root/radiance/ray/src/cv/Rmakefile
Revision: 2.50
Committed: Sat Apr 26 15:59:38 2014 UTC (11 years, 3 months ago) by greg
CVS Tags: rad5R0, rad4R2, rad4R2P1, rad4R2P2
# User Rev Content
1 greg 2.50 # RCSid $Id: Rmakefile,v 2.49 2014/03/27 03:49:14 greg Exp $
2 greg 2.8 #
3 greg 1.1 # Makefile for conversion programs
4     #
5
6 greg 1.3 OPT = -O
7 greg 1.1
8 greg 1.10 MACH = -DBSD
9 greg 1.1
10 greg 2.18 CFLAGS = -I../common -L../lib $(OPT) $(MACH)
11 greg 2.47 CXXFLAGS = $(CFLAGS)
12 schorsch 2.24 METACFLAGS = -I../meta
13 greg 1.1
14 greg 2.2 CC = cc
15 greg 2.48 CXX = c++
16 greg 2.2
17 greg 2.4 MLIB = -lm
18
19 greg 1.10 INSTDIR = /usr/local/bin
20 greg 1.1
21 greg 1.10 LIBDIR = /usr/local/lib/ray
22 greg 1.3
23 greg 2.34 PROGS = ies2rad nff2rad lampcolor tmesh2rad obj2rad \
24 greg 2.38 mgf2rad rad2mgf mgf2meta mgfilt mgf2inv 3ds2mgf \
25 greg 2.40 pabopto2bsdf bsdf2ttree bsdf2klems pkgBSDF epw2wea
26 greg 1.3
27 greg 2.28 LIBFILES = source.cal tilt.cal lamp.tab window.cal
28 greg 1.9
29 greg 1.3 all: $(PROGS)
30
31 greg 2.28 install: $(PROGS) $(LIBFILES) optics2rad.csh
32 greg 1.3 cp $(PROGS) $(INSTDIR)
33 greg 2.28 cp optics2rad.csh $(INSTDIR)/optics2rad
34     chmod 755 $(INSTDIR)/optics2rad
35 greg 2.23 cd $(LIBDIR) && rm -f $(LIBFILES)
36 greg 1.9 cp $(LIBFILES) $(LIBDIR)
37 greg 1.3
38     clean:
39 greg 2.50 set nonomatch; rm -f $(PROGS) *.o
40 greg 1.3
41 greg 1.6 ies2rad: ies2rad.o
42 greg 2.32 $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad $(MLIB)
43 greg 1.1
44 greg 1.6 arch2rad: arch2rad.o trans.o
45 schorsch 2.27 $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad
46 greg 1.1
47 greg 1.3 nff2rad: nff2rad.o
48 greg 2.2 $(CC) $(CFLAGS) -o nff2rad nff2rad.o
49 greg 1.4
50 greg 1.6 lampcolor: lampcolor.o
51 schorsch 2.27 $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrtrad
52 greg 1.3
53 greg 2.19 tmesh2rad: tmesh2rad.o
54 schorsch 2.27 $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrtrad $(MLIB)
55 greg 2.5
56 greg 2.19 obj2rad: obj2rad.o trans.o
57 schorsch 2.27 $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB)
58 greg 2.4
59 greg 2.35 mgf2rad: mgf2rad.o
60 schorsch 2.27 $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB)
61 greg 2.7
62 greg 2.10 rad2mgf: rad2mgf.o
63 schorsch 2.27 $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB)
64 greg 2.10
65 greg 2.35 mgf2meta: mgf2meta.o
66 schorsch 2.27 $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB)
67 greg 2.15
68 greg 2.35 mgfilt: mgfilt.o
69     $(CC) $(CFLAGS) -o mgfilt mgfilt.o -lmgf -lrtrad $(MLIB)
70
71     mgf2inv: mgf2inv.o
72     $(CC) $(CFLAGS) -o mgf2inv mgf2inv.o -lmgf -lrtrad $(MLIB)
73 greg 2.7
74 greg 2.35 3ds2mgf: 3ds2mgf.o rayopt3ds.o vect3ds.o
75     $(CC) $(CFLAGS) -o 3ds2mgf 3ds2mgf.o rayopt3ds.o vect3ds.o \
76     -lmgf -lrtrad $(MLIB)
77
78 greg 2.47 pabopto2bsdf: pabopto2bsdf.o bsdfrep.o bsdfrbf.o bsdfmesh.o bsdftrans.o
79     $(CXX) $(CXXFLAGS) -o pabopto2bsdf pabopto2bsdf.o bsdfrep.o \
80     bsdfrbf.o bsdfmesh.o bsdftrans.o -lrtrad $(MLIB)
