root/radiance/ray/src/cv/Rmakefile
Revision: 2.58
Committed: Tue Mar 8 19:04:56 2022 UTC (3 years, 5 months ago) by greg
Changes since 2.57: +3 -2 lines
feat(iso2klems): New script to generate Klems BSDF from simplified measurements
# User Rev Content
1 greg 2.58 # RCSid $Id: Rmakefile,v 2.57 2021/12/14 02:33:18 greg Exp $
2 greg 2.8 #
3 greg 1.1 # Makefile for conversion programs
4     #
5
6 greg 1.3 OPT = -O
7 greg 1.1
8 greg 1.10 MACH = -DBSD
9 greg 1.1
10 greg 2.18 CFLAGS = -I../common -L../lib $(OPT) $(MACH)
11 greg 2.47 CXXFLAGS = $(CFLAGS)
12 schorsch 2.24 METACFLAGS = -I../meta
13 greg 1.1
14 greg 2.2 CC = cc
15 greg 2.48 CXX = c++
16 greg 2.2
17 greg 2.4 MLIB = -lm
18
19 greg 1.10 INSTDIR = /usr/local/bin
20 greg 1.1
21 greg 1.10 LIBDIR = /usr/local/lib/ray
22 greg 1.3
23 greg 2.56 PROGS = ies2rad nff2rad lampcolor tmesh2rad obj2rad robjutil \
24 greg 2.57 mgf2rad rad2mgf mgf2meta mgfilt mgf2inv 3ds2mgf bsdfquery checkBSDF \
25 greg 2.53 pabopto2xyz pabopto2bsdf bsdf2ttree bsdf2klems pkgBSDF epw2wea bsdf2rad
26 greg 1.3
27 greg 2.53 LIBFILES = source.cal tilt.cal lamp.tab window.cal bsdf2rad.cal
28 greg 1.9
29 greg 1.3 all: $(PROGS)
30
31 greg 2.28 install: $(PROGS) $(LIBFILES) optics2rad.csh
32 greg 1.3 cp $(PROGS) $(INSTDIR)
33 greg 2.28 cp optics2rad.csh $(INSTDIR)/optics2rad
34 greg 2.58 cp iso2klems.pl $(INSTDIR)/iso2klems
35     chmod 755 $(INSTDIR)/optics2rad $(INSTDIR)/iso2klems
36 greg 2.23 cd $(LIBDIR) && rm -f $(LIBFILES)
37 greg 1.9 cp $(LIBFILES) $(LIBDIR)
38 greg 1.3
39     clean:
40 greg 2.50 set nonomatch; rm -f $(PROGS) *.o
41 greg 1.3
42 greg 1.6 ies2rad: ies2rad.o
43 greg 2.32 $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad $(MLIB)
44 greg 1.1
45 greg 1.6 arch2rad: arch2rad.o trans.o
46 schorsch 2.27 $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad
47 greg 1.1
48 greg 1.3 nff2rad: nff2rad.o
49 greg 2.2 $(CC) $(CFLAGS) -o nff2rad nff2rad.o
50 greg 1.4
51 greg 1.6 lampcolor: lampcolor.o
52 schorsch 2.27 $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrtrad
53 greg 1.3
54 greg 2.19 tmesh2rad: tmesh2rad.o
55 schorsch 2.27 $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrtrad $(MLIB)
56 greg 2.5
57 greg 2.19 obj2rad: obj2rad.o trans.o
58 schorsch 2.27 $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB)
59 greg 2.4
60 greg 2.35 mgf2rad: mgf2rad.o
61 schorsch 2.27 $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB)
62 greg 2.7
63 greg 2.10 rad2mgf: rad2mgf.o
64 schorsch 2.27 $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB)
65 greg 2.10
66 greg 2.35 mgf2meta: mgf2meta.o
67 schorsch 2.27 $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB)
68 greg 2.15
69 greg 2.35 mgfilt: mgfilt.o
70     $(CC) $(CFLAGS) -o mgfilt mgfilt.o -lmgf -lrtrad $(MLIB)
71
72     mgf2inv: mgf2inv.o
73     $(CC) $(CFLAGS) -o mgf2inv mgf2inv.o -lmgf -lrtrad $(MLIB)
74 greg 2.7
75 greg 2.35 3ds2mgf: 3ds2mgf.o rayopt3ds.o vect3ds.o
76     $(CC) $(CFLAGS) -o 3ds2mgf 3ds2mgf.o rayopt3ds.o vect3ds.o \
77     -lmgf -lrtrad $(MLIB)
78
79 greg 2.51 pabopto2xyz: pabopto2xyz.o
80     $(CXX) $(CXXFLAGS) -o pabopto2xyz pabopto2xyz.o \
81     -lrtrad $(MLIB)
82
83 greg 2.47 pabopto2bsdf: pabopto2bsdf.o bsdfrep.o bsdfrbf.o bsdfmesh.o bsdftrans.o
84     $(CXX) $(CXXFLAGS) -o pabopto2bsdf pabopto2bsdf.o bsdfrep.o \
85     bsdfrbf.o bsdfmesh.o bsdftrans.o -lrtrad $(MLIB)
86 greg 2.38
87 greg 2.49 pabopto2rad: pabopto2rad.o bsdfrep.o bsdfrbf.o
88 greg 2.41 $(CC) $(CFLAGS) -o pabopto2rad pabopto2rad.o bsdfrep.o \
