1 |
MODEL CONVERTER PROGRAMS |
2 |
SCCSid "$SunId$ LBL" |
3 |
4 |
This directory contains translator programs between other scene modeling |
5 |
languages and Radiance. |
6 |
7 |
tmesh.h triangle mesh (barycentric coordinate) definitions |
8 |
trans.h translator definitions |
9 |
arch2rad.c convert Architrion file to Radiance |
10 |
ies2rad.c convert IES luminaire data to Radiance description |
11 |
lamp.tab default lookup table associating lamp types with colors |
12 |
lampcolor.c program to convert lamp color from table and compute radiance |
13 |
mgf2meta.c program to convert from MGF language to metafile 2-d graphics |
14 |
mgf2rad.c convert Material and Geometry Format to Radiance scene |
15 |
nff2rad.c convert Neutral File Format input to Radiance scene description |
16 |
obj2rad.c convert from Wavefront's .obj format to Radiance |
17 |
rad2mgf.c convert from Radiance to MGF language |
18 |
thf2rad.c convert GDS things file to Radiance scene description |
19 |
thf2rad2.c modified thf2rad with different cylinder end caps |
20 |
tmesh.c triangle mesh (barycentric coordinate) routines |
21 |
tmesh2rad.c converts from non-standard triangle mesh to Radiance |
22 |
trans.c translator utilities |
23 |
source.cal function file for light sources from ies2rad |
24 |
tilt.cal computes tilt factor for ies2rad |
25 |
tmesh.cal interpolates triangle surface normal using barycentric mapping |
