root/radiance/ray/src/cv/README
Revision: 2.5
Committed: Thu Jun 23 23:04:22 1994 UTC (31 years ago) by greg
reorg and completion
1 MODEL CONVERTER PROGRAMS
2 SCCSid "$SunId$ LBL"
3
4 This directory contains translator programs between other scene modeling
5 languages and Radiance.
6
7 tmesh.h triangle mesh (barycentric coordinate) definitions
8 trans.h translator definitions
9 arch2rad.c convert Architrion file to Radiance
10 ies2rad.c convert IES luminaire data to Radiance description
11 lampcolor.c program to convert lamp color from table and compute radiance
12 mgf2rad.c convert Material and Geometry Format to Radiance scene
13 nff2rad.c convert Neutral File Format input to Radiance scene description
14 obj2rad.c convert from Wavefront's .obj format to Radiance
15 thf2rad.c convert GDS things file to Radiance scene description
16 thf2rad2.c modified thf2rad with different cylinder end caps
17 tmesh.c triangle mesh (barycentric coordinate) routines
18 tmesh2rad.c converts from non-standard triangle mesh to Radiance
19 trans.c translator utilities
20 source.cal function file for light sources from ies2rad
21 tilt.cal computes tilt factor for ies2rad
22 tmesh.cal interpolates triangle surface normal using barycentric mapping
23 lamp.tab default lookup table associating lamp types with colors
