--- ray/src/cv/Rmakefile 1995/04/25 21:40:23 2.13 +++ ray/src/cv/Rmakefile 2003/02/22 02:07:23 2.18 @@ -1,5 +1,5 @@ +# RCSid: $Id: Rmakefile,v 2.18 2003/02/22 02:07:23 greg Exp $ # -# SCCSid "$SunId$ LBL" # Makefile for conversion programs # @@ -7,7 +7,7 @@ OPT = -O MACH = -DBSD -CFLAGS = $(OPT) $(MACH) -I../common -L../lib +CFLAGS = -I../common -L../lib $(OPT) $(MACH) CC = cc @@ -18,7 +18,7 @@ INSTDIR = /usr/local/bin LIBDIR = /usr/local/lib/ray PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \ -mgf2rad rad2mgf mgf2meta +mgf2rad rad2mgf mgf2meta mgfilt mgf2inv LIBFILES = source.cal tilt.cal lamp.tab tmesh.cal @@ -63,17 +63,29 @@ rad2mgf: rad2mgf.o mgf2meta: MGF_LIB mgf2meta.o $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrt $(MLIB) +mgfilt: + cd mgflib ; rm -f mgfilt ; \ + make mgfilt CC=$(CC) \ + CFLAGS="$(OPT) $(MACH) -DNOPROTO" ; \ + mv mgfilt .. + +mgf2inv: + cd mgflib ; rm -f mgf2inv ; \ + make mgf2inv CC=$(CC) \ + CFLAGS="$(OPT) $(MACH) -DNOPROTO" ; \ + mv mgf2inv .. + MGF_LIB: cd mgflib ; rm -f libmgf.a ; \ make libmgf.a CC=$(CC) \ - CFLAGS="$(OPT) $(MACH) '-DMEM_PTR=char *' -DNOPROTO" ; \ + CFLAGS="$(OPT) $(MACH) -DNOPROTO" ; \ cp libmgf.a ../../lib -mgf2rad.o: mgflib/parser.h tmesh.h - $(CC) $(CFLAGS) '-DMEM_PTR=char *' -DNOPROTO -c mgf2rad.c +mgf2rad.o: mgf2rad.c mgflib/parser.h tmesh.h ../common/color.h + $(CC) $(CFLAGS) -DNOPROTO -c mgf2rad.c -mgf2meta.o: mgflib/parser.h - $(CC) $(CFLAGS) '-DMEM_PTR=char *' -DNOPROTO -c mgf2meta.c +mgf2meta.o: mgf2meta.c mgflib/parser.h + $(CC) $(CFLAGS) -DNOPROTO -c mgf2meta.c arch2rad.o trans.o: trans.h @@ -88,5 +100,5 @@ obj2rad.o: trans.h tmesh.o: tmesh.h ../common/fvect.h -rad2mgf.o: ../common/fvect.h ../common/object.h ../common/color.h \ -../common/lookup.h +rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \ +../common/object.h ../common/color.h ../common/lookup.h
