--- ray/src/cv/README 1993/03/18 09:29:46 2.2 +++ ray/src/cv/README 2003/02/22 02:07:23 2.7 @@ -1,17 +1,25 @@ MODEL CONVERTER PROGRAMS - SCCSid "$SunId$ LBL" + SCCSid "@(#)README 2.6 8/25/95 LBL" This directory contains translator programs between other scene modeling languages and Radiance. +tmesh.h triangle mesh (barycentric coordinate) definitions trans.h translator definitions arch2rad.c convert Architrion file to Radiance ies2rad.c convert IES luminaire data to Radiance description lamp.tab default lookup table associating lamp types with colors lampcolor.c program to convert lamp color from table and compute radiance +mgf2meta.c program to convert from MGF language to metafile 2-d graphics +mgf2rad.c convert Material and Geometry Format to Radiance scene nff2rad.c convert Neutral File Format input to Radiance scene description -source.cal function file for light sources from ies2rad +obj2rad.c convert from Wavefront's .obj format to Radiance +rad2mgf.c convert from Radiance to MGF language thf2rad.c convert GDS things file to Radiance scene description thf2rad2.c modified thf2rad with different cylinder end caps -tilt.cal computes tilt factor for ies2rad +tmesh.c triangle mesh (barycentric coordinate) routines +tmesh2rad.c converts from non-standard triangle mesh to Radiance trans.c translator utilities +source.cal function file for light sources from ies2rad +tilt.cal computes tilt factor for ies2rad +tmesh.cal interpolates triangle surface normal using barycentric mapping
