| 1 |
# RCSid $Id: Rmakefile,v 2.36 2011/06/23 18:05:18 greg Exp $ |
| 2 |
| 3 |
# Makefile for conversion programs |
| 4 |
| 5 |
| 6 |
OPT = -O |
| 7 |
| 8 |
MACH = -DBSD |
| 9 |
| 10 |
CFLAGS = -I../common -L../lib $(OPT) $(MACH) |
| 11 |
METACFLAGS = -I../meta |
| 12 |
| 13 |
CC = cc |
| 14 |
| 15 |
MLIB = -lm |
| 16 |
| 17 |
INSTDIR = /usr/local/bin |
| 18 |
| 19 |
LIBDIR = /usr/local/lib/ray |
| 20 |
| 21 |
PROGS = ies2rad nff2rad lampcolor tmesh2rad obj2rad \ |
| 22 |
mgf2rad rad2mgf mgf2meta mgfilt mgf2inv pabopto2xml pkgBSDF 3ds2mgf |
| 23 |
| 24 |
LIBFILES = source.cal tilt.cal lamp.tab window.cal |
| 25 |
| 26 |
all: $(PROGS) |
| 27 |
| 28 |
install: $(PROGS) $(LIBFILES) optics2rad.csh |
| 29 |
cp $(PROGS) $(INSTDIR) |
| 30 |
cp optics2rad.csh $(INSTDIR)/optics2rad |
| 31 |
chmod 755 $(INSTDIR)/optics2rad |
| 32 |
cd $(LIBDIR) && rm -f $(LIBFILES) |
| 33 |
cp $(LIBFILES) $(LIBDIR) |
| 34 |
| 35 |
clean: |
| 36 |
set nonomatch; rm -f $(PROGS) *.o core |
| 37 |
| 38 |
ies2rad: ies2rad.o |
| 39 |
$(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad $(MLIB) |
| 40 |
| 41 |
arch2rad: arch2rad.o trans.o |
| 42 |
$(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad |
| 43 |
| 44 |
nff2rad: nff2rad.o |
| 45 |
$(CC) $(CFLAGS) -o nff2rad nff2rad.o |
| 46 |
| 47 |
lampcolor: lampcolor.o |
| 48 |
$(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrtrad |
| 49 |
| 50 |
tmesh2rad: tmesh2rad.o |
| 51 |
$(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrtrad $(MLIB) |
| 52 |
| 53 |
obj2rad: obj2rad.o trans.o |
| 54 |
$(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB) |
| 55 |
| 56 |
mgf2rad: mgf2rad.o |
| 57 |
$(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB) |
| 58 |
| 59 |
rad2mgf: rad2mgf.o |
| 60 |
$(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB) |
| 61 |
| 62 |
mgf2meta: mgf2meta.o |
| 63 |
$(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB) |
| 64 |
| 65 |
mgfilt: mgfilt.o |
| 66 |
$(CC) $(CFLAGS) -o mgfilt mgfilt.o -lmgf -lrtrad $(MLIB) |
| 67 |
| 68 |
mgf2inv: mgf2inv.o |
| 69 |
$(CC) $(CFLAGS) -o mgf2inv mgf2inv.o -lmgf -lrtrad $(MLIB) |
| 70 |
| 71 |
3ds2mgf: 3ds2mgf.o rayopt3ds.o vect3ds.o |
| 72 |
$(CC) $(CFLAGS) -o 3ds2mgf 3ds2mgf.o rayopt3ds.o vect3ds.o \ |
| 73 |
| 74 |
| 75 |
pabopto2xml: pabopto2xml.o |
| 76 |
$(CC) $(CFLAGS) -o pabopto2xml pabopto2xml.o -lrtrad $(MLIB) |
| 77 |
| 78 |
pkgBSDF: pkgBSDF.o |
| 79 |
$(CC) $(CFLAGS) -o pkgBSDF pkgBSDF.o -lrtrad $(MLIB) |
| 80 |
| 81 |
mgf2rad.o: mgf2rad.c ../common/mgf_parser.h ../common/tmesh.h \ |
| 82 |
../common/color.h |
| 83 |
$(CC) $(CFLAGS) -c mgf2rad.c |
| 84 |
| 85 |
mgf2meta.o: mgf2meta.c ../common/mgf_parser.h |
| 86 |
$(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c |
| 87 |
| 88 |
arch2rad.o trans.o: trans.h |
| 89 |
| 90 |
ies2rad.o lampcolor.o: ../common/color.h |
| 91 |
| 92 |
ies2rad.o: ../common/paths.h |
| 93 |
| 94 |
obj2rad.o tmesh2rad.o: ../common/tmesh.h \ |
| 95 |
../common/standard.h ../common/rtmisc.h ../common/rtio.h \ |
| 96 |
../common/rtmath.h ../common/rterror.h ../common/mat4.h \ |
| 97 |
../common/fvect.h |
| 98 |
| 99 |
obj2rad.o: trans.h |
| 100 |
| 101 |
rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \ |
| 102 |
../common/object.h ../common/color.h ../common/lookup.h |
| 103 |
| 104 |
mgfilt.o: ../common/mgf_parser.h ../common/ccolor.h |
| 105 |
| 106 |
mgf2inv.o: ../common/mgf_parser.h ../common/ccolor.h |
| 107 |
| 108 |
3ds2mgf.o rayopt3ds.o: rayopt3ds.h |
| 109 |
| 110 |
3ds2mgf.o rayopt3ds.o vect3ds.o: vect3ds.h |
| 111 |
| 112 |
pkgBSDF.o: ../common/bsdf.h ../common/fvect.h ../common/ccolor.h \ |
| 113 |
../common/paths.h |
| 114 |
| 115 |
pabopto2xml.o: ../common/bsdf.h ../common/fvect.h ../common/ccolor.h |
