| 1 | # |
| 2 | # SCCSid "$SunId$ LBL" |
| 3 | # Makefile for conversion programs |
| 4 | # |
| 5 |  |
| 6 | OPT = -O |
| 7 |  |
| 8 | MACH = -DBSD |
| 9 |  |
| 10 | CFLAGS = $(OPT) $(MACH) -I../common -L../lib |
| 11 |  |
| 12 | CC = cc |
| 13 |  |
| 14 | MLIB = -lm |
| 15 |  |
| 16 | INSTDIR = /usr/local/bin |
| 17 |  |
| 18 | LIBDIR = /usr/local/lib/ray |
| 19 |  |
| 20 | PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \ |
| 21 | mgf2rad rad2mgf mgf2meta mgfilt mgf2inv |
| 22 |  |
| 23 | LIBFILES = source.cal tilt.cal lamp.tab tmesh.cal |
| 24 |  |
| 25 | all:    $(PROGS) |
| 26 |  |
| 27 | install:        $(PROGS) $(LIBFILES) |
| 28 | cp $(PROGS) $(INSTDIR) |
| 29 | cd $(LIBDIR) ; rm -f $(LIBFILES) |
| 30 | cp $(LIBFILES) $(LIBDIR) |
| 31 |  |
| 32 | clean: |
| 33 | set nonomatch; rm -f $(PROGS) *.o core |
| 34 | cd mgflib ; make clean |
| 35 |  |
| 36 | thf2rad:        thf2rad.o |
| 37 | $(CC) $(CFLAGS) -o thf2rad thf2rad.o |
| 38 |  |
| 39 | ies2rad:        ies2rad.o |
| 40 | $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrt -lm |
| 41 |  |
| 42 | arch2rad:       arch2rad.o trans.o |
| 43 | $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt |
| 44 |  |
| 45 | nff2rad:        nff2rad.o |
| 46 | $(CC) $(CFLAGS) -o nff2rad nff2rad.o |
| 47 |  |
| 48 | lampcolor:      lampcolor.o |
| 49 | $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrt |
| 50 |  |
| 51 | tmesh2rad:      tmesh2rad.o tmesh.o |
| 52 | $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o tmesh.o -lrt $(MLIB) |
| 53 |  |
| 54 | obj2rad:        obj2rad.o trans.o tmesh.o |
| 55 | $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o tmesh.o -lrt $(MLIB) |
| 56 |  |
| 57 | mgf2rad:        MGF_LIB mgf2rad.o tmesh.o |
| 58 | $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o tmesh.o -lmgf -lrt $(MLIB) |
| 59 |  |
| 60 | rad2mgf:        rad2mgf.o |
| 61 | $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrt $(MLIB) |
| 62 |  |
| 63 | mgf2meta:       MGF_LIB mgf2meta.o |
| 64 | $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrt $(MLIB) |
| 65 |  |
| 66 | mgfilt: |
| 67 | cd mgflib ; rm -f mgfilt ; \ |
| 68 | make mgfilt CC=$(CC) \ |
| 69 | CFLAGS="$(OPT) $(MACH) '-DMEM_PTR=char *' -DNOPROTO" ; \ |
| 70 | mv mgfilt .. |
| 71 |  |
| 72 | mgf2inv: |
| 73 | cd mgflib ; rm -f mgf2inv ; \ |
| 74 | make mgf2inv CC=$(CC) \ |
| 75 | CFLAGS="$(OPT) $(MACH) '-DMEM_PTR=char *' -DNOPROTO" ; \ |
| 76 | mv mgf2inv .. |
| 77 |  |
| 78 | MGF_LIB: |
| 79 | cd mgflib ; rm -f libmgf.a ; \ |
| 80 | make libmgf.a CC=$(CC) \ |
| 81 | CFLAGS="$(OPT) $(MACH) '-DMEM_PTR=char *' -DNOPROTO" ; \ |
| 82 | cp libmgf.a ../../lib |
| 83 |  |
| 84 | mgf2rad.o:      mgflib/parser.h tmesh.h ../common/color.h |
| 85 | $(CC) $(CFLAGS) '-DMEM_PTR=char *' -DNOPROTO -c mgf2rad.c |
| 86 |  |
| 87 | mgf2meta.o:     mgflib/parser.h |
| 88 | $(CC) $(CFLAGS) '-DMEM_PTR=char *' -DNOPROTO -c mgf2meta.c |
| 89 |  |
| 90 | arch2rad.o trans.o:     trans.h |
| 91 |  |
| 92 | ies2rad.o lampcolor.o:  ../common/color.h |
| 93 |  |
| 94 | ies2rad.o:      ../common/paths.h |
| 95 |  |
| 96 | obj2rad.o tmesh2rad.o:  tmesh.h \ |
| 97 | ../common/standard.h ../common/mat4.h ../common/fvect.h |
| 98 |  |
| 99 | obj2rad.o:      trans.h |
| 100 |  |
| 101 | tmesh.o:        tmesh.h ../common/fvect.h |
| 102 |  |
| 103 | rad2mgf.o:      ../common/fvect.h ../common/object.h ../common/color.h \ |
| 104 | ../common/lookup.h |
