root/radiance/ray/src/cv/README
Revision: 2.4
Committed: Wed Jun 22 15:33:20 1994 UTC (31 years ago) by greg
Changes since 2.3: +3 -0 lines
added mgf2rad program
1 MODEL CONVERTER PROGRAMS
2 SCCSid "$SunId$ LBL"
3
4 This directory contains translator programs between other scene modeling
5 languages and Radiance.
6
7 tmesh.h triangle mesh (barycentric coordinate) definitions
8 trans.h translator definitions
9 arch2rad.c convert Architrion file to Radiance
10 ies2rad.c convert IES luminaire data to Radiance description
11 lamp.tab default lookup table associating lamp types with colors
12 lampcolor.c program to convert lamp color from table and compute radiance
13 mgf2rad.c convert Material and Geometry Format to Radiance scene
14 nff2rad.c convert Neutral File Format input to Radiance scene description
15 obj2rad.c convert from Wavefront's .obj format to Radiance
16 source.cal function file for light sources from ies2rad
17 thf2rad.c convert GDS things file to Radiance scene description
18 thf2rad2.c modified thf2rad with different cylinder end caps
19 tilt.cal computes tilt factor for ies2rad
20 tmesh.c triangle mesh (barycentric coordinate) routines
21 tmesh2rad.c converts from non-standard triangle mesh to Radiance
22 trans.c translator utilities
