--- ray/src/cv/README 1991/11/11 16:13:55 1.1 +++ ray/src/cv/README 1994/06/22 15:33:20 2.4 @@ -4,11 +4,19 @@ This directory contains translator programs between other scene modeling languages and Radiance. +tmesh.h triangle mesh (barycentric coordinate) definitions trans.h translator definitions arch2rad.c convert Architrion file to Radiance ies2rad.c convert IES luminaire data to Radiance description +lamp.tab default lookup table associating lamp types with colors lampcolor.c program to convert lamp color from table and compute radiance +mgf2rad.c convert Material and Geometry Format to Radiance scene nff2rad.c convert Neutral File Format input to Radiance scene description +obj2rad.c convert from Wavefront's .obj format to Radiance +source.cal function file for light sources from ies2rad thf2rad.c convert GDS things file to Radiance scene description thf2rad2.c modified thf2rad with different cylinder end caps +tilt.cal computes tilt factor for ies2rad +tmesh.c triangle mesh (barycentric coordinate) routines +tmesh2rad.c converts from non-standard triangle mesh to Radiance trans.c translator utilities
