root/radiance/ray/src/cv/Rmakefile
Thu Jun 23 18:05:18 2011 UTC (12 years, 11 months ago) by greg
Changes since 2.35: +8 -2 lines
Diff to previous 2.35 , to selected 2.31
Created pkgBSDF program
Changes since 2.34: +23 -31 lines
Diff to previous 2.34 , to selected 2.31
Mon Nov 29 17:22:30 2010 UTC (13 years, 6 months ago) by greg
Changes since 2.33: +11 -11 lines
Diff to previous 2.33 , to selected 2.31
Modifications to support dmake
Tue Jun 24 02:01:19 2008 UTC (15 years, 11 months ago) by greg
Diff to previous 2.32 , to selected 2.31
Mon Feb 11 15:17:54 2008 UTC (16 years, 3 months ago) by greg
Diff to previous 2.31
Added missing link to math library for ies2rad
Revision 2.31 - (view) (download) (annotate) - [selected]
Sat Nov 24 00:37:27 2007 UTC (16 years, 6 months ago) by greg
Diff to previous 2.30
Wed Nov 21 17:52:04 2007 UTC (16 years, 6 months ago) by greg
Diff to previous 2.29 , to selected 2.31
Sun Nov 4 17:01:34 2007 UTC (16 years, 7 months ago) by greg
Changes since 2.28: +8 -2 lines
Diff to previous 2.28 , to selected 2.31
Added 3ds2mgf to default builds
Fri May 19 03:50:13 2006 UTC (18 years ago) by greg
Diff to previous 2.27 , to selected 2.31
Fri Mar 10 19:40:12 2006 UTC (18 years, 3 months ago) by schorsch
Diff to previous 2.26 , to selected 2.31
Fri Nov 5 03:31:37 2004 UTC (19 years, 7 months ago) by greg
Diff to previous 2.25 , to selected 2.31
Wed Oct 27 23:36:09 2004 UTC (19 years, 7 months ago) by greg
CVS Tags: rad3R6P1
Diff to previous 2.24 , to selected 2.31
Mon Nov 17 13:20:10 2003 UTC (20 years, 6 months ago) by schorsch
Diff to previous 2.23 , to selected 2.31
Mon Oct 20 15:10:18 2003 UTC (20 years, 7 months ago) by greg
Diff to previous 2.22 , to selected 2.31
Fri Jun 27 06:53:22 2003 UTC (20 years, 11 months ago) by greg
Diff to previous 2.21 , to selected 2.31
Fri Jun 6 19:40:34 2003 UTC (21 years ago) by greg
Diff to previous 2.20 , to selected 2.31
Thu Jun 5 17:04:19 2003 UTC (21 years ago) by schorsch
Diff to previous 2.19 , to selected 2.31
Mon Mar 10 19:38:19 2003 UTC (21 years, 3 months ago) by greg
Diff to previous 2.18 , to selected 2.31
Diff to previous 2.17 , to selected 2.31
Fri Sep 4 09:09:58 1998 UTC (25 years, 9 months ago) by gwlarson
Diff to previous 2.16 , to selected 2.31
Tue Jun 16 17:33:40 1998 UTC (25 years, 11 months ago) by gwlarson
Diff to previous 2.15 , to selected 2.31
Fri Jan 19 09:47:34 1996 UTC (28 years, 4 months ago) by greg
Diff to previous 2.14 , to selected 2.31
Mon Oct 16 09:24:48 1995 UTC (28 years, 7 months ago) by greg
Diff to previous 2.13 , to selected 2.31
Tue Apr 25 21:40:23 1995 UTC (29 years, 1 month ago) by greg
Diff to previous 2.12 , to selected 2.31
Tue Apr 4 10:19:17 1995 UTC (29 years, 2 months ago) by greg
Diff to previous 2.11 , to selected 2.31
added mgf2meta program
Mon Dec 12 12:35:46 1994 UTC (29 years, 6 months ago) by greg
Diff to previous 2.10 , to selected 2.31
Thu Jul 7 17:30:45 1994 UTC (29 years, 11 months ago) by greg
Diff to previous 2.9 , to selected 2.31
added rad2mgf program
Thu Jun 23 10:27:54 1994 UTC (29 years, 11 months ago) by greg
Diff to previous 2.8 , to selected 2.31
minor change to clean entry
Wed Jun 22 15:39:49 1994 UTC (29 years, 11 months ago) by greg
Diff to previous 2.7 , to selected 2.31
added mgf2rad program
Wed Jun 22 12:35:56 1994 UTC (29 years, 11 months ago) by greg
Diff to previous 2.6 , to selected 2.31
Wed Apr 13 14:08:53 1994 UTC (30 years, 2 months ago) by greg
Diff to previous 2.5 , to selected 2.31
added mapping file to obj2rad
Tue Apr 12 17:12:58 1994 UTC (30 years, 2 months ago) by greg
Diff to previous 2.4 , to selected 2.31
created obj2rad program
Tue Feb 15 15:59:57 1994 UTC (30 years, 3 months ago) by greg
Diff to previous 2.3 , to selected 2.31
added tmesh2rad program
Tue Sep 8 10:05:15 1992 UTC (31 years, 9 months ago) by greg
Diff to previous 2.2 , to selected 2.31
Wed Jul 1 15:06:36 1992 UTC (31 years, 11 months ago) by greg
Diff to previous 2.1 , to selected 2.31
Tue Nov 12 17:01:56 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.11 , to selected 2.31
Thu Oct 24 10:35:23 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.10 , to selected 2.31
Wed Oct 23 10:45:41 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.9 , to selected 2.31
standardized macro settings
Thu Sep 5 14:11:59 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.8 , to selected 2.31
Thu Aug 22 09:22:50 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.7 , to selected 2.31
moved librt to ../lib
Thu Aug 22 08:48:29 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.6 , to selected 2.31
Mon Jul 15 12:38:50 1991 UTC (32 years, 11 months ago) by greg
Diff to previous 1.5 , to selected 2.31
Thu Apr 11 09:21:18 1991 UTC (33 years, 2 months ago) by greg
Diff to previous 1.4 , to selected 2.31
Thu Mar 14 13:55:16 1991 UTC (33 years, 3 months ago) by greg
Diff to previous 1.3 , to selected 2.31
added lampcolor
Wed Mar 6 10:14:12 1991 UTC (33 years, 3 months ago) by greg
Diff to previous 1.2 , to selected 2.31
Makefile normalization
Fri Dec 14 14:41:19 1990 UTC (33 years, 6 months ago) by greg
Diff to previous 1.1 , to selected 2.31
improved use of lamp data
Tue Dec 11 08:45:45 1990 UTC (33 years, 6 months ago) by greg
Diff to selected 2.31
