--- ray/src/cv/README 1991/11/11 16:13:55 1.1 +++ ray/src/cv/README 1994/06/23 23:04:22 2.5 @@ -4,11 +4,20 @@ This directory contains translator programs between other scene modeling languages and Radiance. +tmesh.h triangle mesh (barycentric coordinate) definitions trans.h translator definitions arch2rad.c convert Architrion file to Radiance ies2rad.c convert IES luminaire data to Radiance description lampcolor.c program to convert lamp color from table and compute radiance +mgf2rad.c convert Material and Geometry Format to Radiance scene nff2rad.c convert Neutral File Format input to Radiance scene description +obj2rad.c convert from Wavefront's .obj format to Radiance thf2rad.c convert GDS things file to Radiance scene description thf2rad2.c modified thf2rad with different cylinder end caps +tmesh.c triangle mesh (barycentric coordinate) routines +tmesh2rad.c converts from non-standard triangle mesh to Radiance trans.c translator utilities +source.cal function file for light sources from ies2rad +tilt.cal computes tilt factor for ies2rad +tmesh.cal interpolates triangle surface normal using barycentric mapping +lamp.tab default lookup table associating lamp types with colors
