h ../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/rterror.h ../common/mat4.h \ +../common/fvect.h obj2rad.o: trans.h -tmesh.o: tmesh.h ../common/fvect.h +rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \ +../common/object.h ../common/color.h ../common/lookup.h -rad2mgf.o: ../common/fvect.h ../common/object.h ../common/color.h \ -../common/lookup.h +mgfilt.o: ../common/mgf_parser.h ../common/ccolor.h + +mgf2inv.o: ../common/mgf_parser.h ../common/ccolor.h + +3ds2mgf.o rayopt3ds.o: rayopt3ds.h + +3ds2mgf.o rayopt3ds.o vect3ds.o: vect3ds.h + +pkgBSDF.o: ../common/bsdf.h ../common/fvect.h ../common/ccolor.h \ +../common/paths.h
