--- ray/src/cv/Rmakefile 1990/12/11 08:45:45 1.1 +++ ray/src/cv/Rmakefile 1994/06/23 10:27:54 2.9 @@ -1,29 +1,78 @@ -# SCCSid "$SunId$ LBL" - # +# SCCSid "$SunId$ LBL" # Makefile for conversion programs # -CFLAGS = -O +OPT = -O -DESTDIR = /usr/local/ray +MACH = -DBSD -all: $(DESTDIR)/thf2rad $(DESTDIR)/ies2rad $(DESTDIR)/arch2rad \ -$(DESTDIR)/nff2rad +CFLAGS = $(OPT) $(MACH) -I../common -L../lib -$(DESTDIR)/thf2rad: thf2rad.o - cc $(CFLAGS) -o $(DESTDIR)/thf2rad thf2rad.o +CC = cc -$(DESTDIR)/ies2rad: ies2rad.o lamps.o spec_rgb.o fropen.o rexpr.o - cc $(CFLAGS) -o $(DESTDIR)/ies2rad ies2rad.o lamps.o \ -spec_rgb.o fropen.o rexpr.o +MLIB = -lm -$(DESTDIR)/arch2rad: arch2rad.o trans.o savestr.o - cc $(CFLAGS) -o $(DESTDIR)/arch2rad arch2rad.o trans.o savestr.o +INSTDIR = /usr/local/bin -$(DESTDIR)/nff2rad: nff2rad.o - cc $(CFLAGS) -o $(DESTDIR)/nff2rad nff2rad.o +LIBDIR = /usr/local/lib/ray +PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad mgf2rad + +LIBFILES = source.cal tilt.cal lamp.tab tmesh.cal + +all: $(PROGS) + +install: $(PROGS) $(LIBFILES) + cp $(PROGS) $(INSTDIR) + cd $(LIBDIR) ; rm -f $(LIBFILES) + cp $(LIBFILES) $(LIBDIR) + +clean: + set nonomatch; rm -f $(PROGS) *.o core + cd mgflib ; make clean + +thf2rad: thf2rad.o + $(CC) $(CFLAGS) -o thf2rad thf2rad.o + +ies2rad: ies2rad.o + $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrt + +arch2rad: arch2rad.o trans.o + $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt + +nff2rad: nff2rad.o + $(CC) $(CFLAGS) -o nff2rad nff2rad.o + +lampcolor: lampcolor.o + $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrt + +tmesh2rad: tmesh2rad.o tmesh.o + $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o tmesh.o -lrt $(MLIB) + +obj2rad: obj2rad.o trans.o tmesh.o + $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o tmesh.o -lrt $(MLIB) + +mgf2rad: MGF_LIB mgf2rad.o tmesh.o + $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o tmesh.o -lmgf -lrt $(MLIB) + +MGF_LIB: + cd mgflib ; \ + make libmgf.a CFLAGS="$(OPT) $(MACH) '-DMEM_PTR=char *' -DNOPROTO" ; \ + cp libmgf.a ../../lib + +mgf2rad.o: mgflib/parser.h tmesh.h + $(CC) $(CFLAGS) '-DMEM_PTR=char *' -DNOPROTO -c mgf2rad.c + arch2rad.o trans.o: trans.h -spec_rgb.o: color.h +ies2rad.o lampcolor.o: ../common/color.h + +ies2rad.o: ../common/paths.h + +obj2rad.o tmesh2rad.o: tmesh.h \ +../common/standard.h ../common/mat4.h ../common/fvect.h + +obj2rad.o: trans.h + +tmesh.o: tmesh.h ../common/fvect.h
