| 1 |
MODEL CONVERTER PROGRAMS
| 2 |
SCCSid "$SunId$ LBL"
| 3 |
| 4 |
This directory contains translator programs between other scene modeling
| 5 |
languages and Radiance.
| 6 |
| 7 |
tmesh.h triangle mesh (barycentric coordinate) definitions
| 8 |
trans.h translator definitions
| 9 |
arch2rad.c convert Architrion file to Radiance
| 10 |
ies2rad.c convert IES luminaire data to Radiance description
| 11 |
lampcolor.c program to convert lamp color from table and compute radiance
| 12 |
mgf2rad.c convert Material and Geometry Format to Radiance scene
| 13 |
nff2rad.c convert Neutral File Format input to Radiance scene description
| 14 |
obj2rad.c convert from Wavefront's .obj format to Radiance
| 15 |
thf2rad.c convert GDS things file to Radiance scene description
| 16 |
thf2rad2.c modified thf2rad with different cylinder end caps
| 17 |
tmesh.c triangle mesh (barycentric coordinate) routines
| 18 |
tmesh2rad.c converts from non-standard triangle mesh to Radiance
| 19 |
trans.c translator utilities
| 20 |
source.cal function file for light sources from ies2rad
| 21 |
tilt.cal computes tilt factor for ies2rad
| 22 |
tmesh.cal interpolates triangle surface normal using barycentric mapping
| 23 |
lamp.tab default lookup table associating lamp types with colors
