--- ray/src/cv/Rmakefile 1990/12/14 14:41:19 1.2 +++ ray/src/cv/Rmakefile 1991/08/22 09:22:50 1.8 @@ -4,26 +4,43 @@ # Makefile for conversion programs # -CFLAGS = -O +OPT = -O -DESTDIR = /usr/local/ray +MACH = -f68881 /usr/lib/libm.il -DBSD -all: $(DESTDIR)/thf2rad $(DESTDIR)/ies2rad $(DESTDIR)/arch2rad \ -$(DESTDIR)/nff2rad +CFLAGS = $(OPT) $(MACH) -I../common -L../lib -$(DESTDIR)/thf2rad: thf2rad.o - cc $(CFLAGS) -o $(DESTDIR)/thf2rad thf2rad.o +INSTDIR = /lumen/lumen/ray/bin.sun3 -$(DESTDIR)/ies2rad: ies2rad.o lamps.o spec_rgb.o fropen.o rexpr.o - cc $(CFLAGS) -o $(DESTDIR)/ies2rad ies2rad.o lamps.o \ -spec_rgb.o fropen.o rexpr.o +LIBDIR = /lumen/lumen/ray/lib -$(DESTDIR)/arch2rad: arch2rad.o trans.o savestr.o - cc $(CFLAGS) -o $(DESTDIR)/arch2rad arch2rad.o trans.o savestr.o +PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor -$(DESTDIR)/nff2rad: nff2rad.o - cc $(CFLAGS) -o $(DESTDIR)/nff2rad nff2rad.o +all: $(PROGS) +install: $(PROGS) source.cal tilt.cal + cp $(PROGS) $(INSTDIR) + rm -f $(LIBDIR)/source.cal $(LIBDIR)/tilt.cal + cp source.cal tilt.cal $(LIBDIR) + +clean: + set nonomatch; rm -f $(PROGS) *.o core + +thf2rad: thf2rad.o + cc $(CFLAGS) -o thf2rad thf2rad.o + +ies2rad: ies2rad.o + cc $(CFLAGS) -o ies2rad ies2rad.o -lrt + +arch2rad: arch2rad.o trans.o + cc $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt + +nff2rad: nff2rad.o + cc $(CFLAGS) -o nff2rad nff2rad.o + +lampcolor: lampcolor.o + cc $(CFLAGS) -o lampcolor lampcolor.o -lrt + arch2rad.o trans.o: trans.h -ies2rad.o spec_rgb.o: color.h +ies2rad.o spec_rgb.o: ../common/color.h
