--- ray/src/cv/Rmakefile 1994/06/22 12:35:56 2.7 +++ ray/src/cv/Rmakefile 2003/06/05 17:04:19 2.20 @@ -1,5 +1,4 @@ -# SCCSid "$SunId$ LBL" - +# RCSid $Id: Rmakefile,v 2.20 2003/06/05 17:04:19 schorsch Exp $ # # Makefile for conversion programs # @@ -8,7 +7,7 @@ OPT = -O MACH = -DBSD -CFLAGS = $(OPT) $(MACH) -I../common -L../lib +CFLAGS = -I../common -L../lib $(OPT) $(MACH) CC = cc @@ -18,10 +17,13 @@ INSTDIR = /usr/local/bin LIBDIR = /usr/local/lib/ray -PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad mgf2rad +MGF_LIB = ../lib/libmgf.a -LIBFILES = source.cal tilt.cal lamp.tab tmesh.cal +PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \ +mgf2rad rad2mgf mgf2meta mgfilt mgf2inv +LIBFILES = source.cal tilt.cal lamp.tab + all: $(PROGS) install: $(PROGS) $(LIBFILES) @@ -31,12 +33,13 @@ install: $(PROGS) $(LIBFILES) clean: set nonomatch; rm -f $(PROGS) *.o core + cd mgflib ; make clean thf2rad: thf2rad.o $(CC) $(CFLAGS) -o thf2rad thf2rad.o ies2rad: ies2rad.o - $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrt + $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrt -lm arch2rad: arch2rad.o trans.o $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt @@ -47,31 +50,55 @@ nff2rad: nff2rad.o lampcolor: lampcolor.o $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrt -tmesh2rad: tmesh2rad.o tmesh.o - $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o tmesh.o -lrt $(MLIB) +tmesh2rad: tmesh2rad.o + $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrt $(MLIB) -obj2rad: obj2rad.o trans.o tmesh.o - $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o tmesh.o -lrt $(MLIB) +obj2rad: obj2rad.o trans.o + $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrt $(MLIB) -mgf2rad: mgf2rad.o ../lib/libmgf.a - $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o tmesh.o -lmgf -lrt $(MLIB) +mgf2rad: $(MGF_LIB) mgf2rad.o + $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrt $(MLIB) -../lib/libmgf.a: - cd mgflib ; \ - make libmgf.a CFLAGS="$(OPT) $(MACH) '-DMEM_PTR=char *' -DNOPROTO" ; \ - mv libmgf.a ../../lib +rad2mgf: rad2mgf.o + $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrt $(MLIB) -mgf2rad.o: mgflib/parser.h tmesh.h +mgf2meta: $(MGF_LIB) mgf2meta.o + $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrt $(MLIB) +mgfilt: + cd mgflib ; rm -f mgfilt ; \ + make mgfilt CC=$(CC) \ + CFLAGS="$(OPT) $(MACH) -DNOPROTO" ; \ + mv mgfilt .. + +mgf2inv: + cd mgflib ; rm -f mgf2inv ; \ + make mgf2inv CC=$(CC) \ + CFLAGS="$(OPT) $(MACH) -DNOPROTO" ; \ + mv mgf2inv .. + +$(MGF_LIB): + cd mgflib ; rm -f libmgf.a ; \ + make libmgf.a CC=$(CC) \ + CFLAGS="$(OPT) $(MACH) -DNOPROTO" ; \ + cp libmgf.a ../../lib + +mgf2rad.o: mgf2rad.c mgflib/parser.h ../common/tmesh.h ../common/color.h + $(CC) $(CFLAGS) -DNOPROTO -c mgf2rad.c + +mgf2meta.o: mgf2meta.c mgflib/parser.h + $(CC) $(CFLAGS) -DNOPROTO -c mgf2meta.c + arch2rad.o trans.o: trans.h ies2rad.o lampcolor.o: ../common/color.h ies2rad.o: ../common/paths.h -obj2rad.o tmesh2rad.o: tmesh.h \ +obj2rad.o tmesh2rad.o: ../common/tmesh.h \ ../common/standard.h ../common/mat4.h ../common/fvect.h obj2rad.o: trans.h -tmesh.o: tmesh.h ../common/fvect.h +rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \ +../common/object.h ../common/color.h ../common/lookup.h
