root/radiance/ray/src/cv/Rmakefile
Revision: 2.19
Committed: Mon Mar 10 19:38:19 2003 UTC (22 years, 5 months ago) by greg
# User Rev Content
1 greg 2.19 # RCSid $Id$
2 greg 2.8 #
3 greg 1.1 # Makefile for conversion programs
4     #
5
6 greg 1.3 OPT = -O
7 greg 1.1
8 greg 1.10 MACH = -DBSD
9 greg 1.1
10 greg 2.18 CFLAGS = -I../common -L../lib $(OPT) $(MACH)
11 greg 1.1
12 greg 2.2 CC = cc
13
14 greg 2.4 MLIB = -lm
15
16 greg 1.10 INSTDIR = /usr/local/bin
17 greg 1.1
18 greg 1.10 LIBDIR = /usr/local/lib/ray
19 greg 1.3
20 greg 2.10 PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \
21 greg 2.15 mgf2rad rad2mgf mgf2meta mgfilt mgf2inv
22 greg 1.3
23 greg 2.19 LIBFILES = source.cal tilt.cal lamp.tab
24 greg 1.9
25 greg 1.3 all: $(PROGS)
26
27 greg 1.9 install: $(PROGS) $(LIBFILES)
28 greg 1.3 cp $(PROGS) $(INSTDIR)
29 greg 1.9 cd $(LIBDIR) ; rm -f $(LIBFILES)
30     cp $(LIBFILES) $(LIBDIR)
31 greg 1.3
32     clean:
33 greg 1.5 set nonomatch; rm -f $(PROGS) *.o core
34 greg 2.9 cd mgflib ; make clean
35 greg 1.3
36     thf2rad: thf2rad.o
37 greg 2.2 $(CC) $(CFLAGS) -o thf2rad thf2rad.o
38 greg 1.3
39 greg 1.6 ies2rad: ies2rad.o
40 greg 2.13 $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrt -lm
41 greg 1.1
42 greg 1.6 arch2rad: arch2rad.o trans.o
43 greg 2.2 $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt
44 greg 1.1
45 greg 1.3 nff2rad: nff2rad.o
46 greg 2.2 $(CC) $(CFLAGS) -o nff2rad nff2rad.o
47 greg 1.4
48 greg 1.6 lampcolor: lampcolor.o
49 greg 2.2 $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrt
50 greg 1.3
51 greg 2.19 tmesh2rad: tmesh2rad.o
52     $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrt $(MLIB)
53 greg 2.5
54 greg 2.19 obj2rad: obj2rad.o trans.o
55     $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrt $(MLIB)
56 greg 2.4
57 greg 2.19 mgf2rad: MGF_LIB mgf2rad.o
58     $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrt $(MLIB)
59 greg 2.7
60 greg 2.10 rad2mgf: rad2mgf.o
61     $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrt $(MLIB)
62
63 greg 2.12 mgf2meta: MGF_LIB mgf2meta.o
64     $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrt $(MLIB)
65 greg 2.15
66     mgfilt:
67     cd mgflib ; rm -f mgfilt ; \
68     make mgfilt CC=$(CC) \
69 gwlarson 2.16 CFLAGS="$(OPT) $(MACH) -DNOPROTO" ; \
70 greg 2.15 mv mgfilt ..
71
72     mgf2inv:
73     cd mgflib ; rm -f mgf2inv ; \
74     make mgf2inv CC=$(CC) \
75 gwlarson 2.16 CFLAGS="$(OPT) $(MACH) -DNOPROTO" ; \
76 greg 2.15 mv mgf2inv ..
77 greg 2.12
78 greg 2.8 MGF_LIB:
79 greg 2.12 cd mgflib ; rm -f libmgf.a ; \
80 greg 2.11 make libmgf.a CC=$(CC) \
81 gwlarson 2.16 CFLAGS="$(OPT) $(MACH) -DNOPROTO" ; \
82 greg 2.8 cp libmgf.a ../../lib
83 greg 2.7
84 greg 2.19 mgf2rad.o: mgf2rad.c mgflib/parser.h ../common/tmesh.h ../common/color.h
85 greg 2.18 $(CC) $(CFLAGS) -DNOPROTO -c mgf2rad.c
86 greg 2.12
87 greg 2.18 mgf2meta.o: mgf2meta.c mgflib/parser.h
88     $(CC) $(CFLAGS) -DNOPROTO -c mgf2meta.c
89 greg 2.7
90 greg 1.1 arch2rad.o trans.o: trans.h
91
92 greg 1.11 ies2rad.o lampcolor.o: ../common/color.h
93 greg 2.3
94     ies2rad.o: ../common/paths.h
95 greg 2.4
96 greg 2.19 obj2rad.o tmesh2rad.o: ../common/tmesh.h \
97 greg 2.7 ../common/standard.h ../common/mat4.h ../common/fvect.h
98
99     obj2rad.o: trans.h
100 greg 2.10
101 gwlarson 2.17 rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \
102     ../common/object.h ../common/color.h ../common/lookup.h
