--- ray/src/cv/Rmakefile 1991/03/06 10:14:12 1.3 +++ ray/src/cv/Rmakefile 1991/08/22 09:22:50 1.8 @@ -6,40 +6,41 @@ OPT = -O -MACH = +MACH = -f68881 /usr/lib/libm.il -DBSD -CFLAGS = $(OPT) $(MACH) +CFLAGS = $(OPT) $(MACH) -I../common -L../lib -INSTDIR = ../../bin +INSTDIR = /lumen/lumen/ray/bin.sun3 -LIBDIR = /usr/local/lib/ray +LIBDIR = /lumen/lumen/ray/lib -PROGS = thf2rad ies2rad arch2rad nff2rad +PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor all: $(PROGS) -install: $(PROGS) +install: $(PROGS) source.cal tilt.cal cp $(PROGS) $(INSTDIR) + rm -f $(LIBDIR)/source.cal $(LIBDIR)/tilt.cal + cp source.cal tilt.cal $(LIBDIR) clean: - rm -f $(PROGS) *.o core + set nonomatch; rm -f $(PROGS) *.o core thf2rad: thf2rad.o cc $(CFLAGS) -o thf2rad thf2rad.o -ies2rad: ies2rad.o lamps.o spec_rgb.o fropen.o rexpr.o - cc $(CFLAGS) -o ies2rad ies2rad.o lamps.o \ -spec_rgb.o fropen.o rexpr.o +ies2rad: ies2rad.o + cc $(CFLAGS) -o ies2rad ies2rad.o -lrt -arch2rad: arch2rad.o trans.o savestr.o - cc $(CFLAGS) -o arch2rad arch2rad.o trans.o savestr.o +arch2rad: arch2rad.o trans.o + cc $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt nff2rad: nff2rad.o cc $(CFLAGS) -o nff2rad nff2rad.o -fropen.o: fropen.c - cc $(CFLAGS) -DDEFPATH=\":$(LIBDIR)\" -c fropen.c +lampcolor: lampcolor.o + cc $(CFLAGS) -o lampcolor lampcolor.o -lrt arch2rad.o trans.o: trans.h -ies2rad.o spec_rgb.o: color.h +ies2rad.o spec_rgb.o: ../common/color.h
