--- ray/src/cv/Rmakefile 1990/12/11 08:45:45 1.1 +++ ray/src/cv/Rmakefile 2006/03/10 19:40:12 2.27 @@ -1,29 +1,104 @@ -# SCCSid "$SunId$ LBL" - +# RCSid $Id: Rmakefile,v 2.27 2006/03/10 19:40:12 schorsch Exp $ # # Makefile for conversion programs # -CFLAGS = -O +OPT = -O -DESTDIR = /usr/local/ray +MACH = -DBSD -all: $(DESTDIR)/thf2rad $(DESTDIR)/ies2rad $(DESTDIR)/arch2rad \ -$(DESTDIR)/nff2rad +CFLAGS = -I../common -L../lib $(OPT) $(MACH) +METACFLAGS = -I../meta -$(DESTDIR)/thf2rad: thf2rad.o - cc $(CFLAGS) -o $(DESTDIR)/thf2rad thf2rad.o +CC = cc -$(DESTDIR)/ies2rad: ies2rad.o lamps.o spec_rgb.o fropen.o rexpr.o - cc $(CFLAGS) -o $(DESTDIR)/ies2rad ies2rad.o lamps.o \ -spec_rgb.o fropen.o rexpr.o +MLIB = -lm -$(DESTDIR)/arch2rad: arch2rad.o trans.o savestr.o - cc $(CFLAGS) -o $(DESTDIR)/arch2rad arch2rad.o trans.o savestr.o +INSTDIR = /usr/local/bin -$(DESTDIR)/nff2rad: nff2rad.o - cc $(CFLAGS) -o $(DESTDIR)/nff2rad nff2rad.o +LIBDIR = /usr/local/lib/ray +MGF_LIB = ../lib/libmgf.a + +PROGS = ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \ +mgf2rad rad2mgf mgf2meta mgfilt mgf2inv + +LIBFILES = source.cal tilt.cal lamp.tab + +all: $(PROGS) + +install: $(PROGS) $(LIBFILES) + cp $(PROGS) $(INSTDIR) + cd $(LIBDIR) && rm -f $(LIBFILES) + cp $(LIBFILES) $(LIBDIR) + +clean: + set nonomatch; rm -f $(PROGS) *.o core + cd mgflib ; make clean + +ies2rad: ies2rad.o + $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad -lm + +arch2rad: arch2rad.o trans.o + $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad + +nff2rad: nff2rad.o + $(CC) $(CFLAGS) -o nff2rad nff2rad.o + +lampcolor: lampcolor.o + $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrtrad + +tmesh2rad: tmesh2rad.o + $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrtrad $(MLIB) + +obj2rad: obj2rad.o trans.o + $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB) + +mgf2rad: $(MGF_LIB) mgf2rad.o + $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB) + +rad2mgf: rad2mgf.o + $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB) + +mgf2meta: $(MGF_LIB) mgf2meta.o + $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB) + +mgfilt: + cd mgflib ; rm -f mgfilt ; \ + make mgfilt CC=$(CC) \ + CFLAGS="$(OPT) $(MACH)" ; \ + mv mgfilt .. + +mgf2inv: + cd mgflib ; rm -f mgf2inv ; \ + make mgf2inv CC=$(CC) \ + CFLAGS="$(OPT) $(MACH)" ; \ + mv mgf2inv .. + +$(MGF_LIB): + cd mgflib ; rm -f libmgf.a ; \ + make libmgf.a CC=$(CC) \ + CFLAGS="$(OPT) $(MACH)" ; \ + mv libmgf.a ../../lib + +mgf2rad.o: mgf2rad.c mgflib/parser.h ../common/tmesh.h ../common/color.h + $(CC) $(CFLAGS) -c mgf2rad.c + +mgf2meta.o: mgf2meta.c mgflib/parser.h + $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c + arch2rad.o trans.o: trans.h -spec_rgb.o: color.h +ies2rad.o lampcolor.o: ../common/color.h + +ies2rad.o: ../common/paths.h + +obj2rad.o tmesh2rad.o: ../common/tmesh.h \ +../common/standard.h ../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/rterror.h ../common/mat4.h \ +../common/fvect.h ../common/tifftypes.h + +obj2rad.o: trans.h + +rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \ +../common/object.h ../common/color.h ../common/lookup.h
