--- ray/src/cv/Rmakefile 1991/04/11 09:21:18 1.5 +++ ray/src/cv/Rmakefile 1991/08/22 09:22:50 1.8 @@ -8,7 +8,7 @@ OPT = -O MACH = -f68881 /usr/lib/libm.il -DBSD -CFLAGS = $(OPT) $(MACH) +CFLAGS = $(OPT) $(MACH) -I../common -L../lib INSTDIR = /lumen/lumen/ray/bin.sun3 @@ -18,8 +18,10 @@ PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor all: $(PROGS) -install: $(PROGS) +install: $(PROGS) source.cal tilt.cal cp $(PROGS) $(INSTDIR) + rm -f $(LIBDIR)/source.cal $(LIBDIR)/tilt.cal + cp source.cal tilt.cal $(LIBDIR) clean: set nonomatch; rm -f $(PROGS) *.o core @@ -27,23 +29,18 @@ clean: thf2rad: thf2rad.o cc $(CFLAGS) -o thf2rad thf2rad.o -ies2rad: ies2rad.o lamps.o spec_rgb.o fropen.o rexpr.o - cc $(CFLAGS) -o ies2rad ies2rad.o lamps.o \ -spec_rgb.o fropen.o rexpr.o +ies2rad: ies2rad.o + cc $(CFLAGS) -o ies2rad ies2rad.o -lrt -arch2rad: arch2rad.o trans.o savestr.o - cc $(CFLAGS) -o arch2rad arch2rad.o trans.o savestr.o +arch2rad: arch2rad.o trans.o + cc $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt nff2rad: nff2rad.o cc $(CFLAGS) -o nff2rad nff2rad.o -lampcolor: lampcolor.o lamps.o spec_rgb.o fropen.o rexpr.o - cc $(CFLAGS) -o lampcolor lampcolor.o spec_rgb.o \ -lamps.o fropen.o rexpr.o +lampcolor: lampcolor.o + cc $(CFLAGS) -o lampcolor lampcolor.o -lrt -fropen.o: fropen.c - cc $(CFLAGS) -DDEFPATH=\":$(LIBDIR)\" -c fropen.c - arch2rad.o trans.o: trans.h -ies2rad.o spec_rgb.o: color.h +ies2rad.o spec_rgb.o: ../common/color.h
