| 1 | # RCSid $Id: Rmakefile,v 2.36 2011/06/23 18:05:18 greg Exp $ |
| 2 | # |
| 3 | # Makefile for conversion programs |
| 4 | # |
| 5 |  |
| 6 | OPT = -O |
| 7 |  |
| 8 | MACH = -DBSD |
| 9 |  |
| 10 | CFLAGS = -I../common -L../lib $(OPT) $(MACH) |
| 11 | METACFLAGS = -I../meta |
| 12 |  |
| 13 | CC = cc |
| 14 |  |
| 15 | MLIB = -lm |
| 16 |  |
| 17 | INSTDIR = /usr/local/bin |
| 18 |  |
| 19 | LIBDIR = /usr/local/lib/ray |
| 20 |  |
| 21 | PROGS = ies2rad nff2rad lampcolor tmesh2rad obj2rad \ |
| 22 | mgf2rad rad2mgf mgf2meta mgfilt mgf2inv pabopto2xml pkgBSDF 3ds2mgf |
| 23 |  |
| 24 | LIBFILES = source.cal tilt.cal lamp.tab window.cal |
| 25 |  |
| 26 | all:    $(PROGS) |
| 27 |  |
| 28 | install:        $(PROGS) $(LIBFILES) optics2rad.csh |
| 29 | cp $(PROGS) $(INSTDIR) |
| 30 | cp optics2rad.csh $(INSTDIR)/optics2rad |
| 31 | chmod 755 $(INSTDIR)/optics2rad |
| 32 | cd $(LIBDIR) && rm -f $(LIBFILES) |
| 33 | cp $(LIBFILES) $(LIBDIR) |
| 34 |  |
| 35 | clean: |
| 36 | set nonomatch; rm -f $(PROGS) *.o core |
| 37 |  |
| 38 | ies2rad:        ies2rad.o |
| 39 | $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad $(MLIB) |
| 40 |  |
| 41 | arch2rad:       arch2rad.o trans.o |
| 42 | $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad |
| 43 |  |
| 44 | nff2rad:        nff2rad.o |
| 45 | $(CC) $(CFLAGS) -o nff2rad nff2rad.o |
| 46 |  |
| 47 | lampcolor:      lampcolor.o |
| 48 | $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrtrad |
| 49 |  |
| 50 | tmesh2rad:      tmesh2rad.o |
| 51 | $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrtrad $(MLIB) |
| 52 |  |
| 53 | obj2rad:        obj2rad.o trans.o |
| 54 | $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB) |
| 55 |  |
| 56 | mgf2rad:        mgf2rad.o |
| 57 | $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB) |
| 58 |  |
| 59 | rad2mgf:        rad2mgf.o |
| 60 | $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB) |
| 61 |  |
| 62 | mgf2meta:       mgf2meta.o |
| 63 | $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB) |
| 64 |  |
| 65 | mgfilt: mgfilt.o |
| 66 | $(CC) $(CFLAGS) -o mgfilt mgfilt.o -lmgf -lrtrad $(MLIB) |
| 67 |  |
| 68 | mgf2inv:        mgf2inv.o |
| 69 | $(CC) $(CFLAGS) -o mgf2inv mgf2inv.o -lmgf -lrtrad $(MLIB) |
| 70 |  |
| 71 | 3ds2mgf:        3ds2mgf.o rayopt3ds.o vect3ds.o |
| 72 | $(CC) $(CFLAGS) -o 3ds2mgf 3ds2mgf.o rayopt3ds.o vect3ds.o \ |
| 73 | -lmgf -lrtrad $(MLIB) |
| 74 |  |
| 75 | pabopto2xml:    pabopto2xml.o |
| 76 | $(CC) $(CFLAGS) -o pabopto2xml pabopto2xml.o -lrtrad $(MLIB) |
| 77 |  |
| 78 | pkgBSDF:        pkgBSDF.o |
| 79 | $(CC) $(CFLAGS) -o pkgBSDF pkgBSDF.o -lrtrad $(MLIB) |
| 80 |  |
| 81 | mgf2rad.o:      mgf2rad.c ../common/mgf_parser.h ../common/tmesh.h \ |
| 82 | ../common/color.h |
| 83 | $(CC) $(CFLAGS) -c mgf2rad.c |
| 84 |  |
| 85 | mgf2meta.o:     mgf2meta.c ../common/mgf_parser.h |
| 86 | $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c |
| 87 |  |
| 88 | arch2rad.o trans.o:     trans.h |
| 89 |  |
| 90 | ies2rad.o lampcolor.o:  ../common/color.h |
| 91 |  |
| 92 | ies2rad.o:      ../common/paths.h |
| 93 |  |
| 94 | obj2rad.o tmesh2rad.o:  ../common/tmesh.h \ |
| 95 | ../common/standard.h ../common/rtmisc.h ../common/rtio.h \ |
| 96 | ../common/rtmath.h ../common/rterror.h ../common/mat4.h \ |
| 97 | ../common/fvect.h |
| 98 |  |
| 99 | obj2rad.o:      trans.h |
| 100 |  |
| 101 | rad2mgf.o:      ../common/standard.h ../common/mat4.h ../common/fvect.h \ |
| 102 | ../common/object.h ../common/color.h ../common/lookup.h |
| 103 |  |
| 104 | mgfilt.o:       ../common/mgf_parser.h ../common/ccolor.h |
| 105 |  |
| 106 | mgf2inv.o:      ../common/mgf_parser.h ../common/ccolor.h |
| 107 |  |
| 108 | 3ds2mgf.o rayopt3ds.o:  rayopt3ds.h |
| 109 |  |
| 110 | 3ds2mgf.o rayopt3ds.o vect3ds.o:        vect3ds.h |
| 111 |  |
| 112 | pkgBSDF.o:      ../common/bsdf.h ../common/fvect.h ../common/ccolor.h \ |
| 113 | ../common/paths.h |
| 114 |  |
| 115 | pabopto2xml.o:  ../common/bsdf.h ../common/fvect.h ../common/ccolor.h |
