root/radiance/ray/src/cv/Rmakefile
Revision: 2.60
Committed: Wed May 21 17:23:07 2025 UTC (2 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.59: +9 -2 lines
feat(bsdfpeaks): Added new utility to find and measure peaks in BSDFs
# User Rev Content
1 greg 2.60 # RCSid $Id: Rmakefile,v 2.59 2024/02/26 23:43:35 greg Exp $
2 greg 2.8 #
3 greg 1.1 # Makefile for conversion programs
4     #
5
6 greg 1.3 OPT = -O
7 greg 1.1
8 greg 1.10 MACH = -DBSD
9 greg 1.1
10 greg 2.18 CFLAGS = -I../common -L../lib $(OPT) $(MACH)
11 greg 2.47 CXXFLAGS = $(CFLAGS)
12 schorsch 2.24 METACFLAGS = -I../meta
13 greg 1.1
14 greg 2.2 CC = cc
15 greg 2.48 CXX = c++
16 greg 2.2
17 greg 2.4 MLIB = -lm
18
19 greg 1.10 INSTDIR = /usr/local/bin
20 greg 1.1
21 greg 1.10 LIBDIR = /usr/local/lib/ray
22 greg 1.3
23 greg 2.56 PROGS = ies2rad nff2rad lampcolor tmesh2rad obj2rad robjutil \
24 greg 2.60 mgf2rad rad2mgf mgf2meta mgfilt mgf2inv 3ds2mgf \
25     bsdfquery bsdfpeaks checkBSDF \
26 greg 2.53 pabopto2xyz pabopto2bsdf bsdf2ttree bsdf2klems pkgBSDF epw2wea bsdf2rad
27 greg 1.3
28 greg 2.53 LIBFILES = source.cal tilt.cal lamp.tab window.cal bsdf2rad.cal
29 greg 1.9
30 greg 1.3 all: $(PROGS)
31
32 greg 2.28 install: $(PROGS) $(LIBFILES) optics2rad.csh
33 greg 1.3 cp $(PROGS) $(INSTDIR)
34 greg 2.28 cp optics2rad.csh $(INSTDIR)/optics2rad
35 greg 2.58 cp iso2klems.pl $(INSTDIR)/iso2klems
36     chmod 755 $(INSTDIR)/optics2rad $(INSTDIR)/iso2klems
37 greg 2.23 cd $(LIBDIR) && rm -f $(LIBFILES)
38 greg 1.9 cp $(LIBFILES) $(LIBDIR)
39 greg 1.3
40     clean:
41 greg 2.50 set nonomatch; rm -f $(PROGS) *.o
42 greg 1.3
43 greg 1.6 ies2rad: ies2rad.o
44 greg 2.32 $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad $(MLIB)
45 greg 1.1
46 greg 1.6 arch2rad: arch2rad.o trans.o
47 schorsch 2.27 $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad
48 greg 1.1
49 greg 1.3 nff2rad: nff2rad.o
50 greg 2.2 $(CC) $(CFLAGS) -o nff2rad nff2rad.o
51 greg 1.4
52 greg 1.6 lampcolor: lampcolor.o
53 schorsch 2.27 $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrtrad
54 greg 1.3
55 greg 2.19 tmesh2rad: tmesh2rad.o
56 schorsch 2.27 $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrtrad $(MLIB)
57 greg 2.5
58 greg 2.19 obj2rad: obj2rad.o trans.o
59 schorsch 2.27 $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB)
60 greg 2.4
61 greg 2.35 mgf2rad: mgf2rad.o
62 schorsch 2.27 $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB)
63 greg 2.7
64 greg 2.10 rad2mgf: rad2mgf.o
65 schorsch 2.27 $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB)
66 greg 2.10
67 greg 2.35 mgf2meta: mgf2meta.o
68 schorsch 2.27 $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB)
69 greg 2.15
70 greg 2.35 mgfilt: mgfilt.o
71     $(CC) $(CFLAGS) -o mgfilt mgfilt.o -lmgf -lrtrad $(MLIB)
72
73     mgf2inv: mgf2inv.o
74     $(CC) $(CFLAGS) -o mgf2inv mgf2inv.o -lmgf -lrtrad $(MLIB)
75 greg 2.7
76 greg 2.35 3ds2mgf: 3ds2mgf.o rayopt3ds.o vect3ds.o
77     $(CC) $(CFLAGS) -o 3ds2mgf 3ds2mgf.o rayopt3ds.o vect3ds.o \
78     -lmgf -lrtrad $(MLIB)
79
80 greg 2.51 pabopto2xyz: pabopto2xyz.o
81     $(CXX) $(CXXFLAGS) -o pabopto2xyz pabopto2xyz.o \
82     -lrtrad $(MLIB)
83
84 greg 2.47 pabopto2bsdf: pabopto2bsdf.o bsdfrep.o bsdfrbf.o bsdfmesh.o bsdftrans.o
85     $(CXX) $(CXXFLAGS) -o pabopto2bsdf pabopto2bsdf.o bsdfrep.o \
86     bsdfrbf.o bsdfmesh.o bsdftrans.o -lrtrad $(MLIB)
87 greg 2.38
88 greg 2.49 pabopto2rad: pabopto2rad.o bsdfrep.o bsdfrbf.o
89 greg 2.41 $(CC) $(CFLAGS) -o pabopto2rad pabopto2rad.o bsdfrep.o \
90 greg 2.49 bsdfrbf.o -lrtrad $(MLIB)
91 greg 2.41
92 greg 2.42 pabopto2rad.o: pabopto2bsdf.c bsdfrep.h
