root/radiance/ray/src/cv/README
Revision: 2.7
Committed: Sat Feb 22 02:07:23 2003 UTC (21 years, 8 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD
# User Rev Content
1 greg 1.1 MODEL CONVERTER PROGRAMS
2 greg 2.7 SCCSid "@(#)README 2.6 8/25/95 LBL"
3 greg 1.1
4     This directory contains translator programs between other scene modeling
5     languages and Radiance.
6
7 greg 2.4 tmesh.h triangle mesh (barycentric coordinate) definitions
8 greg 1.1 trans.h translator definitions
9     arch2rad.c convert Architrion file to Radiance
10     ies2rad.c convert IES luminaire data to Radiance description
11 greg 2.6 lamp.tab default lookup table associating lamp types with colors
12 greg 1.1 lampcolor.c program to convert lamp color from table and compute radiance
13 greg 2.6 mgf2meta.c program to convert from MGF language to metafile 2-d graphics
14 greg 2.4 mgf2rad.c convert Material and Geometry Format to Radiance scene
15 greg 1.1 nff2rad.c convert Neutral File Format input to Radiance scene description
16 greg 2.3 obj2rad.c convert from Wavefront's .obj format to Radiance
17 greg 2.6 rad2mgf.c convert from Radiance to MGF language
18 greg 1.1 thf2rad.c convert GDS things file to Radiance scene description
19     thf2rad2.c modified thf2rad with different cylinder end caps
20 greg 2.4 tmesh.c triangle mesh (barycentric coordinate) routines
21 greg 2.3 tmesh2rad.c converts from non-standard triangle mesh to Radiance
22 greg 1.1 trans.c translator utilities
23 greg 2.5 source.cal function file for light sources from ies2rad
24     tilt.cal computes tilt factor for ies2rad
25     tmesh.cal interpolates triangle surface normal using barycentric mapping
