--- ray/src/cv/Rmakefile 1991/03/06 10:14:12 1.3 +++ ray/src/cv/Rmakefile 2003/06/27 06:53:22 2.22 @@ -1,45 +1,105 @@ -# SCCSid "$SunId$ LBL" - +# RCSid $Id: Rmakefile,v 2.22 2003/06/27 06:53:22 greg Exp $ # # Makefile for conversion programs # OPT = -O -MACH = +MACH = -DBSD -CFLAGS = $(OPT) $(MACH) +CFLAGS = -I../common -L../lib $(OPT) $(MACH) -INSTDIR = ../../bin +CC = cc +MLIB = -lm + +INSTDIR = /usr/local/bin + LIBDIR = /usr/local/lib/ray -PROGS = thf2rad ies2rad arch2rad nff2rad +MGF_LIB = ../lib/libmgf.a +PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \ +mgf2rad rad2mgf mgf2meta mgfilt mgf2inv + +LIBFILES = source.cal tilt.cal lamp.tab + all: $(PROGS) -install: $(PROGS) +install: $(PROGS) $(LIBFILES) cp $(PROGS) $(INSTDIR) + cd $(LIBDIR) ; rm -f $(LIBFILES) + cp $(LIBFILES) $(LIBDIR) clean: - rm -f $(PROGS) *.o core + set nonomatch; rm -f $(PROGS) *.o core + cd mgflib ; make clean thf2rad: thf2rad.o - cc $(CFLAGS) -o thf2rad thf2rad.o + $(CC) $(CFLAGS) -o thf2rad thf2rad.o -ies2rad: ies2rad.o lamps.o spec_rgb.o fropen.o rexpr.o - cc $(CFLAGS) -o ies2rad ies2rad.o lamps.o \ -spec_rgb.o fropen.o rexpr.o +ies2rad: ies2rad.o + $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrt -lm -arch2rad: arch2rad.o trans.o savestr.o - cc $(CFLAGS) -o arch2rad arch2rad.o trans.o savestr.o +arch2rad: arch2rad.o trans.o + $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt nff2rad: nff2rad.o - cc $(CFLAGS) -o nff2rad nff2rad.o + $(CC) $(CFLAGS) -o nff2rad nff2rad.o -fropen.o: fropen.c - cc $(CFLAGS) -DDEFPATH=\":$(LIBDIR)\" -c fropen.c +lampcolor: lampcolor.o + $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrt +tmesh2rad: tmesh2rad.o + $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrt $(MLIB) + +obj2rad: obj2rad.o trans.o + $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrt $(MLIB) + +mgf2rad: $(MGF_LIB) mgf2rad.o + $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrt $(MLIB) + +rad2mgf: rad2mgf.o + $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrt $(MLIB) + +mgf2meta: $(MGF_LIB) mgf2meta.o + $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrt $(MLIB) + +mgfilt: + cd mgflib ; rm -f mgfilt ; \ + make mgfilt CC=$(CC) \ + CFLAGS="$(OPT) $(MACH)" ; \ + mv mgfilt .. + +mgf2inv: + cd mgflib ; rm -f mgf2inv ; \ + make mgf2inv CC=$(CC) \ + CFLAGS="$(OPT) $(MACH)" ; \ + mv mgf2inv .. + +$(MGF_LIB): + cd mgflib ; rm -f libmgf.a ; \ + make libmgf.a CC=$(CC) \ + CFLAGS="$(OPT) $(MACH)" ; \ + mv libmgf.a ../../lib + +mgf2rad.o: mgf2rad.c mgflib/parser.h ../common/tmesh.h ../common/color.h + $(CC) $(CFLAGS) -c mgf2rad.c + +mgf2meta.o: mgf2meta.c mgflib/parser.h + $(CC) $(CFLAGS) -c mgf2meta.c + arch2rad.o trans.o: trans.h -ies2rad.o spec_rgb.o: color.h +ies2rad.o lampcolor.o: ../common/color.h + +ies2rad.o: ../common/paths.h + +obj2rad.o tmesh2rad.o: ../common/tmesh.h \ +../common/standard.h ../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/rterror.h ../common/mat4.h ../common/fvect.h + +obj2rad.o: trans.h + +rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \ +../common/object.h ../common/color.h ../common/lookup.h
