--- ray/src/cv/CMakeLists.txt 2012/04/25 22:21:06 1.2 +++ ray/src/cv/CMakeLists.txt 2018/01/08 16:51:32 1.14 @@ -1,50 +1,105 @@ +add_executable(ies2rad ies2rad.c) +target_link_libraries(ies2rad rtrad) + add_executable(arch2rad arch2rad.c trans.c) target_link_libraries(arch2rad rtrad) -add_executable(ies2rad ies2rad.c) -target_link_libraries(ies2rad rtrad) +add_executable(nff2rad nff2rad.c) add_executable(lampcolor lampcolor.c) target_link_libraries(lampcolor rtrad) -add_executable(mgf2rad mgf2rad.c) -target_link_libraries(mgf2rad mgf rtrad) +add_executable(tmesh2rad tmesh2rad.c) +target_link_libraries(tmesh2rad rtrad) -add_executable(nff2rad nff2rad.c) - add_executable(obj2rad obj2rad.c trans.c) target_link_libraries(obj2rad rtrad) -add_executable(pkgBSDF pkgBSDF.c trans.c) -target_link_libraries(pkgBSDF rtrad) +add_executable(mgf2rad mgf2rad.c) +target_link_libraries(mgf2rad mgf rtrad) add_executable(rad2mgf rad2mgf.c) target_link_libraries(rad2mgf rtrad) -add_executable(tmesh2rad tmesh2rad.c) -target_link_libraries(tmesh2rad rtrad) - -include_directories(${CMAKE_CURRENT_SOURCE_DIR}/../meta) -add_executable(mgf2meta mgf2meta.c) -target_link_libraries(mgf2meta mgf meta rtrad) - add_executable(mgfilt mgfilt.c) target_link_libraries(mgfilt mgf rtrad) +add_executable(mgf2inv mgf2inv.c) +target_link_libraries(mgf2inv mgf rtrad) + add_executable(3ds2mgf 3ds2mgf.c rayopt3ds.c vect3ds.c) -target_link_libraries(3ds2mgf rtrad) +target_link_libraries(3ds2mgf rtrad) -add_executable(mgf2inv mgf2inv.c) -target_link_libraries(mgf2inv mgf rtrad) +if(BUILD_PABOPTO_UTILS) + add_executable(pabopto2bsdf pabopto2bsdf.c bsdfrep.c bsdfrbf.c bsdfmesh.c bsdftrans.cpp) + target_link_libraries(pabopto2bsdf rtrad) -install(TARGETS - ies2rad nff2rad lampcolor tmesh2rad obj2rad mgf2rad - rad2mgf mgf2meta mgfilt mgf2inv pkgBSDF 3ds2mgf - RUNTIME DESTINATION bin) + #add_executable(pabopto2xyz pabopto2xyz.c) + #target_link_libraries(pabopto2xyz rtrad) -INSTALL(FILES source.cal tilt.cal lamp.tab window.cal - DESTINATION lib) + add_executable(pabopto2rad pabopto2bsdf.c bsdfrep.c bsdfrbf.c bsdfmesh.c bsdftrans.cpp) + target_link_libraries(pabopto2rad rtrad) + set_target_properties(pabopto2rad PROPERTIES COMPILE_DEFINITIONS TEST_MAIN) +endif() -if (NOT WIN32) - INSTALL(PROGRAMS optics2rad.csh DESTINATION bin RENAME optics2rad) -endif() \ No newline at end of file +add_executable(bsdf2rad bsdf2rad.c bsdfrep.c bsdfinterp.c) +target_link_libraries(bsdf2rad rtrad) + +add_executable(bsdfquery bsdfquery.c bsdfrep.c bsdfinterp.c) +target_link_libraries(bsdfquery rtrad) + +add_executable(bsdf2ttree bsdf2ttree.c bsdfrep.c bsdfinterp.c) +target_link_libraries(bsdf2ttree rtrad) + +add_executable(bsdf2klems bsdf2klems.c bsdfrep.c bsdfinterp.c) +target_link_libraries(bsdf2klems rtrad) + +add_executable(pkgBSDF pkgBSDF.c trans.c) +target_link_libraries(pkgBSDF rtrad) + +add_executable(epw2wea epw2wea.c) + +include_directories(${CMAKE_CURRENT_SOURCE_DIR}/../meta) +add_executable(mgf2meta mgf2meta.c) +target_link_libraries(mgf2meta mgf meta rtrad) + +install(TARGETS + 3ds2mgf + bsdf2klems + bsdf2ttree + epw2wea + ies2rad + lampcolor + mgf2inv + mgf2meta + mgf2rad + mgfilt + nff2rad + obj2rad + pkgBSDF + rad2mgf + tmesh2rad + RUNTIME DESTINATION "bin" +) + +file(COPY + bsdf2rad.cal + lamp.tab + source.cal + tilt.cal + window.cal + DESTINATION "${CMAKE_BINARY_DIR}/lib" +) + +if(NOT WIN32) + install(PROGRAMS optics2rad.csh + DESTINATION "bin" + RENAME optics2rad + ) +endif() + +if(BUILD_PABOPTO_UTILS) + install(TARGETS pabopto2bsdf pabopto2rad + DESTINATION "bin" + ) +endif()
