--- ray/src/cv/Rmakefile 1991/11/12 17:01:56 2.1 +++ ray/src/cv/Rmakefile 1996/01/19 09:47:34 2.15 @@ -1,6 +1,5 @@ -# SCCSid "$SunId$ LBL" - # +# SCCSid "$SunId$ LBL" # Makefile for conversion programs # @@ -10,13 +9,18 @@ MACH = -DBSD CFLAGS = $(OPT) $(MACH) -I../common -L../lib +CC = cc + +MLIB = -lm + INSTDIR = /usr/local/bin LIBDIR = /usr/local/lib/ray -PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor +PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \ +mgf2rad rad2mgf mgf2meta mgfilt mgf2inv -LIBFILES = source.cal tilt.cal lamp.tab +LIBFILES = source.cal tilt.cal lamp.tab tmesh.cal all: $(PROGS) @@ -27,22 +31,74 @@ install: $(PROGS) $(LIBFILES) clean: set nonomatch; rm -f $(PROGS) *.o core + cd mgflib ; make clean thf2rad: thf2rad.o - cc $(CFLAGS) -o thf2rad thf2rad.o + $(CC) $(CFLAGS) -o thf2rad thf2rad.o ies2rad: ies2rad.o - cc $(CFLAGS) -o ies2rad ies2rad.o -lrt + $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrt -lm arch2rad: arch2rad.o trans.o - cc $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt + $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt nff2rad: nff2rad.o - cc $(CFLAGS) -o nff2rad nff2rad.o + $(CC) $(CFLAGS) -o nff2rad nff2rad.o lampcolor: lampcolor.o - cc $(CFLAGS) -o lampcolor lampcolor.o -lrt + $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrt +tmesh2rad: tmesh2rad.o tmesh.o + $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o tmesh.o -lrt $(MLIB) + +obj2rad: obj2rad.o trans.o tmesh.o + $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o tmesh.o -lrt $(MLIB) + +mgf2rad: MGF_LIB mgf2rad.o tmesh.o + $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o tmesh.o -lmgf -lrt $(MLIB) + +rad2mgf: rad2mgf.o + $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrt $(MLIB) + +mgf2meta: MGF_LIB mgf2meta.o + $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrt $(MLIB) + +mgfilt: + cd mgflib ; rm -f mgfilt ; \ + make mgfilt CC=$(CC) \ + CFLAGS="$(OPT) $(MACH) '-DMEM_PTR=char *' -DNOPROTO" ; \ + mv mgfilt .. + +mgf2inv: + cd mgflib ; rm -f mgf2inv ; \ + make mgf2inv CC=$(CC) \ + CFLAGS="$(OPT) $(MACH) '-DMEM_PTR=char *' -DNOPROTO" ; \ + mv mgf2inv .. + +MGF_LIB: + cd mgflib ; rm -f libmgf.a ; \ + make libmgf.a CC=$(CC) \ + CFLAGS="$(OPT) $(MACH) '-DMEM_PTR=char *' -DNOPROTO" ; \ + cp libmgf.a ../../lib + +mgf2rad.o: mgflib/parser.h tmesh.h ../common/color.h + $(CC) $(CFLAGS) '-DMEM_PTR=char *' -DNOPROTO -c mgf2rad.c + +mgf2meta.o: mgflib/parser.h + $(CC) $(CFLAGS) '-DMEM_PTR=char *' -DNOPROTO -c mgf2meta.c + arch2rad.o trans.o: trans.h ies2rad.o lampcolor.o: ../common/color.h + +ies2rad.o: ../common/paths.h + +obj2rad.o tmesh2rad.o: tmesh.h \ +../common/standard.h ../common/mat4.h ../common/fvect.h + +obj2rad.o: trans.h + +tmesh.o: tmesh.h ../common/fvect.h + +rad2mgf.o: ../common/fvect.h ../common/object.h ../common/color.h \ +../common/lookup.h
