--- ray/src/cv/Rmakefile 1991/11/12 17:01:56 2.1 +++ ray/src/cv/Rmakefile 2008/02/11 15:17:54 2.32 @@ -1,5 +1,4 @@ -# SCCSid "$SunId$ LBL" - +# RCSid $Id: Rmakefile,v 2.32 2008/02/11 15:17:54 greg Exp $ # # Makefile for conversion programs # @@ -8,41 +7,106 @@ OPT = -O MACH = -DBSD -CFLAGS = $(OPT) $(MACH) -I../common -L../lib +CFLAGS = -I../common -L../lib $(OPT) $(MACH) +METACFLAGS = -I../meta +CC = cc + +MLIB = -lm + INSTDIR = /usr/local/bin LIBDIR = /usr/local/lib/ray -PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor +MGF_LIB = ../lib/libmgf.a -LIBFILES = source.cal tilt.cal lamp.tab +PROGS = ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \ +mgf2rad rad2mgf mgf2meta mgfilt mgf2inv 3ds2mgf +LIBFILES = source.cal tilt.cal lamp.tab window.cal + all: $(PROGS) -install: $(PROGS) $(LIBFILES) +install: $(PROGS) $(LIBFILES) optics2rad.csh cp $(PROGS) $(INSTDIR) - cd $(LIBDIR) ; rm -f $(LIBFILES) + cp optics2rad.csh $(INSTDIR)/optics2rad + chmod 755 $(INSTDIR)/optics2rad + cd $(LIBDIR) && rm -f $(LIBFILES) cp $(LIBFILES) $(LIBDIR) clean: set nonomatch; rm -f $(PROGS) *.o core + cd mgflib ; make clean -thf2rad: thf2rad.o - cc $(CFLAGS) -o thf2rad thf2rad.o - ies2rad: ies2rad.o - cc $(CFLAGS) -o ies2rad ies2rad.o -lrt + $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad $(MLIB) arch2rad: arch2rad.o trans.o - cc $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt + $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad nff2rad: nff2rad.o - cc $(CFLAGS) -o nff2rad nff2rad.o + $(CC) $(CFLAGS) -o nff2rad nff2rad.o lampcolor: lampcolor.o - cc $(CFLAGS) -o lampcolor lampcolor.o -lrt + $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrtrad +tmesh2rad: tmesh2rad.o + $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrtrad $(MLIB) + +obj2rad: obj2rad.o trans.o + $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB) + +mgf2rad: $(MGF_LIB) mgf2rad.o + $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB) + +rad2mgf: rad2mgf.o + $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB) + +mgf2meta: $(MGF_LIB) mgf2meta.o + $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB) + +mgfilt: + cd mgflib ; rm -f mgfilt ; \ + make mgfilt CC="$(CC)" \ + CFLAGS="$(OPT) $(MACH)" ; \ + mv mgfilt .. + +mgf2inv: + cd mgflib ; rm -f mgf2inv ; \ + make mgf2inv CC="$(CC)" \ + CFLAGS="$(OPT) $(MACH)" ; \ + mv mgf2inv .. + +3ds2mgf: + cd mgflib ; rm -f 3ds2mgf ; \ + make 3ds2mgf CC="$(CC)" \ + CFLAGS="$(OPT) $(MACH)" ; \ + mv 3ds2mgf .. + +$(MGF_LIB): + cd mgflib ; rm -f libmgf.a ; \ + make libmgf.a CC="$(CC)" \ + CFLAGS="$(OPT) $(MACH)" ; \ + mv libmgf.a ../../lib + +mgf2rad.o: mgf2rad.c mgflib/parser.h ../common/tmesh.h ../common/color.h + $(CC) $(CFLAGS) -c mgf2rad.c + +mgf2meta.o: mgf2meta.c mgflib/parser.h + $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c + arch2rad.o trans.o: trans.h ies2rad.o lampcolor.o: ../common/color.h + +ies2rad.o: ../common/paths.h + +obj2rad.o tmesh2rad.o: ../common/tmesh.h \ +../common/standard.h ../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/rterror.h ../common/mat4.h \ +../common/fvect.h ../common/tifftypes.h + +obj2rad.o: trans.h + +rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \ +../common/object.h ../common/color.h ../common/lookup.h