81 greg 2.38
82 greg 2.49 pabopto2rad: pabopto2rad.o bsdfrep.o bsdfrbf.o
83 greg 2.41 $(CC) $(CFLAGS) -o pabopto2rad pabopto2rad.o bsdfrep.o \
84 greg 2.49 bsdfrbf.o -lrtrad $(MLIB)
85 greg 2.41
86 greg 2.42 pabopto2rad.o: pabopto2bsdf.c bsdfrep.h
87 greg 2.41 $(CC) $(CFLAGS) -c -DTEST_MAIN -o pabopto2rad.o pabopto2bsdf.c
88
89     bsdf2rad: bsdf2rad.o bsdfrep.o bsdfinterp.o
90     $(CC) $(CFLAGS) -o bsdf2rad bsdf2rad.o bsdfrep.o bsdfinterp.o \
91     -lrtrad $(MLIB)
92
93 greg 2.43 bsdfquery: bsdfquery.o bsdfrep.o bsdfinterp.o
94     $(CC) $(CFLAGS) -o bsdfquery bsdfquery.o bsdfrep.o bsdfinterp.o \
95     -lrtrad $(MLIB)
96
97 greg 2.38 bsdf2ttree: bsdf2ttree.o bsdfrep.o bsdfinterp.o
98     $(CC) $(CFLAGS) -o bsdf2ttree bsdf2ttree.o bsdfrep.o bsdfinterp.o \
99     -lrtrad $(MLIB)
100 greg 2.37
101 greg 2.39 bsdf2klems: bsdf2klems.o bsdfrep.o bsdfinterp.o
102     $(CC) $(CFLAGS) -o bsdf2klems bsdf2klems.o bsdfrep.o bsdfinterp.o \
103     -lrtrad $(MLIB)
104
105 greg 2.36 pkgBSDF: pkgBSDF.o
106     $(CC) $(CFLAGS) -o pkgBSDF pkgBSDF.o -lrtrad $(MLIB)
107
108 greg 2.40 epw2wea: epw2wea.o
109     $(CC) $(CFLAGS) -o epw2wea epw2wea.o
110
111 greg 2.35 mgf2rad.o: mgf2rad.c ../common/mgf_parser.h ../common/tmesh.h \
112     ../common/color.h
113 greg 2.21 $(CC) $(CFLAGS) -c mgf2rad.c
114 greg 2.12
115 greg 2.35 mgf2meta.o: mgf2meta.c ../common/mgf_parser.h
116 schorsch 2.24 $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c
117 greg 2.7
118 greg 1.1 arch2rad.o trans.o: trans.h
119
120 greg 1.11 ies2rad.o lampcolor.o: ../common/color.h
121 greg 2.3
122     ies2rad.o: ../common/paths.h
123 greg 2.4
124 greg 2.19 obj2rad.o tmesh2rad.o: ../common/tmesh.h \
125 greg 2.22 ../common/standard.h ../common/rtmisc.h ../common/rtio.h \
126 greg 2.25 ../common/rtmath.h ../common/rterror.h ../common/mat4.h \
127 greg 2.33 ../common/fvect.h
128 greg 2.7
129     obj2rad.o: trans.h
130 greg 2.10
131 gwlarson 2.17 rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \
132     ../common/object.h ../common/color.h ../common/lookup.h
133 greg 2.35
134     mgfilt.o: ../common/mgf_parser.h ../common/ccolor.h
135
136     mgf2inv.o: ../common/mgf_parser.h ../common/ccolor.h
137
138     3ds2mgf.o rayopt3ds.o: rayopt3ds.h
139
140     3ds2mgf.o rayopt3ds.o vect3ds.o: vect3ds.h
141 greg 2.36
142     pkgBSDF.o: ../common/bsdf.h ../common/fvect.h ../common/ccolor.h \
143     ../common/paths.h
144 greg 2.37
145 greg 2.47 bsdf2ttree.o bsdfinterp.o bsdfmesh.o bsdfrbf.o bsdfrep.o bsdf2rad.o bsdftrans.o \
146 greg 2.38 pabopto2bsdf.o: bsdfrep.h ../common/bsdf.h ../common/fvect.h ../common/ccolor.h
147
148     bsdf2ttree.o pabopto2bsdf.o: ../common/platform.h
149
150     bsdfrep.o: ../common/resolu.h ../common/rtio.h
151 greg 2.44
152 greg 2.46 pabopto2bsdf.o: ../common/resolu.h
153
154 greg 2.44 bsdf2rad.o bsdf2ttree.o: ../common/rtprocess.h
155 greg 2.45
156     bsdf2klems.o bsdf2ttree.o mgf2meta.o: ../common/random.h
157 greg 2.47
158     bsdftrans.o: transportSimplex.h
