| 1 |
| 2 |
# SCCSid "$SunId$ LBL"
| 3 |
# Makefile for conversion programs
| 4 |
| 5 |
| 6 |
OPT = -O
| 7 |
| 8 |
MACH = -DBSD
| 9 |
| 10 |
CFLAGS = $(OPT) $(MACH) -I../common -L../lib
| 11 |
| 12 |
CC = cc
| 13 |
| 14 |
MLIB = -lm
| 15 |
| 16 |
INSTDIR = /usr/local/bin
| 17 |
| 18 |
LIBDIR = /usr/local/lib/ray
| 19 |
| 20 |
PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \
| 21 |
mgf2rad rad2mgf mgf2meta mgfilt mgf2inv
| 22 |
| 23 |
LIBFILES = source.cal tilt.cal lamp.tab tmesh.cal
| 24 |
| 25 |
all: $(PROGS)
| 26 |
| 27 |
install: $(PROGS) $(LIBFILES)
| 28 |
cp $(PROGS) $(INSTDIR)
| 29 |
cd $(LIBDIR) ; rm -f $(LIBFILES)
| 30 |
cp $(LIBFILES) $(LIBDIR)
| 31 |
| 32 |
clean:
| 33 |
set nonomatch; rm -f $(PROGS) *.o core
| 34 |
cd mgflib ; make clean
| 35 |
| 36 |
thf2rad: thf2rad.o
| 37 |
$(CC) $(CFLAGS) -o thf2rad thf2rad.o
| 38 |
| 39 |
ies2rad: ies2rad.o
| 40 |
$(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrt -lm
| 41 |
| 42 |
arch2rad: arch2rad.o trans.o
| 43 |
$(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt
| 44 |
| 45 |
nff2rad: nff2rad.o
| 46 |
$(CC) $(CFLAGS) -o nff2rad nff2rad.o
| 47 |
| 48 |
lampcolor: lampcolor.o
| 49 |
$(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrt
| 50 |
| 51 |
tmesh2rad: tmesh2rad.o tmesh.o
| 52 |
$(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o tmesh.o -lrt $(MLIB)
| 53 |
| 54 |
obj2rad: obj2rad.o trans.o tmesh.o
| 55 |
$(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o tmesh.o -lrt $(MLIB)
| 56 |
| 57 |
mgf2rad: MGF_LIB mgf2rad.o tmesh.o
| 58 |
$(CC) $(CFLAGS) -o mgf2rad mgf2rad.o tmesh.o -lmgf -lrt $(MLIB)
| 59 |
| 60 |
rad2mgf: rad2mgf.o
| 61 |
$(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrt $(MLIB)
| 62 |
| 63 |
mgf2meta: MGF_LIB mgf2meta.o
| 64 |
$(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrt $(MLIB)
| 65 |
| 66 |
mgfilt:
| 67 |
cd mgflib ; rm -f mgfilt ; \
| 68 |
make mgfilt CC=$(CC) \
| 69 |
CFLAGS="$(OPT) $(MACH) -DNOPROTO" ; \
| 70 |
mv mgfilt ..
| 71 |
| 72 |
mgf2inv:
| 73 |
cd mgflib ; rm -f mgf2inv ; \
| 74 |
make mgf2inv CC=$(CC) \
| 75 |
| 76 |
mv mgf2inv ..
| 77 |
| 78 |
MGF_LIB:
| 79 |
cd mgflib ; rm -f libmgf.a ; \
| 80 |
make libmgf.a CC=$(CC) \
| 81 |
| 82 |
cp libmgf.a ../../lib
| 83 |
| 84 |
mgf2rad.o: mgflib/parser.h tmesh.h ../common/color.h
| 85 |
$(CC) $(CFLAGS) '-DMEM_PTR=char *' -DNOPROTO -c mgf2rad.c
| 86 |
| 87 |
mgf2meta.o: mgflib/parser.h
| 88 |
$(CC) $(CFLAGS) '-DMEM_PTR=char *' -DNOPROTO -c mgf2meta.c
| 89 |
| 90 |
arch2rad.o trans.o: trans.h
| 91 |
| 92 |
ies2rad.o lampcolor.o: ../common/color.h
| 93 |
| 94 |
ies2rad.o: ../common/paths.h
| 95 |
| 96 |
obj2rad.o tmesh2rad.o: tmesh.h \
| 97 |
../common/standard.h ../common/mat4.h ../common/fvect.h
| 98 |
| 99 |
obj2rad.o: trans.h
| 100 |
| 101 |
tmesh.o: tmesh.h ../common/fvect.h
| 102 |
| 103 |
rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \
| 104 |
../common/object.h ../common/color.h ../common/lookup.h
