| 1 | # RCSid $Id: Rmakefile,v 2.47 2014/03/26 02:52:31 greg Exp $ |
| 2 | # |
| 3 | # Makefile for conversion programs |
| 4 | # |
| 5 |  |
| 6 | OPT = -O |
| 7 |  |
| 8 | MACH = -DBSD |
| 9 |  |
| 10 | CFLAGS = -I../common -L../lib $(OPT) $(MACH) |
| 11 | CXXFLAGS = $(CFLAGS) |
| 12 | METACFLAGS = -I../meta |
| 13 |  |
| 14 | CC = cc |
| 15 | CXX = c++ |
| 16 |  |
| 17 | MLIB = -lm |
| 18 |  |
| 19 | INSTDIR = /usr/local/bin |
| 20 |  |
| 21 | LIBDIR = /usr/local/lib/ray |
| 22 |  |
| 23 | PROGS = ies2rad nff2rad lampcolor tmesh2rad obj2rad \ |
| 24 | mgf2rad rad2mgf mgf2meta mgfilt mgf2inv 3ds2mgf \ |
| 25 | pabopto2bsdf bsdf2ttree bsdf2klems pkgBSDF epw2wea |
| 26 |  |
| 27 | LIBFILES = source.cal tilt.cal lamp.tab window.cal |
| 28 |  |
| 29 | all:    $(PROGS) |
| 30 |  |
| 31 | install:        $(PROGS) $(LIBFILES) optics2rad.csh |
| 32 | cp $(PROGS) $(INSTDIR) |
| 33 | cp optics2rad.csh $(INSTDIR)/optics2rad |
| 34 | chmod 755 $(INSTDIR)/optics2rad |
| 35 | cd $(LIBDIR) && rm -f $(LIBFILES) |
| 36 | cp $(LIBFILES) $(LIBDIR) |
| 37 |  |
| 38 | clean: |
| 39 | set nonomatch; rm -f $(PROGS) *.o core |
| 40 |  |
| 41 | ies2rad:        ies2rad.o |
| 42 | $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad $(MLIB) |
| 43 |  |
| 44 | arch2rad:       arch2rad.o trans.o |
| 45 | $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad |
| 46 |  |
| 47 | nff2rad:        nff2rad.o |
| 48 | $(CC) $(CFLAGS) -o nff2rad nff2rad.o |
| 49 |  |
| 50 | lampcolor:      lampcolor.o |
| 51 | $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrtrad |
| 52 |  |
| 53 | tmesh2rad:      tmesh2rad.o |
| 54 | $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrtrad $(MLIB) |
| 55 |  |
| 56 | obj2rad:        obj2rad.o trans.o |
| 57 | $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB) |
| 58 |  |
| 59 | mgf2rad:        mgf2rad.o |
| 60 | $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB) |
| 61 |  |
| 62 | rad2mgf:        rad2mgf.o |
| 63 | $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB) |
| 64 |  |
| 65 | mgf2meta:       mgf2meta.o |
| 66 | $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB) |
| 67 |  |
| 68 | mgfilt: mgfilt.o |
| 69 | $(CC) $(CFLAGS) -o mgfilt mgfilt.o -lmgf -lrtrad $(MLIB) |
| 70 |  |
| 71 | mgf2inv:        mgf2inv.o |
| 72 | $(CC) $(CFLAGS) -o mgf2inv mgf2inv.o -lmgf -lrtrad $(MLIB) |
| 73 |  |
| 74 | 3ds2mgf:        3ds2mgf.o rayopt3ds.o vect3ds.o |
| 75 | $(CC) $(CFLAGS) -o 3ds2mgf 3ds2mgf.o rayopt3ds.o vect3ds.o \ |
| 76 | -lmgf -lrtrad $(MLIB) |
| 77 |  |
| 78 | pabopto2bsdf:   pabopto2bsdf.o bsdfrep.o bsdfrbf.o bsdfmesh.o bsdftrans.o |
| 79 | $(CXX) $(CXXFLAGS) -o pabopto2bsdf pabopto2bsdf.o bsdfrep.o \ |
| 80 | bsdfrbf.o bsdfmesh.o bsdftrans.o -lrtrad $(MLIB) |
| 81 |  |
| 82 | pabopto2rad:    pabopto2rad.o bsdfrep.o bsdfrbf.o bsdfmesh.o |
| 83 | $(CC) $(CFLAGS) -o pabopto2rad pabopto2rad.o bsdfrep.o \ |
| 84 | bsdfrbf.o bsdfmesh.o -lrtrad $(MLIB) |
