--- ray/src/cv/Rmakefile 2006/05/19 03:50:13 2.28 +++ ray/src/cv/Rmakefile 2020/03/30 18:28:35 2.56 @@ -1,4 +1,4 @@ -# RCSid $Id: Rmakefile,v 2.28 2006/05/19 03:50:13 greg Exp $ +# RCSid $Id: Rmakefile,v 2.56 2020/03/30 18:28:35 greg Exp $ # # Makefile for conversion programs # @@ -8,9 +8,11 @@ OPT = -O MACH = -DBSD CFLAGS = -I../common -L../lib $(OPT) $(MACH) +CXXFLAGS = $(CFLAGS) METACFLAGS = -I../meta CC = cc +CXX = c++ MLIB = -lm @@ -18,13 +20,12 @@ INSTDIR = /usr/local/bin LIBDIR = /usr/local/lib/ray -MGF_LIB = ../lib/libmgf.a +PROGS = ies2rad nff2rad lampcolor tmesh2rad obj2rad robjutil \ +mgf2rad rad2mgf mgf2meta mgfilt mgf2inv 3ds2mgf bsdfquery \ +pabopto2xyz pabopto2bsdf bsdf2ttree bsdf2klems pkgBSDF epw2wea bsdf2rad -PROGS = ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \ -mgf2rad rad2mgf mgf2meta mgfilt mgf2inv +LIBFILES = source.cal tilt.cal lamp.tab window.cal bsdf2rad.cal -LIBFILES = source.cal tilt.cal lamp.tab window.cal - all: $(PROGS) install: $(PROGS) $(LIBFILES) optics2rad.csh @@ -35,11 +36,10 @@ install: $(PROGS) $(LIBFILES) optics2rad.csh cp $(LIBFILES) $(LIBDIR) clean: - set nonomatch; rm -f $(PROGS) *.o core - cd mgflib ; make clean + set nonomatch; rm -f $(PROGS) *.o ies2rad: ies2rad.o - $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad -lm + $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad $(MLIB) arch2rad: arch2rad.o trans.o $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad @@ -56,37 +56,75 @@ tmesh2rad: tmesh2rad.o obj2rad: obj2rad.o trans.o $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB) -mgf2rad: $(MGF_LIB) mgf2rad.o +mgf2rad: mgf2rad.o $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB) rad2mgf: rad2mgf.o $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB) -mgf2meta: $(MGF_LIB) mgf2meta.o +mgf2meta: mgf2meta.o $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB) -mgfilt: - cd mgflib ; rm -f mgfilt ; \ - make mgfilt CC=$(CC) \ - CFLAGS="$(OPT) $(MACH)" ; \ - mv mgfilt .. +mgfilt: mgfilt.o + $(CC) $(CFLAGS) -o mgfilt mgfilt.o -lmgf -lrtrad $(MLIB) -mgf2inv: - cd mgflib ; rm -f mgf2inv ; \ - make mgf2inv CC=$(CC) \ - CFLAGS="$(OPT) $(MACH)" ; \ - mv mgf2inv .. +mgf2inv: mgf2inv.o + $(CC) $(CFLAGS) -o mgf2inv mgf2inv.o -lmgf -lrtrad $(MLIB) -$(MGF_LIB): - cd mgflib ; rm -f libmgf.a ; \ - make libmgf.a CC=$(CC) \ - CFLAGS="$(OPT) $(MACH)" ; \ - mv libmgf.a ../../lib +3ds2mgf: 3ds2mgf.o rayopt3ds.o vect3ds.o + $(CC) $(CFLAGS) -o 3ds2mgf 3ds2mgf.o rayopt3ds.o vect3ds.o \ +-lmgf -lrtrad $(MLIB) -mgf2rad.o: mgf2rad.c mgflib/parser.h ../common/tmesh.h ../common/color.h +pabopto2xyz: pabopto2xyz.o + $(CXX) $(CXXFLAGS) -o pabopto2xyz pabopto2xyz.o \ +-lrtrad $(MLIB) + +pabopto2bsdf: pabopto2bsdf.o bsdfrep.o bsdfrbf.o bsdfmesh.o bsdftrans.o + $(CXX) $(CXXFLAGS) -o pabopto2bsdf pabopto2bsdf.o bsdfrep.o \ +bsdfrbf.o bsdfmesh.o bsdftrans.o -lrtrad $(MLIB) + +pabopto2rad: pabopto2rad.o bsdfrep.o bsdfrbf.o + $(CC) $(CFLAGS) -o pabopto2rad pabopto2rad.o bsdfrep.o \ +bsdfrbf.o -lrtrad $(MLIB) + +pabopto2rad.o: pabopto2bsdf.c bsdfrep.h + $(CC) $(CFLAGS) -c -DTEST_MAIN -o pabopto2rad.o pabopto2bsdf.c + +bsdf2rad: bsdf2rad.o bsdfrep.o bsdfinterp.o + $(CC) $(CFLAGS) -o bsdf2rad bsdf2rad.o bsdfrep.o bsdfinterp.o \ +-lrtrad $(MLIB) + +bsdf2rado: bsdf2rado.o bsdfrep.o bsdfinterp.o + $(CC) $(CFLAGS) -o bsdf2rado bsdf2rado.o bsdfrep.o bsdfinterp.o \ +-lrtrad $(MLIB) + +bsdfquery: bsdfquery.o bsdfrep.o bsdfinterp.o + $(CC) $(CFLAGS) -o bsdfquery bsdfquery.o bsdfrep.o bsdfinterp.o \ +-lrtrad $(MLIB) + +bsdf2ttree: bsdf2ttree.o bsdfrep.o bsdfinterp.o + $(CC) $(CFLAGS) -o bsdf2ttree bsdf2ttree.o bsdfrep.o bsdfinterp.o \ +-lrtrad $(MLIB) + +bsdf2klems: bsdf2klems.o bsdfrep.o bsdfinterp.o + $(CC) $(CFLAGS) -o bsdf2klems bsdf2klems.o bsdfrep.o bsdfinterp.o \ +-lrtrad $(MLIB) + +pkgBSDF: pkgBSDF.o + $(CC) $(CFLAGS) -o pkgBSDF pkgBSDF.o -lrtrad $(MLIB) + +epw2wea: epw2wea.o + $(CC) $(CFLAGS) -o epw2wea epw2wea.o + +robjutil: robjutil.o + $(CC) $(CFLAGS) -o robjutil robjutil.o \ +-lwfobj -lrtrad $(MLIB) + +mgf2rad.o: mgf2rad.c ../common/mgf_parser.h ../common/tmesh.h \ +../common/color.h $(CC) $(CFLAGS) -c mgf2rad.c -mgf2meta.o: mgf2meta.c mgflib/parser.h +mgf2meta.o: mgf2meta.c ../common/mgf_parser.h $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c arch2rad.o trans.o: trans.h @@ -98,9 +136,39 @@ ies2rad.o: ../common/paths.h obj2rad.o tmesh2rad.o: ../common/tmesh.h \ ../common/standard.h ../common/rtmisc.h ../common/rtio.h \ ../common/rtmath.h ../common/rterror.h ../common/mat4.h \ -../common/fvect.h ../common/tifftypes.h +../common/fvect.h obj2rad.o: trans.h rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \ ../common/object.h ../common/color.h ../common/lookup.h + +mgfilt.o: ../common/mgf_parser.h ../common/ccolor.h + +mgf2inv.o: ../common/mgf_parser.h ../common/ccolor.h + +3ds2mgf.o rayopt3ds.o: rayopt3ds.h + +3ds2mgf.o rayopt3ds.o vect3ds.o: vect3ds.h + +pkgBSDF.o: ../common/bsdf.h ../common/fvect.h ../common/ccolor.h \ +../common/paths.h + +bsdf2ttree.o bsdfinterp.o bsdfmesh.o bsdfrbf.o bsdfrep.o bsdf2rad.o bsdftrans.o \ +pabopto2bsdf.o: bsdfrep.h ../common/bsdf.h ../common/fvect.h ../common/ccolor.h + +bsdf2ttree.o pabopto2bsdf.o: ../common/platform.h + +bsdfrep.o: ../common/resolu.h ../common/rtio.h + +pabopto2bsdf.o: ../common/resolu.h + +bsdf2rad.o bsdf2ttree.o: ../common/rtprocess.h + +bsdf2klems.o bsdf2ttree.o mgf2meta.o: ../common/random.h + +bsdftrans.o: transportSimplex.h + +bsdfquery.o: ../common/rtmath.h ../common/rtio.h bsdfrep.h + +robjutil.o: ../common/objutil.h
