root/radiance/ray/src/cv/Rmakefile
Tue Jun 24 02:01:19 2008 UTC (15 years, 9 months ago) by greg
Diff to previous 2.32 , to selected 2.17
Mon Feb 11 15:17:54 2008 UTC (16 years, 1 month ago) by greg
Diff to previous 2.31 , to selected 2.17
Added missing link to math library for ies2rad
Sat Nov 24 00:37:27 2007 UTC (16 years, 4 months ago) by greg
Diff to previous 2.30 , to selected 2.17
Wed Nov 21 17:52:04 2007 UTC (16 years, 4 months ago) by greg
Diff to previous 2.29 , to selected 2.17
Sun Nov 4 17:01:34 2007 UTC (16 years, 4 months ago) by greg
Changes since 2.28: +8 -2 lines
Diff to previous 2.28 , to selected 2.17
Added 3ds2mgf to default builds
Fri May 19 03:50:13 2006 UTC (17 years, 10 months ago) by greg
Diff to previous 2.27 , to selected 2.17
Fri Mar 10 19:40:12 2006 UTC (18 years ago) by schorsch
Diff to previous 2.26 , to selected 2.17
Fri Nov 5 03:31:37 2004 UTC (19 years, 4 months ago) by greg
Diff to previous 2.25 , to selected 2.17
Wed Oct 27 23:36:09 2004 UTC (19 years, 5 months ago) by greg
CVS Tags: rad3R6P1
Diff to previous 2.24 , to selected 2.17
Mon Nov 17 13:20:10 2003 UTC (20 years, 4 months ago) by schorsch
Diff to previous 2.23 , to selected 2.17
Mon Oct 20 15:10:18 2003 UTC (20 years, 5 months ago) by greg
Diff to previous 2.22 , to selected 2.17
Fri Jun 27 06:53:22 2003 UTC (20 years, 9 months ago) by greg
Diff to previous 2.21 , to selected 2.17
Fri Jun 6 19:40:34 2003 UTC (20 years, 9 months ago) by greg
Diff to previous 2.20 , to selected 2.17
Thu Jun 5 17:04:19 2003 UTC (20 years, 9 months ago) by schorsch
Diff to previous 2.19 , to selected 2.17
Mon Mar 10 19:38:19 2003 UTC (21 years ago) by greg
Diff to previous 2.18 , to selected 2.17
Sat Feb 22 02:07:23 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 2.17
Revision 2.17 - (view) (download) (annotate) - [selected]
Fri Sep 4 09:09:58 1998 UTC (25 years, 6 months ago) by gwlarson
Diff to previous 2.16
Tue Jun 16 17:33:40 1998 UTC (25 years, 9 months ago) by gwlarson
Diff to previous 2.15 , to selected 2.17
Fri Jan 19 09:47:34 1996 UTC (28 years, 2 months ago) by greg
Diff to previous 2.14 , to selected 2.17
Mon Oct 16 09:24:48 1995 UTC (28 years, 5 months ago) by greg
Diff to previous 2.13 , to selected 2.17
Tue Apr 25 21:40:23 1995 UTC (28 years, 11 months ago) by greg
Diff to previous 2.12 , to selected 2.17
Tue Apr 4 10:19:17 1995 UTC (29 years ago) by greg
Diff to previous 2.11 , to selected 2.17
added mgf2meta program
Mon Dec 12 12:35:46 1994 UTC (29 years, 3 months ago) by greg
Diff to previous 2.10 , to selected 2.17
Thu Jul 7 17:30:45 1994 UTC (29 years, 8 months ago) by greg
Diff to previous 2.9 , to selected 2.17
added rad2mgf program
Thu Jun 23 10:27:54 1994 UTC (29 years, 9 months ago) by greg
Diff to previous 2.8 , to selected 2.17
minor change to clean entry
Wed Jun 22 15:39:49 1994 UTC (29 years, 9 months ago) by greg
Diff to previous 2.7 , to selected 2.17
added mgf2rad program
Wed Jun 22 12:35:56 1994 UTC (29 years, 9 months ago) by greg
Diff to previous 2.6 , to selected 2.17
Wed Apr 13 14:08:53 1994 UTC (29 years, 11 months ago) by greg
Diff to previous 2.5 , to selected 2.17
added mapping file to obj2rad
Tue Apr 12 17:12:58 1994 UTC (29 years, 11 months ago) by greg
Diff to previous 2.4 , to selected 2.17
created obj2rad program
Tue Feb 15 15:59:57 1994 UTC (30 years, 1 month ago) by greg
Diff to previous 2.3 , to selected 2.17
added tmesh2rad program
Tue Sep 8 10:05:15 1992 UTC (31 years, 6 months ago) by greg
Diff to previous 2.2 , to selected 2.17
Wed Jul 1 15:06:36 1992 UTC (31 years, 9 months ago) by greg
Diff to previous 2.1 , to selected 2.17
Tue Nov 12 17:01:56 1991 UTC (32 years, 4 months ago) by greg
Diff to previous 1.11 , to selected 2.17
Thu Oct 24 10:35:23 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.10 , to selected 2.17
Wed Oct 23 10:45:41 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.9 , to selected 2.17
standardized macro settings
Thu Sep 5 14:11:59 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.8 , to selected 2.17
Thu Aug 22 09:22:50 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.7 , to selected 2.17
moved librt to ../lib
Thu Aug 22 08:48:29 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.6 , to selected 2.17
Mon Jul 15 12:38:50 1991 UTC (32 years, 8 months ago) by greg
Diff to previous 1.5 , to selected 2.17
Thu Apr 11 09:21:18 1991 UTC (32 years, 11 months ago) by greg
Diff to previous 1.4 , to selected 2.17
Thu Mar 14 13:55:16 1991 UTC (33 years ago) by greg
Diff to previous 1.3 , to selected 2.17
added lampcolor
Wed Mar 6 10:14:12 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.2 , to selected 2.17
Makefile normalization
Fri Dec 14 14:41:19 1990 UTC (33 years, 3 months ago) by greg
Diff to previous 1.1 , to selected 2.17
improved use of lamp data
Tue Dec 11 08:45:45 1990 UTC (33 years, 3 months ago) by greg
Diff to selected 2.17