| 85 |  |
| 86 | pabopto2rad.o:  pabopto2bsdf.c bsdfrep.h |
| 87 | $(CC) $(CFLAGS) -c -DTEST_MAIN -o pabopto2rad.o pabopto2bsdf.c |
| 88 |  |
| 89 | bsdf2rad:       bsdf2rad.o bsdfrep.o bsdfinterp.o |
| 90 | $(CC) $(CFLAGS) -o bsdf2rad bsdf2rad.o bsdfrep.o bsdfinterp.o \ |
| 91 | -lrtrad $(MLIB) |
| 92 |  |
| 93 | bsdfquery:      bsdfquery.o bsdfrep.o bsdfinterp.o |
| 94 | $(CC) $(CFLAGS) -o bsdfquery bsdfquery.o bsdfrep.o bsdfinterp.o \ |
| 95 | -lrtrad $(MLIB) |
| 96 |  |
| 97 | bsdf2ttree:     bsdf2ttree.o bsdfrep.o bsdfinterp.o |
| 98 | $(CC) $(CFLAGS) -o bsdf2ttree bsdf2ttree.o bsdfrep.o bsdfinterp.o \ |
| 99 | -lrtrad $(MLIB) |
| 100 |  |
| 101 | bsdf2klems:     bsdf2klems.o bsdfrep.o bsdfinterp.o |
| 102 | $(CC) $(CFLAGS) -o bsdf2klems bsdf2klems.o bsdfrep.o bsdfinterp.o \ |
| 103 | -lrtrad $(MLIB) |
| 104 |  |
| 105 | pkgBSDF:        pkgBSDF.o |
| 106 | $(CC) $(CFLAGS) -o pkgBSDF pkgBSDF.o -lrtrad $(MLIB) |
| 107 |  |
| 108 | epw2wea:        epw2wea.o |
| 109 | $(CC) $(CFLAGS) -o epw2wea epw2wea.o |
| 110 |  |
| 111 | mgf2rad.o:      mgf2rad.c ../common/mgf_parser.h ../common/tmesh.h \ |
| 112 | ../common/color.h |
| 113 | $(CC) $(CFLAGS) -c mgf2rad.c |
| 114 |  |
| 115 | mgf2meta.o:     mgf2meta.c ../common/mgf_parser.h |
| 116 | $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c |
| 117 |  |
| 118 | arch2rad.o trans.o:     trans.h |
| 119 |  |
| 120 | ies2rad.o lampcolor.o:  ../common/color.h |
| 121 |  |
| 122 | ies2rad.o:      ../common/paths.h |
| 123 |  |
| 124 | obj2rad.o tmesh2rad.o:  ../common/tmesh.h \ |
| 125 | ../common/standard.h ../common/rtmisc.h ../common/rtio.h \ |
| 126 | ../common/rtmath.h ../common/rterror.h ../common/mat4.h \ |
| 127 | ../common/fvect.h |
| 128 |  |
| 129 | obj2rad.o:      trans.h |
| 130 |  |
| 131 | rad2mgf.o:      ../common/standard.h ../common/mat4.h ../common/fvect.h \ |
| 132 | ../common/object.h ../common/color.h ../common/lookup.h |
| 133 |  |
| 134 | mgfilt.o:       ../common/mgf_parser.h ../common/ccolor.h |
| 135 |  |
| 136 | mgf2inv.o:      ../common/mgf_parser.h ../common/ccolor.h |
| 137 |  |
| 138 | 3ds2mgf.o rayopt3ds.o:  rayopt3ds.h |
| 139 |  |
| 140 | 3ds2mgf.o rayopt3ds.o vect3ds.o:        vect3ds.h |
| 141 |  |
| 142 | pkgBSDF.o:      ../common/bsdf.h ../common/fvect.h ../common/ccolor.h \ |
| 143 | ../common/paths.h |
| 144 |  |
| 145 | bsdf2ttree.o bsdfinterp.o bsdfmesh.o bsdfrbf.o bsdfrep.o bsdf2rad.o bsdftrans.o \ |
| 146 | pabopto2bsdf.o: bsdfrep.h ../common/bsdf.h ../common/fvect.h ../common/ccolor.h |
| 147 |  |
| 148 | bsdf2ttree.o pabopto2bsdf.o:    ../common/platform.h |
| 149 |  |
| 150 | bsdfrep.o:      ../common/resolu.h ../common/rtio.h |
| 151 |  |
| 152 | pabopto2bsdf.o: ../common/resolu.h |
| 153 |  |
| 154 | bsdf2rad.o bsdf2ttree.o:        ../common/rtprocess.h |
| 155 |  |
| 156 | bsdf2klems.o bsdf2ttree.o mgf2meta.o:   ../common/random.h |
| 157 |  |
| 158 | bsdftrans.o:    transportSimplex.h |