93 greg 2.41 $(CC) $(CFLAGS) -c -DTEST_MAIN -o pabopto2rad.o pabopto2bsdf.c
94
95     bsdf2rad: bsdf2rad.o bsdfrep.o bsdfinterp.o
96     $(CC) $(CFLAGS) -o bsdf2rad bsdf2rad.o bsdfrep.o bsdfinterp.o \
97     -lrtrad $(MLIB)
98
99 greg 2.55 bsdf2rado: bsdf2rado.o bsdfrep.o bsdfinterp.o
100     $(CC) $(CFLAGS) -o bsdf2rado bsdf2rado.o bsdfrep.o bsdfinterp.o \
101     -lrtrad $(MLIB)
102
103 greg 2.43 bsdfquery: bsdfquery.o bsdfrep.o bsdfinterp.o
104     $(CC) $(CFLAGS) -o bsdfquery bsdfquery.o bsdfrep.o bsdfinterp.o \
105     -lrtrad $(MLIB)
106
107 greg 2.60 bsdfpeaks: bsdfpeaks.o bsdfrep.o bsdfinterp.o
108     $(CC) $(CFLAGS) -o bsdfpeaks bsdfpeaks.o bsdfrep.o bsdfinterp.o \
109     -lrtrad $(MLIB)
110
111 greg 2.38 bsdf2ttree: bsdf2ttree.o bsdfrep.o bsdfinterp.o
112     $(CC) $(CFLAGS) -o bsdf2ttree bsdf2ttree.o bsdfrep.o bsdfinterp.o \
113     -lrtrad $(MLIB)
114 greg 2.37
115 greg 2.39 bsdf2klems: bsdf2klems.o bsdfrep.o bsdfinterp.o
116     $(CC) $(CFLAGS) -o bsdf2klems bsdf2klems.o bsdfrep.o bsdfinterp.o \
117     -lrtrad $(MLIB)
118
119 greg 2.36 pkgBSDF: pkgBSDF.o
120     $(CC) $(CFLAGS) -o pkgBSDF pkgBSDF.o -lrtrad $(MLIB)
121
122 greg 2.57 checkBSDF: checkBSDF.o
123     $(CC) $(CFLAGS) -o checkBSDF checkBSDF.o -lrtrad $(MLIB)
124
125 greg 2.40 epw2wea: epw2wea.o
126     $(CC) $(CFLAGS) -o epw2wea epw2wea.o
127
128 greg 2.56 robjutil: robjutil.o
129     $(CC) $(CFLAGS) -o robjutil robjutil.o \
130     -lwfobj -lrtrad $(MLIB)
131
132 greg 2.35 mgf2rad.o: mgf2rad.c ../common/mgf_parser.h ../common/tmesh.h \
133     ../common/color.h
134 greg 2.21 $(CC) $(CFLAGS) -c mgf2rad.c
135 greg 2.12
136 greg 2.35 mgf2meta.o: mgf2meta.c ../common/mgf_parser.h
137 schorsch 2.24 $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c
138 greg 2.7
139 greg 1.1 arch2rad.o trans.o: trans.h
140
141 greg 1.11 ies2rad.o lampcolor.o: ../common/color.h
142 greg 2.3
143     ies2rad.o: ../common/paths.h
144 greg 2.4
145 greg 2.19 obj2rad.o tmesh2rad.o: ../common/tmesh.h \
146 greg 2.22 ../common/standard.h ../common/rtmisc.h ../common/rtio.h \
147 greg 2.25 ../common/rtmath.h ../common/rterror.h ../common/mat4.h \
148 greg 2.33 ../common/fvect.h
149 greg 2.7
150     obj2rad.o: trans.h
151 greg 2.10
152 gwlarson 2.17 rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \
153     ../common/object.h ../common/color.h ../common/lookup.h
154 greg 2.35
155     mgfilt.o: ../common/mgf_parser.h ../common/ccolor.h
156
157     mgf2inv.o: ../common/mgf_parser.h ../common/ccolor.h
158
159     3ds2mgf.o rayopt3ds.o: rayopt3ds.h
160
161     3ds2mgf.o rayopt3ds.o vect3ds.o: vect3ds.h
162 greg 2.36
163 greg 2.57 checkBSDF.o pkgBSDF.o: ../common/bsdf.h ../common/fvect.h \
164     ../common/ccolor.h ../common/paths.h
165 greg 2.37
166 greg 2.47 bsdf2ttree.o bsdfinterp.o bsdfmesh.o bsdfrbf.o bsdfrep.o bsdf2rad.o bsdftrans.o \
167 greg 2.38 pabopto2bsdf.o: bsdfrep.h ../common/bsdf.h ../common/fvect.h ../common/ccolor.h
168
169     bsdf2ttree.o pabopto2bsdf.o: ../common/platform.h
170
171     bsdfrep.o: ../common/resolu.h ../common/rtio.h
172 greg 2.44
173 greg 2.46 pabopto2bsdf.o: ../common/resolu.h
174
175 greg 2.44 bsdf2rad.o bsdf2ttree.o: ../common/rtprocess.h
176 greg 2.45
177 greg 2.59 bsdf2klems.o bsdf2ttree.o mgf2meta.o: ../common/random.h ../common/calcomp.h
178 greg 2.47
179     bsdftrans.o: transportSimplex.h
180 greg 2.52
181     bsdfquery.o: ../common/rtmath.h ../common/rtio.h bsdfrep.h
182 greg 2.56
183 greg 2.60 bsdfpeaks.o: bsdfrep.h
184
185 greg 2.57 checkBSDF.o: ../common/rtio.h ../common/bsdf_m.h ../common/bsdf_t.h
186
187 greg 2.56 robjutil.o: ../common/objutil.h
