chore: Added missing dependency
feat(iso2klems): New script to generate Klems BSDF from simplified measurements
feat(checkBSDF): created new checkBSDF tool to check XML data reciprocity
Resurrected original bsdf2rad utility (optional build)
Added value flushing to bsdfquery and put in standard build
Added pabopto2xyz utility to interpolate CIE-XYZ color values from measurements
Minor fixes
Fixed major bug in incident mesh triangulation code
Fixed compiler warnings
Include random.h for Windows instead of calling drand48
Created bsdfquery program for evaluating BSDF representations
Introducing program for interpolating BSDF data
Created pkgBSDF program
Modifications to support dmake
Added missing link to math library for ies2rad
Added 3ds2mgf to default builds
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added mgf2meta program
added rad2mgf program
minor change to clean entry
added mgf2rad program
added mapping file to obj2rad
created obj2rad program
added tmesh2rad program
standardized macro settings
moved librt to ../lib
added lampcolor
Makefile normalization
improved use of lamp data
