--- ray/src/cv/Rmakefile 1991/07/15 12:38:50 1.6 +++ ray/src/cv/Rmakefile 1994/12/12 12:35:46 2.11 @@ -1,44 +1,86 @@ -# SCCSid "$SunId$ LBL" - # +# SCCSid "$SunId$ LBL" # Makefile for conversion programs # OPT = -O -MACH = -f68881 /usr/lib/libm.il -DBSD +MACH = -DBSD -CFLAGS = $(OPT) $(MACH) -I../common +CFLAGS = $(OPT) $(MACH) -I../common -L../lib -INSTDIR = /lumen/lumen/ray/bin.sun3 +CC = cc -LIBDIR = /lumen/lumen/ray/lib +MLIB = -lm -PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor +INSTDIR = /usr/local/bin +LIBDIR = /usr/local/lib/ray + +PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \ +mgf2rad rad2mgf + +LIBFILES = source.cal tilt.cal lamp.tab tmesh.cal + all: $(PROGS) -install: $(PROGS) +install: $(PROGS) $(LIBFILES) cp $(PROGS) $(INSTDIR) + cd $(LIBDIR) ; rm -f $(LIBFILES) + cp $(LIBFILES) $(LIBDIR) clean: set nonomatch; rm -f $(PROGS) *.o core + cd mgflib ; make clean thf2rad: thf2rad.o - cc $(CFLAGS) -o thf2rad thf2rad.o + $(CC) $(CFLAGS) -o thf2rad thf2rad.o ies2rad: ies2rad.o - cc $(CFLAGS) -o ies2rad ies2rad.o ../common/librt.a + $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrt arch2rad: arch2rad.o trans.o - cc $(CFLAGS) -o arch2rad arch2rad.o trans.o ../common/librt.a + $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt nff2rad: nff2rad.o - cc $(CFLAGS) -o nff2rad nff2rad.o + $(CC) $(CFLAGS) -o nff2rad nff2rad.o lampcolor: lampcolor.o - cc $(CFLAGS) -o lampcolor lampcolor.o ../common/librt.a + $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrt +tmesh2rad: tmesh2rad.o tmesh.o + $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o tmesh.o -lrt $(MLIB) + +obj2rad: obj2rad.o trans.o tmesh.o + $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o tmesh.o -lrt $(MLIB) + +mgf2rad: MGF_LIB mgf2rad.o tmesh.o + $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o tmesh.o -lmgf -lrt $(MLIB) + +rad2mgf: rad2mgf.o + $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrt $(MLIB) + +MGF_LIB: + cd mgflib ; \ + make libmgf.a CC=$(CC) \ + CFLAGS="$(OPT) $(MACH) '-DMEM_PTR=char *' -DNOPROTO" ; \ + cp libmgf.a ../../lib + +mgf2rad.o: mgflib/parser.h tmesh.h + $(CC) $(CFLAGS) '-DMEM_PTR=char *' -DNOPROTO -c mgf2rad.c + arch2rad.o trans.o: trans.h -ies2rad.o spec_rgb.o: ../common/color.h +ies2rad.o lampcolor.o: ../common/color.h + +ies2rad.o: ../common/paths.h + +obj2rad.o tmesh2rad.o: tmesh.h \ +../common/standard.h ../common/mat4.h ../common/fvect.h + +obj2rad.o: trans.h + +tmesh.o: tmesh.h ../common/fvect.h + +rad2mgf.o: ../common/fvect.h ../common/object.h ../common/color.h \ +../common/lookup.h