89 greg 2.49 bsdfrbf.o -lrtrad $(MLIB)
90 greg 2.41
91 greg 2.42 pabopto2rad.o: pabopto2bsdf.c bsdfrep.h
92 greg 2.41 $(CC) $(CFLAGS) -c -DTEST_MAIN -o pabopto2rad.o pabopto2bsdf.c
93
94     bsdf2rad: bsdf2rad.o bsdfrep.o bsdfinterp.o
95     $(CC) $(CFLAGS) -o bsdf2rad bsdf2rad.o bsdfrep.o bsdfinterp.o \
96     -lrtrad $(MLIB)
97
98 greg 2.55 bsdf2rado: bsdf2rado.o bsdfrep.o bsdfinterp.o
99     $(CC) $(CFLAGS) -o bsdf2rado bsdf2rado.o bsdfrep.o bsdfinterp.o \
100     -lrtrad $(MLIB)
101
102 greg 2.43 bsdfquery: bsdfquery.o bsdfrep.o bsdfinterp.o
103     $(CC) $(CFLAGS) -o bsdfquery bsdfquery.o bsdfrep.o bsdfinterp.o \
104     -lrtrad $(MLIB)
105
106 greg 2.38 bsdf2ttree: bsdf2ttree.o bsdfrep.o bsdfinterp.o
107     $(CC) $(CFLAGS) -o bsdf2ttree bsdf2ttree.o bsdfrep.o bsdfinterp.o \
108     -lrtrad $(MLIB)
109 greg 2.37
110 greg 2.39 bsdf2klems: bsdf2klems.o bsdfrep.o bsdfinterp.o
111     $(CC) $(CFLAGS) -o bsdf2klems bsdf2klems.o bsdfrep.o bsdfinterp.o \
112     -lrtrad $(MLIB)
113
114 greg 2.36 pkgBSDF: pkgBSDF.o
115     $(CC) $(CFLAGS) -o pkgBSDF pkgBSDF.o -lrtrad $(MLIB)
116
117 greg 2.57 checkBSDF: checkBSDF.o
118     $(CC) $(CFLAGS) -o checkBSDF checkBSDF.o -lrtrad $(MLIB)
119
120 greg 2.40 epw2wea: epw2wea.o
121     $(CC) $(CFLAGS) -o epw2wea epw2wea.o
122
123 greg 2.56 robjutil: robjutil.o
124     $(CC) $(CFLAGS) -o robjutil robjutil.o \
125     -lwfobj -lrtrad $(MLIB)
126
127 greg 2.35 mgf2rad.o: mgf2rad.c ../common/mgf_parser.h ../common/tmesh.h \
128     ../common/color.h
129 greg 2.21 $(CC) $(CFLAGS) -c mgf2rad.c
130 greg 2.12
131 greg 2.35 mgf2meta.o: mgf2meta.c ../common/mgf_parser.h
132 schorsch 2.24 $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c
133 greg 2.7
134 greg 1.1 arch2rad.o trans.o: trans.h
135
136 greg 1.11 ies2rad.o lampcolor.o: ../common/color.h
137 greg 2.3
138     ies2rad.o: ../common/paths.h
139 greg 2.4
140 greg 2.19 obj2rad.o tmesh2rad.o: ../common/tmesh.h \
141 greg 2.22 ../common/standard.h ../common/rtmisc.h ../common/rtio.h \
142 greg 2.25 ../common/rtmath.h ../common/rterror.h ../common/mat4.h \
143 greg 2.33 ../common/fvect.h
144 greg 2.7
145     obj2rad.o: trans.h
146 greg 2.10
147 gwlarson 2.17 rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \
148     ../common/object.h ../common/color.h ../common/lookup.h
149 greg 2.35
150     mgfilt.o: ../common/mgf_parser.h ../common/ccolor.h
151
152     mgf2inv.o: ../common/mgf_parser.h ../common/ccolor.h
153
154     3ds2mgf.o rayopt3ds.o: rayopt3ds.h
155
156     3ds2mgf.o rayopt3ds.o vect3ds.o: vect3ds.h
157 greg 2.36
158 greg 2.57 checkBSDF.o pkgBSDF.o: ../common/bsdf.h ../common/fvect.h \
159     ../common/ccolor.h ../common/paths.h
160 greg 2.37
161 greg 2.47 bsdf2ttree.o bsdfinterp.o bsdfmesh.o bsdfrbf.o bsdfrep.o bsdf2rad.o bsdftrans.o \
162 greg 2.38 pabopto2bsdf.o: bsdfrep.h ../common/bsdf.h ../common/fvect.h ../common/ccolor.h
163
164     bsdf2ttree.o pabopto2bsdf.o: ../common/platform.h
165
166     bsdfrep.o: ../common/resolu.h ../common/rtio.h
167 greg 2.44
168 greg 2.46 pabopto2bsdf.o: ../common/resolu.h
169
170 greg 2.44 bsdf2rad.o bsdf2ttree.o: ../common/rtprocess.h
171 greg 2.45
172     bsdf2klems.o bsdf2ttree.o mgf2meta.o: ../common/random.h
173 greg 2.47
174     bsdftrans.o: transportSimplex.h
175 greg 2.52
176     bsdfquery.o: ../common/rtmath.h ../common/rtio.h bsdfrep.h
177 greg 2.56
178 greg 2.57 checkBSDF.o: ../common/rtio.h ../common/bsdf_m.h ../common/bsdf_t.h
179
180 greg 2.56 robjutil.o: ../common/objutil.h
