--- ray/src/cv/Rmakefile 2003/10/20 15:10:18 2.23 +++ ray/src/cv/Rmakefile 2007/11/21 17:52:04 2.30 @@ -1,4 +1,4 @@ -# RCSid $Id: Rmakefile,v 2.23 2003/10/20 15:10:18 greg Exp $ +# RCSid $Id: Rmakefile,v 2.30 2007/11/21 17:52:04 greg Exp $ # # Makefile for conversion programs # @@ -8,6 +8,7 @@ OPT = -O MACH = -DBSD CFLAGS = -I../common -L../lib $(OPT) $(MACH) +METACFLAGS = -I../meta CC = cc @@ -19,15 +20,17 @@ LIBDIR = /usr/local/lib/ray MGF_LIB = ../lib/libmgf.a -PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \ -mgf2rad rad2mgf mgf2meta mgfilt mgf2inv +PROGS = ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \ +mgf2rad rad2mgf mgf2meta mgfilt mgf2inv 3ds2mgf -LIBFILES = source.cal tilt.cal lamp.tab +LIBFILES = source.cal tilt.cal lamp.tab window.cal all: $(PROGS) -install: $(PROGS) $(LIBFILES) +install: $(PROGS) $(LIBFILES) optics2rad.csh cp $(PROGS) $(INSTDIR) + cp optics2rad.csh $(INSTDIR)/optics2rad + chmod 755 $(INSTDIR)/optics2rad cd $(LIBDIR) && rm -f $(LIBFILES) cp $(LIBFILES) $(LIBDIR) @@ -35,51 +38,54 @@ clean: set nonomatch; rm -f $(PROGS) *.o core cd mgflib ; make clean -thf2rad: thf2rad.o - $(CC) $(CFLAGS) -o thf2rad thf2rad.o - ies2rad: ies2rad.o - $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrt -lm + $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad -lm arch2rad: arch2rad.o trans.o - $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt + $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad nff2rad: nff2rad.o $(CC) $(CFLAGS) -o nff2rad nff2rad.o lampcolor: lampcolor.o - $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrt + $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrtrad tmesh2rad: tmesh2rad.o - $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrt $(MLIB) + $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrtrad $(MLIB) obj2rad: obj2rad.o trans.o - $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrt $(MLIB) + $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB) mgf2rad: $(MGF_LIB) mgf2rad.o - $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrt $(MLIB) + $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB) rad2mgf: rad2mgf.o - $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrt $(MLIB) + $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB) mgf2meta: $(MGF_LIB) mgf2meta.o - $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrt $(MLIB) + $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB) mgfilt: cd mgflib ; rm -f mgfilt ; \ - make mgfilt CC=$(CC) \ + make mgfilt CC="$(CC)" \ CFLAGS="$(OPT) $(MACH)" ; \ mv mgfilt .. mgf2inv: cd mgflib ; rm -f mgf2inv ; \ - make mgf2inv CC=$(CC) \ + make mgf2inv CC="$(CC)" \ CFLAGS="$(OPT) $(MACH)" ; \ mv mgf2inv .. +3ds2mgf: + cd mgflib ; rm -f 3ds2mgf ; \ + make 3ds2mgf CC=$(CC) \ + CFLAGS="$(OPT) $(MACH)" ; \ + mv 3ds2mgf .. + $(MGF_LIB): cd mgflib ; rm -f libmgf.a ; \ - make libmgf.a CC=$(CC) \ + make libmgf.a CC="$(CC)" \ CFLAGS="$(OPT) $(MACH)" ; \ mv libmgf.a ../../lib @@ -87,7 +93,7 @@ mgf2rad.o: mgf2rad.c mgflib/parser.h ../common/tmesh.h $(CC) $(CFLAGS) -c mgf2rad.c mgf2meta.o: mgf2meta.c mgflib/parser.h - $(CC) $(CFLAGS) -c mgf2meta.c + $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c arch2rad.o trans.o: trans.h @@ -97,7 +103,8 @@ ies2rad.o: ../common/paths.h obj2rad.o tmesh2rad.o: ../common/tmesh.h \ ../common/standard.h ../common/rtmisc.h ../common/rtio.h \ -../common/rtmath.h ../common/rterror.h ../common/mat4.h ../common/fvect.h +../common/rtmath.h ../common/rterror.h ../common/mat4.h \ +../common/fvect.h ../common/tifftypes.h obj2rad.o: trans.h
